Old Oct 20, 2010, 12:38 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Build Log
EPP f3P Plane
This will be the official thread for my New EPP F3P Plane
Video attached
EPP F3P Pattern Plane (1 min 38 sec)
Plans can be ordered from my website at for just $3.99
http://www.sdparkflyers.com
Below is also a list parts and items used to build this plane.
Parts list for a EPP F3P Kit
1. sheet 24 x 36 1.3# 6mm epp white foam
1. 40" x 3mm carbon rods or tubes
3. 3.7g Ultra Micro Servos
1. 1400kv Micro brushless outrunner
1. GWS 8043 Slofly prop
1. prop saver + bands
1 set Dubro micro pushrods (20-30") version
2 sets dubro quick connects
1. 1/8" Plywood Motor mount
2. sets dubro micro horns
1. sheet of lightply 16th inch thick
1 roll strapping tape
1. 9-10 amp brushless esc
1. box #11 x-acto blades
1. medal straight edge (18-24 inch)
sharpie pens for color
5 minute epoxy
hot glue gun with low temp sticks
battery used is 7.4 volt 360 mah is what I use. (hobby City)
1 small 4 channel receiver (I use the gws 4 channel)
1 transmitter.
(I will list parts that order from Hobby City as these plans are being downloaded from around the globe and Hobby city ships most places)
for those of you living in the USA I will post a link to my webstore for parts and accessories also.
tallflyer is offline Find More Posts by tallflyer
Old Nov 02, 2010, 08:49 PM
nerdc0re79 is offline
Find More Posts by nerdc0re79
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
cg?
nerdc0re79 is offline Find More Posts by nerdc0re79
Old Nov 02, 2010, 09:46 PM
tallflyer's Avatar
Joined Jul 2002
The CG as seen in the video when Im flying is about 1" in front of the spar.
I will double check for you.
Latest blog entry: My Official 3DR Solo Blog
Old Nov 04, 2010, 02:58 PM
tallflyer's Avatar
Joined Jul 2002
More raw footage of my F3P plane
Raw video of my 6mm EPP F3P plane (2 min 43 sec)
Old Dec 08, 2010, 07:33 AM
lonergb is offline
Find More Posts by lonergb
WHERE NO ONE HAS GONE BEFORE
lonergb's Avatar
GuangZhou
Joined Dec 2005
You did not tell us the most important data: THE FLYING WEIGHT
lonergb is offline Find More Posts by lonergb
Old Dec 08, 2010, 01:50 PM
tallflyer's Avatar
Joined Jul 2002
AUW! is a little under 7oz I think I will throw it on the scale tonight after work!
Old Dec 09, 2010, 04:28 PM
tallflyer's Avatar
Joined Jul 2002
Ok so I put it on the scale last night and the plane without battery is 5.0oz so the flying weight with 2 cell 350mah is at 6.7- 6.9oz.
Old Dec 14, 2010, 08:13 PM
sims76 is offline
Find More Posts by sims76
USA, PA, Mohnton
Joined Apr 2007
Thanks SD Parkflyers. Easy build love it. I made it out of 9mm EPP and 3mm carbon tube in the wing and horizontal stab. Other than that, I used an alternate motor mount.
Some obligatory indoor hovering.
F3P 9mm EPP (1 min 46 sec)
sims76 is offline Find More Posts by sims76
Old Dec 14, 2010, 10:41 PM
tallflyer's Avatar
Joined Jul 2002
sims76
Thanks for sharing this has to be one of the most stable planes I have every designed
plane will track straight and holds a hover nice.
Thanks again for sharing
Old Dec 18, 2010, 03:08 PM
sims76 is offline
USA, PA, Mohnton
Joined Apr 2007
First attempt at in-flight video using keychain cam.
Tallflyer's www.sdparkflyers.com F3P (3 min 52 sec)
Old Mar 31, 2011, 12:18 AM
orangepeal is offline
Find More Posts by orangepeal
orangepeal's Avatar
Vestavia Hills, AL
Joined Dec 2008
Hey Robert. I enjoyed building and painting this plane! It's my 3rd EPP build in about a month and I think I'm getting the hang of it. Before I decide where to put the electronics, I was hoping you could confirm the recommended CG is about where you indicated above. Here's some pics of my build . . . . Thanks !!
orangepeal is offline Find More Posts by orangepeal
Old Mar 31, 2011, 12:59 AM
tallflyer's Avatar
Joined Jul 2002
CG Location
I used your drawing to make a mark on your photo to show you a good place to set you cg,
Since you have not installed any hardware you might even go with a dual aileron servo setup!
Old Mar 31, 2011, 01:18 AM
orangepeal's Avatar
Vestavia Hills, AL
Joined Dec 2008
Thanks Robert. I was thinking of using 2 aileron servos--I'll probably use HXT500s all the way around.
Best,
Ed
Old Feb 28, 2012, 03:32 PM
KTMRacr is offline
Find More Posts by KTMRacr
When in doubt, gas it!
KTMRacr's Avatar
United States, KS, Spring Hill
Joined Dec 2010
What is the wingspan on this thing?
KTMRacr is offline Find More Posts by KTMRacr
Discussion HK Cessna 182 Micro plane EPP Telechat Micro Ready-to-Fly 6 Oct 16, 2010 11:01 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 06:29 PM
Build Log The New ULD EPP-DEPRON Durable F3P plane kit tallflyer Foamies (Kits) 17 Mar 25, 2009 04:22 PM
Discussion E-foamies.com EPP F3P Plane 3d_Crazy Indoor Pattern/F3P 15 Aug 20, 2006 10:37 PM
Idea EPP F3P Practice Plane? 3d_Crazy Indoor Pattern/F3P 26 Feb 15, 2006 11:34 AM
