Old Oct 19, 2010, 09:43 PM
dards is offline
Find More Posts by dards
Joined Dec 2007
World Models p47 1.20
Hi
I just purchased a p47 1.20 from world models.
Following are the specs
Wing Span : 70 in / 1780 mm
Wing Area : 893 sq in / 57.6 sq dm
Flying Weight : 10.7 lbs / 4850 g
Fuselage Length : 62 in / 1580 mm
Engine Required : 4-stroke 1.20 engine
Would appreciate if someone could comment on the following questions
Ideal Power Plant
Option1: Saito 125, which is considerably lighter than OS four stroke 120 about 200g lighter. Do not want to add dead weight so will I be able to balance it with battery placement? Does Saito 125 will be enough to pull the plane this size?
Option 2: The newly released DLE20? approximately same weight as OS FS120? Will it have enough power to this plane?
Servos:
To save some weight and to use some of the servos that I already have I am planning to use Hitec HS5345 servos on all control surfaces except retracts? Do you think I will be alright with these servos.
Any other thing I need to be careful about while assembling this plane?
Thanks in advance.
Salman
www.rcpak.com (Pakistan's largest website on rc hobby)
dards is offline Find More Posts by dards
Old Oct 20, 2010, 10:55 AM
Old Fart is online now
Find More Posts by Old Fart
Lost at LAX
Old Fart's Avatar
United States, CA, Lakewood
Joined Dec 2005
DLE30. I have a RCGF 26cc on mine and it's a dog. One of these days I'll get another cowl and go 30cc.
No real issues with the build, don't get too crazy with the heat when you go over the covering - it's pretty thin.
Old Fart is online now Find More Posts by Old Fart
Question World Models P47-D 1/7 scale Mr48Volts Fuel Warbirds 49 Dec 27, 2015 10:45 AM
Wanted I need a pipe & muffler for a YS 1.20, OS 1.20, & Saito 1.20 stevster Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 04, 2010 12:45 AM
Question World Models 1/4 Cub JEanes Fuel Plane Talk 0 Sep 18, 2010 07:39 PM
Help! World Models Funworld 1.20 to Electric. What kind of Battery? sneasle Glow to Electric Conversions 3 Feb 13, 2009 02:46 PM
For Sale World Models 300 w/ Magnum 1.20 JEanes Aircraft - Fuel - Airplanes (FS/W) 1 Mar 09, 2008 07:24 AM
