Old Oct 18, 2010, 10:19 PM
3DPat is offline
Find More Posts by 3DPat
Pat Nguyen
Rochester, NY
Joined Sep 2009
Help!
Mamo Models VPP Help
I have the perfect setup for this vpp unit.
Hacker A20-34s
Thunderbird 9 ESC
Dualsky 300 45c Batteries
Yak 55m
But the motor mount failed a while back and I broke and lost the lever and the bearing. So I'm thinking of doing the direct servo as the lever. Where would be a good place to get the right sized bearing? I've already tried bocabearing but they we on backorder. Thanks
-Pat Nguyen
3DPat is offline Find More Posts by 3DPat
Old Oct 19, 2010, 03:02 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
You broke the mount
Have a look at the micro heli spares, bound to be a bearing to suit there.
I have a drawing for a mount and direct servo control if you need it
Andy
Andycap is offline Find More Posts by Andycap
Old Oct 19, 2010, 05:05 PM
3DPat is offline
Pat Nguyen
Rochester, NY
Joined Sep 2009
It'd be great if you could send me the drawing. Thanks
-Pat Nguyen
Old Oct 20, 2010, 03:39 AM
Andycap is offline
Andycap's Avatar
Leeds
Joined Mar 2003
No Problem Pat.
The mounting lugs are shown 5mm wide as the mount is designed for an EPP Nose
Andy
Old Oct 20, 2010, 05:25 PM
3DPat is offline
Pat Nguyen
Rochester, NY
Joined Sep 2009
Thank you! Now all I gotta do is find a bearing.
Old Oct 20, 2010, 08:08 PM
airportdog is offline
Find More Posts by airportdog
departure from controlled flt
airportdog's Avatar
SF Bay Area
The pitch bearing is an M1.5x4 (x2 wide).
I would guess this one should work fine.....
http://www.helidirect.com/abec3-bear...pcs-p-2126.hdx
Larry
airportdog is offline Find More Posts by airportdog
Old Oct 20, 2010, 08:29 PM
3DPat is offline
Pat Nguyen
Rochester, NY
Joined Sep 2009
Thank you soooo much!
Sold Mamo Models Upside-down VPP Prop Jeff Pfeifer Aircraft - Electric - Power Systems (FS/W) 5 Jun 04, 2010 06:21 PM
Discussion Anybody have the Mamo VPP instructions ? heffalump 3D Flying 2 Apr 17, 2007 02:02 PM
For Sale Mamo Models VPP j_z_123 Aircraft - Electric - Power Systems (FS/W) 2 Mar 27, 2007 08:07 PM
Discussion Mamo VPP system - is it any good ? heffalump 3D Flying 1 Jan 26, 2007 04:16 AM
