Old Oct 18, 2010, 08:23 PM
Watch out all you moles!
g'ville,fl
Joined Sep 2010
fooltaba 7c part II
Well, I am almost there. The radio finally came back. It is broadcasting.
He switched my idle up to a right side switch, which is playing havoc with my heli flying.
But.......it has been pointed out that I should limit my total aileron deflection to about 3/8", on a taboo, equal up and down.
I would think the way to limit the travel would be with end points, but if I cut those down it will also limit the flap travel, which I have been advised to give all the servo has to offer.
Is there a way to limit the ail deflection and still have full - 1" dropping - flaps?
(I love this plane. It is the finest flying thing I have ever controlled. Well, sort of controlled)
sky'hi' is offline Find More Posts by sky'hi'
Old Oct 18, 2010, 09:00 PM
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
I think you might find what you're looking for in the "differential" setting.
carlsoti is offline Find More Posts by carlsoti
Old Oct 18, 2010, 11:21 PM
Tucson, AZ
Joined May 2004
Just set dual rates for the ailerons. For low rates, just use whatever % gives you the desired 3/8" travel.
billwolfe is offline Find More Posts by billwolfe
Old Oct 19, 2010, 07:47 AM
g'ville,fl
Joined Sep 2010
Thanks guys. I ran differential up and down it's spectrum but dual rates sounds promising.
I guess I should be able to set a mode in the throw I want and leave it there always. Have never messed with dr but it makes sense.
Old Oct 19, 2010, 09:31 AM
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
End point adjustments are for setting maximum servo travel limits, so as to avoid mechanical interferance.....ie your horn or linkage running into some part of the plane.
The "dual-rates" are definetly where you want to be to limit just aileron travel. Just because they call it "dual" rates does not mean you have to set up two different things on the switch, btw they could be the same settings in both switch positions.
I often got into trouble forgetting I'm on low rates and then not having the control athority when landing flaps were down. I now avoid that problem by using only the expo on the dual-rates menu, for a "low rate" I crank up the expo to around 40-50%. that softens the controls enough, but if I need the full throw I don't need to hit a switch first. I fly on my "high rate", which has much less or no expo, unless I need finer control for thermaling. The travel limits are the same for both "rates".
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Oct 20, 2010, 08:58 AM
g'ville,fl
Joined Sep 2010
Yeah, it dawned on me that I can set the dual rate switch at the same value in both directions and avoid the problem of bumping it with my fumbly fingers.
I am still in the habit of dropping the flaps all the way even when I don't want them (slamming them down), because I have been using that stick for throttle for so many years.
One thing at a time. (my new motto)
Old Oct 20, 2010, 09:41 AM
Joined Apr 2007
loop a rubberband around the transmitters metal handle (the one on the back) now take the free end of the rubberband and loop it around the throttle stick.
VIOLA stick springs forward all by itself!! Old tircks are the best tricks as they say
Any other problems I can solve for you?? LOL
For Sale TA-7C Corsair II by FSK dlazarus6660 Aircraft - Electric - Jets (FS/W) 6 Jan 09, 2013 04:32 PM
What fan to use in TA-7C Corsair II? Aubard Electric Ducted Fan Jet Talk 2 Dec 26, 2003 04:25 PM
Flying Styro Vought TA-7C Corsair II ARF dave_lilley Electric Ducted Fan Jet Talk 7 Dec 31, 2002 09:06 AM
Flying Styro Vought TA-7C Corsair II ARF dave_lilley Site Chat 0 Dec 20, 2002 12:44 AM
