Old Oct 18, 2010, 05:01 PM
ganapati08 is offline
Find More Posts by ganapati08
Unlimited FPV
ganapati08's Avatar
Latvia, Riga
Joined Jun 2010
How to build heavy Duty Antenna Tracking pod for Eagle Tree FPV?
now its time to make own tracking pod instead of buying expensive one like this: https://www.dpcav.com/xcart/product.php?productid=16555
What you can advice guys? is there any ready schematic/doc for cutting?
The stuff that i already have and want to use in this pod.
two servos
S4315M Tilt 213 oz-in ~90 - http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
S8166M Pan (heavy duty)417 oz-in~180 - http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
(these servos recommended by dpcav.com) (also got ''shipped' price on ebay much less then on dpcav) u can get these servos from my links.
1x - FPV eagle station
two 2x - R1200-DELUXE 1.2 Ghz Portable High Sensitivity Receiver - http://hobbywireless.com/cart/index....roducts_id=288
1x - 8 dBi 1.2/1.3 GHz Flat Patch Antenna - http://fpvsystems.com/index.php?main...products_id=54
1x - 13 dBi 802.11b/g Wifi Yagi Antenna N Female 1.2 GHz (with shipping) - http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
1x - 6500mah 12V DC Rechargeable CCTV Li-ion battery - http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
also i got monitors and googles but this is not needed for details as this stuff will be wired from station.
ganapati08 is offline Find More Posts by ganapati08
Old Oct 19, 2010, 06:36 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Metal = bad
It will create loss due to multipath interference. That is why most antenna trackers are made from wood. You can use wood, plastic, or any other non-conductive material. That doesn't mean metal won't work. It just means that you need to get the antenna away from it for optimal performance.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 19, 2010, 06:54 AM
Unlimited FPV
ganapati08's Avatar
Latvia, Riga
Joined Jun 2010
Originally Posted by IBCrazy View Post
Metal = bad
-Alex
Thanks IBCrazy for the advice! Preciate it!
Old Oct 19, 2010, 10:58 AM
blade thrasher is offline
Find More Posts by blade thrasher
KJ4IKY Gravity Wins
blade thrasher's Avatar
Georgia
Joined Apr 2007
Im just about to start building one also. So far I have the tripod but thats about it. Still trying to figure out the design for the ply. Im planning on using some standard birch ply, 1/4". I have a Yagi but I think it may be difficult to counterbalance for the servo to easily turn so I may end up getting a patch to replace it.
blade thrasher is offline Find More Posts by blade thrasher
Old Oct 19, 2010, 12:14 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
cant you mount the yagi half way down so that it balances itself ?
Blackrat is offline Find More Posts by Blackrat
Old Oct 19, 2010, 12:19 PM
KJ4IKY Gravity Wins
Georgia
Joined Apr 2007
That Im not sure? Although I did get my HAM license for FPV I dont know much about wave interference or how that could affect the feed elements. If it wouldnt that would be a good simple way to mount.
Also I have two, one vertical and one horizontal although I dont know if its possible to use both along with the omni through the EAgle Eyes diversity.
Old Oct 19, 2010, 12:24 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
I tried mounting half way down but i found the wires put extra strain on the servo`s too
Coyote64 is offline Find More Posts by Coyote64
Sold Heavy duty Octocopter (8KG!) for AP/AV jago_svensson Aircraft - Electric - Helis (FS/W) 6 Jan 30, 2011 02:09 PM
Discussion Heavy duty landing gear for quad/mikrokopter! IDEAS? adbo Multirotor Talk 9 Dec 20, 2010 10:37 AM
Discussion Home made FPV parts..camera pod..antenna tracking..:D DavorVZ FPV Talk 6 Sep 04, 2010 06:06 AM
Build Log Wild Hawk / Supper Lightning Eagle Tree FPV Build. SoMoney FPV Talk 11 Jul 03, 2010 08:51 AM
