Old Oct 18, 2010, 04:46 PM
MechatronicsLLC is offline
Find More Posts by MechatronicsLLC
MechatronicsLLC's Avatar
Joined Oct 2010
New Product
Navigation Board M3 - Open Source combined IMU and GPS
Hi everyone,
The new NavBoard M3 has both the inertial sensors and GPS capability you might need, along with onboard processing and a native USB interface for easy code changes and use as a dedicated serial port!
While not specifically a drone or autopilot, we recently upgraded our I2C sensor based Navigation Board (which previously did not have an on board processor) with on board ARM processing and USB connectivity. This allows the unit perform as a standalone unit or as a sensor only board.
The unit could also easily be attached to a XBee or other modem for wireless flight telemetry.
The NavBoard contains:
  • U-Blox GPS with onboard antenna and external antenna jack
  • ITG-3200 3 axis rate sensor
  • LIS3LV02DQ 3 axis accelerometer
  • HMC 5843 3 axis magnetometer
  • LPC 1343 ARM Cortex M3 processor (32k flash, 8k ram)
Best of all, the firmware is all open source. A Visual Basic .net GUI for interfacing to the unit is open source as well.
https://code.google.com/p/navboard-m3/
With no firmware programmed into the ARM, or holding it in reset using a jumper, the unit is an I2C device with all the inertial sensors, magnetometers, and GPS capabilty you need to interface to an autopilot.
With on board firmware, you can customize the unit into a standalone device capable of anything needing attitude and location information. Even rudimentary autopilot capability could be programmed into the unit!
So feel free to check out the manual, videos and software here:
http://www.ryanmechatronics.com/inde...NavBoardM3.htm
We hope you find it useful!
MechatronicsLLC is offline Find More Posts by MechatronicsLLC
Discussion PIXHAWK pxIMU v.2.5 Open-Source IMU now available! pixhawk UAV - Unmanned Aerial Vehicles 4 Apr 30, 2011 04:47 AM
Poll New tightly integrated, fast Open Source IMU/Autopilot board pixhawk UAV - Unmanned Aerial Vehicles 14 Nov 16, 2010 06:13 AM
Poll New tightly integrated, fast Open Source IMU/Autopilot board for student competitions pixhawk Chit Chat 0 Aug 04, 2010 05:48 AM
Poll New tightly integrated, fast Open Source IMU/Autopilot board pixhawk DIY Electronics 0 Aug 04, 2010 05:46 AM
Poll New tightly integrated, fast Open Source IMU/Autopilot board pixhawk Multirotor Talk 0 Aug 04, 2010 05:45 AM
