Old Oct 18, 2010, 09:03 AM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Question
ICE 100 BEC rating?
Hi everyone!
I'd like to pick your brains about using the ICE 100 in a 6S "500" heli (LAHeli Sniper), and whether the BEC is up to the task. Here's the setup:
LAHeli Sniper V2 (470mm blades)
Cyclic servos: Align DS510
Tail servo: JR 8900G
FBL: BeastX MicroBeast
RX: AR7000
I was previously running a Jazz 80-6-18 (and using its 4A continuous-rated onboard BEC) but a failure of the previous FBL unit seems to have fried the Jazz (along with killing a 9254 and stripping gears in all 3 cyclics )
Anyway, to my question:
Does the ICE 100's onboard BEC have the guts to run that setup? All I could find was "5A peak" rating, but I wonder what the continuous rating is?
Thanks for any advice.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Oct 18, 2010, 01:33 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I have not tested it but there was some posts a while back where it was tested under flight conditions and they found that 3 amps is about it before the voltage start dropping.
Spektrum receivers are very sensitive to voltage drop so you should probably use a BEC Pro V2.
RC Man is offline Find More Posts by RC Man
Question Phoenix ICE BEC current rating? nsg Castle Creations 25 May 28, 2011 08:54 PM
Question Anyone know what the max continues rating is on the ICE BEC snjbird Castle Creations 24 Sep 01, 2010 11:41 PM
Discussion CC ice 100 / CC pro bec esc will not link bobbyshafter Castle Creations 5 Mar 02, 2010 09:16 PM
Sold ICE 100 | < 10 flights | CC BEC numb_thumb Aircraft - Electric - Power Systems (FS/W) 2 Feb 02, 2010 04:22 PM
Discussion Ice 100 issues with the BEC. litespeed Castle Creations 1 Dec 30, 2009 12:47 PM
