Old Mar 01, 2011, 11:05 AM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
"couldn`t get them cycled enough times for break-in"
Hey Knife
Would you mind explaining your break in procedure for the batteries?
Air Head is offline Find More Posts by Air Head
Old Mar 01, 2011, 08:45 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
Just visited JHH web site. Turbax rotors are now $50.00 plus $8.00 shipping. I guess demand is up and supply is down. Makes me think about buying 11 Dynamax blades for $88 and cutting them down to fit the 4.5 shroud. Anyone tried this yet? I wonder if it would sound more like a turbine?
rfodor is offline Find More Posts by rfodor
Old Mar 01, 2011, 09:15 PM
ca_fingers is offline
Find More Posts by ca_fingers
Been there , Crashed that
Joined Mar 2010
you might try tamjets website, i thing i saw something on the about a 120mm and a 110mm with the dynamax rotor . might give a bit of an idea performance wise.
ca_fingers is offline Find More Posts by ca_fingers
Old Mar 01, 2011, 09:20 PM
tag is offline
tag
Find More Posts by tag
tag
Trevor
tag's Avatar
Canada, SK, Estevan
Joined Nov 2002
The blades on a dynamax are removeable so you would need the hub as well.
tag is offline Find More Posts by tag
Old Mar 01, 2011, 09:24 PM
rfodor is offline
Joined Feb 2009
I have a whole fan, just needs new blades.
Old Mar 01, 2011, 10:09 PM
Joined Mar 2010
ok i found some video of tams with a dynamax rotor in a tj120 . performance numbers are close to the 4.5 with turbax rotor. when comparing these two fans the bang for the buck factor is way up on the haoye/turbax.
Tamjets TJ120 BVM Electra video.wmv (6 min 46 sec)
Old Mar 02, 2011, 04:34 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
Finally all the parts arrived. So now it's assembly time
Samjet is offline Find More Posts by Samjet
Old Mar 02, 2011, 05:53 AM
rfodor is offline
Joined Feb 2009
I like the sound of the TJ120 a lot more. As far as bang for the buck I agree abouth the Haoye/Turbax unless you already have a hub and only need the rotor blades ($60 (with the spinner) Vs. $88 for 11 blades). The Dynamax in the 4.5 will be around 114 MM not 120 like in the TJ, I wonder what impact the smaller size will have on thrust. Maybe I'll just try cutting down the blades I have (they have significant FOD wear and tear) and see what happens. I wonder how many stators the TJ120 has and what effect less stators in the 4.5 will have also.
I guess that is why we experiment...... I'll have to find a safe place to stand in my basement workshop.
Ron
Old Mar 02, 2011, 01:56 PM
Joined Mar 2010
still waiting on my fan to arrive, can some on verify the outer diameter of the shroud that the ducting fits over on the 4.5 ". i went by hobby city's diameter of 122mm for the shroud but would like a real world measurement . i made the fan end of the ducts with a slight taper so it can be trimmed for a snug fit . wanna get the ducts in so i can plank the fuse. thanks
Old Mar 02, 2011, 02:08 PM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
I just messured mine it IS 122 mm
Old Mar 02, 2011, 02:15 PM
Joined Mar 2010
Very awesome. thanks so much
Old Mar 02, 2011, 10:52 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
dont bother using the stock turbax spinner.....it will vibrate like crazy. your better off without it at this point.
corsair nut is offline Find More Posts by corsair nut
Old Mar 02, 2011, 11:27 PM
Joined Mar 2010
is jhh the only source for the turbax rotor? quite the price jump on the rotor in the past little while
Old Mar 03, 2011, 12:19 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Yeap, supply and demand...at that price I don't think I demand turbax rotors all that much
erh7771 is offline Find More Posts by erh7771
Old Mar 03, 2011, 01:00 AM
tehachapi, CA
Joined Jan 2006
when you consider you spend over 100 bucks for a dynamax rotor...that doesnt sound too bad. sure its not hoaye price range....but its not a inefficient amp hog either...and it comes dynamically balanced. by comparison, youll spend 35-40 bucks for a balanced 90mm rotor...
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
