Old Feb 24, 2011, 07:19 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Very nice Lee
rvincent is online now Find More Posts by rvincent
Old Feb 24, 2011, 07:30 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Thanks Bob. I showed my girlfiend, but she wasn`t very impressed. She asked if I was going to put flowers in it for her................. but I knew my buddies on RCG would appreciate my work. LOL
Knife Liddle is offline Find More Posts by Knife Liddle
Old Feb 24, 2011, 07:32 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Bill, here is a copy of post #485 is has the numbers from the 4" fan and the 1100kv motor. Pretty hot set-up. I`ll be putting it into something.
OK guys here are some numbers to chew on. This is the Turbax rotor cut down to fit in the Haoye 102mm (4") shroud, driven by the Turnigy 4030-1100. The shroud is old and is slightly out of round and so the gap is not that great but it`s acceptable. The batteries are the blue Turnigy 25c 5000mah.
I cut and reshaped a midifan intake ring ti fit and glued it to the shroud, and sealed the gap with tape. Quick and dirty.
10s
105a
36.0v
3.8kw
11 lbs thrust
221 mph
11s
120a
40.6v (aprox 3.6 per cell)
4.9kw
12.5lbs thrust
237 mph
12s crazy (for this motor)
145a
42v (aprox 3.5 per cell)
6.1kw
14.5lbs thrust
255 mph
There it is. These are not super accurate numbers, but close enough to get the message that the rotor still works well at 100mm. The 11s numbers are very similar to a very high-end 100mm that can cost 7 or 8 times as much when you include the Neu to run it. I`m not saying it`s as good. I`m just saying the numbers are similar
Old Feb 24, 2011, 11:47 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
and to think i did all that work ..i better snag one of those for all these smaller fans .
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 25, 2011, 12:34 AM
ca_fingers is offline
Find More Posts by ca_fingers
Been there , Crashed that
Joined Mar 2010
^hence why i am divorced...women:
Lee, im pondering the 4.5" for my mirage ,but she is bigger than most (45" span /71" long approx). my ideal weight would be around 15 lbs but with my luck she'll be a plumper a 20lbs . at 15# my watts are 320 and at 20# they're 240 . will 240 be enough for a jet? im gonna swiss cheese the airframe and cover with monokote to lighten her up. also 2 layers of 4 oz. glass wrapped with carbon tow heavy enough for ducts? first time using glass for ducting. thanks
ca_fingers is offline Find More Posts by ca_fingers
Old Feb 25, 2011, 01:24 AM
yakhakker is offline
Find More Posts by yakhakker
still trying to get it right
yakhakker's Avatar
Belgium, Région wallonne, Tournai
Joined Feb 2009
Thanks for the photos Lee, you have this weeks ingenuity award!. I am now off to home base to measure all the vases for a 5 inch version cheers
yakhakker is offline Find More Posts by yakhakker
Old Feb 25, 2011, 08:38 AM
Getmore Rc is offline
Find More Posts by Getmore Rc
Matrix 90 & 100mm sport jet
Getmore Rc's Avatar
Merritt Island Fl
Joined Aug 2008
Thanks Lee. I have one of the 1100kv Im thinking of doing one of my Matrix with that setup. If it puts out 11lb's of thrust on 10s look out and I be a
Getmore Rc is offline Find More Posts by Getmore Rc
Old Feb 25, 2011, 10:09 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That should be great in the Matrix. The 11 lbs was with an intake ring and open exhaust but even with ducting you should see about 10. The add a cell for turbo boost
Old Feb 25, 2011, 10:15 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Glad you liked my plug idea. If you can't find exactly what you are looking for get something a little bigger and then cut it down when you join the two halfs.
Guess what I used as release adgent on the glass. Ever heard of Rain-X? Worked great. Only took seconds to apply and didn't effect the glass at all. That was poly resin not epoxy resin.
Old Feb 25, 2011, 06:22 PM
yakhakker's Avatar
Joined Feb 2009
Thanks for that Lee, sorry but rain x is new to me what is it for?
Old Feb 26, 2011, 12:16 AM
Joined Mar 2010
rain-x is a car wax that is supposed to shed water better than others. supposedly works good on windshield glass too.
Old Feb 26, 2011, 01:06 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
jcdfrd is offline Find More Posts by jcdfrd
Old Feb 26, 2011, 01:13 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Turns out that the weather tomorrow is supposed to be good, so I`ve done a quick finish on the nacelle tonight and plan to get it in the air tomorrow. I didn`t take any pics along the way due to the lack of time, but I`ll do another one (I have another plane that needs one). So I`ll take more pics on the next one.
The fan gets the mounting tabs cut off of it, then it is a friction fit into an inner mounting ring glued inside the nacelle. A little tape is added to the outside of the fan if needed for a tight fit. Then I`ll use one or two set screws to make sure that the fan doesn`t rotate inside of the housing. Then the rear section of the nacelle will be attached to finish it off.
Old Feb 26, 2011, 01:34 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
a few more pics in place on the Falcon
Old Feb 26, 2011, 08:11 AM
jweber009 is offline
Find More Posts by jweber009
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
Finally I got the exhaust duct finished..... so I'll be assembling the Saves F-16 this weekend. Maybe it will be ready for it's maiden tomorrow.
jweber009 is offline Find More Posts by jweber009
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
