Old Feb 19, 2011, 09:53 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
yes, he does sell just the turbax adapter for 6m shafts. fits like a dang glove
i know its more money, but it really makes this setup really fast and easy to assemble, but i think the big selling point is the fact that it keeps the motor super cool so if you plan to run 12s, it will live al long time.
also, this weekend hes finishing off the motor extension for the e turbax, so if you want to use the full turbax with this motor(or just about any other motor out there....you can. hes also going to be making a setup for direct hookup with a 19 series neu......
also, im hoping in a couple weeks he'll have the alum turbax spinners done...
also, you must remember this guy is making this stuff in his personal shop, by hand. its not cheap or easy to do. hes barely breaking even on these after you consider the hours it takes to make one.
corsair nut is online now Find More Posts by corsair nut
Old Feb 19, 2011, 09:54 AM
Par_18 is online now
Find More Posts by Par_18
United States, VA, Virginia Beach
Joined Dec 2005
Originally Posted by Samjet View Post
That sounds right. Both the fan and the esc are backordered at HK. But I found the hobbywing 120a esc at Hobby Hot and the fan at Low Price RC where they name the fan Astral 4.5". The also have the 120 a esc at Low Price RC but for 133$ istead of 120$ at hobby hot.
I can't find at suitable 6 mm collet for the motor and the turbax fan. Does anybody have a suggestion? Thanks
Samjet,
Is this the same ESC: http://www.hobbyhot.com/hobbywing-pl...er-pr-751.html
This one says it has a BEC on it as well, not that I want to use it. The HK one doesn't have a BEC on it, so is it really the same?
Par_18 is online now Find More Posts by Par_18
Old Feb 19, 2011, 09:57 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Sweet, do you know if he's got the motor extension for the 4" shroud done?
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Feb 19, 2011, 10:00 AM
tehachapi, CA
Joined Jan 2006
he may have it done this weekend....
Old Feb 19, 2011, 10:03 AM
Senior Member
Molde, Norway
Joined Jan 2001
Originally Posted by Par_18 View Post
Samjet,
It's a typo, the pic of the controller shows it clearly says Opto on the label so that's a mistake in the description. It also says no BEC in the specs further down.
Old Feb 19, 2011, 10:38 AM
Joined Dec 2005
You are absolutely right. I just ordered it and it was 10 bucks cheaper than HK.
Old Feb 19, 2011, 10:43 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
Yeah pretty cheap
Samjet is offline Find More Posts by Samjet
Old Feb 19, 2011, 06:12 PM
tag is offline
tag
Find More Posts by tag
tag
Trevor
tag's Avatar
Canada, SK, Estevan
Joined Nov 2002
Hey buckaroo. It is, but then again it isn't a ziroli panther. I bought the ziroli plans and shrunk them 15%. I thought the smaller size would match my homebuilt turbine better. About 9 pounds of thrust max. It's just one of those projects that I never completed. The EDF setup will be much simpler than the kero burner.
The fuse is balsa stringers over the lite ply formers then sheeted with 1/8 x 3/4 balsa planking. The wings are traditional built up balsa and lite ply. Of course the ziroli canopy, tip tanks, inlet ducting, etc won't fit. Scrounge and scratch build I guess. It's probably been 3 or 4 years since I last worked on it.
Sorry guys, for going off topic a bit on your thread.
tag is offline Find More Posts by tag
Old Feb 19, 2011, 08:24 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
That`s some beautiful work. It`s rewarding to see old projects getting dusted off and comming back to life because of sharing some helpful info. We expect to see a maiden video when the time comes. Lee
Knife Liddle is offline Find More Posts by Knife Liddle
Old Feb 19, 2011, 11:02 PM
tehachapi, CA
Joined Jan 2006
gorgeous wood work!!!
Old Feb 20, 2011, 11:47 AM
buckaroo is offline
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
Sweet Tag. I like your style.
buckaroo is offline Find More Posts by buckaroo
Old Feb 21, 2011, 10:24 PM
Joined Dec 2005
Just curious but what is that second smaller black wire on the Turnigy 120A ESC? I'm guessing its some kind of spark protection...right? Does it connect right up to the negative terminal like any lower rated ESC?
Old Feb 23, 2011, 02:39 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Stupid question:
Can one of these (yellow Aircraft Mako F16) be pushed around by the KL Combo? (What I'm calling it Knifes fan find)
Seems simple seeing the AUW is 11-14pds but you never know...may not fit or something...maybe brakets for only stumaxes etc.
Never thought of flying one of these cause the power systems were out of my price range and even if I could afford 6 of the other fans the pds per amp seemed like battery busters. Now with the KL combo throwing out 15pds at 100amps on 12s I can use any of my batteries to push this jet around all day from my 2200s 30c (6x4s..2200\30c) to 5k 30cs if I wanted to.
Seems worth it to save up some cheddar or make room for it if this fan combo has enough push for that F16....
Thx for any input
erh7771 is online now Find More Posts by erh7771
Old Feb 24, 2011, 09:51 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yes it's for spark protection. When hooking up the lipos you connect the pos lead first then hook up the small black lead to the neg side and you'll hear the esc arm itself the hook up the main neg lead and you'll have no spark. Works great.
Old Feb 24, 2011, 11:21 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
The combo should work well in the Yellow F-16. I'm sure it will fit. I think I've seen some flown with 120mm fans and on less power than what we are doing here I say go for it.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
