Old Jan 30, 2011, 08:53 PM
Designer/Scratch Builder
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
The HW730 rotor on 12S 3700mah pack (70-80% charge) delivers 2279watts (53amps @ 43volts (46.8 static)). This was without an intake lip or exhaust. I like the low current draw.
Time for a test mule
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 31, 2011, 04:23 AM
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
This was with a 880Kv motor? Amps are so low that you could possibly use the 1100Kv motor as well for higher performance.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jan 31, 2011, 04:16 PM
Kevin Cox's Avatar
Joined Jan 1997
Yes, it is 880kV. I was thinking in terms of a twin powered by a single 12s 5000mah pack or a single fan powered by 2600 or 3000mah pack.
Old Feb 01, 2011, 04:45 AM
PH.D in Scratchbuilding
Copenhagen, Denmark
Joined Sep 2005
Should get a shipment with 12s 5000 Nanotech this week..... then I just have to make the exhaust duct for the Savex F-16.....
Setup will be Hayoe 4.5'' with std. rotor, Scorpion 4035-560, Turnigy superbrain 100 amp, 12s 5000 Nanotech.
I'll get back when I have the test result....
jweber009 is offline Find More Posts by jweber009
Old Feb 04, 2011, 11:32 PM
that's how i roll!!
parkfly27's Avatar
United States, NM, Las Cruces
Joined Feb 2008
hi everyone,
I just picked up the haoye 5-inch fan at a fly-in last weekend, and i'm hoping to use it with the 880K/V turnigy heli motor on 10S. Do you think this is too much for the motor? I'd like to keep the amps not more than 100-120 so i can use the 5000 packs i have. From reading this thread it seems like the motor should handle it, but i'd still like to see what the experts think. The fan will (eventually) be going in a byron f-16 i am re-furbishing.
Thanks!!
parkfly27 is offline Find More Posts by parkfly27
Old Feb 04, 2011, 11:36 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
hey man! long time no see. been a couple years eh ( i used to come out and watch you and the other guys fly at the school when i was there for work..)
well, depends what rotor....presonally....the stock hoaye 5" rotor is going to be a whole lot of load for the 880.. even on 10s. you may want to try a turbax rotor, that would keep you around 95-100A. the stock hoaye 5" rotor is going to be a solid 130A on 10s, with good strong packs..
corsair nut is offline Find More Posts by corsair nut
Old Feb 05, 2011, 07:39 AM
Keith T Sr.
United States, NM, Portales
Joined Feb 2010
There is a thread on the Haoye fans with the Turbax rotor. http://www.rcgroups.com/forums/showthread.php?t=1324088 I don't know if I did that right. From what I have been playing with I think you'll smoke the motor with that rotor.
KT
keithtsr is offline Find More Posts by keithtsr
Old Feb 05, 2011, 08:00 AM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
KT
KT, this is that thread.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Feb 05, 2011, 08:18 AM
Keith T Sr.
Joined Feb 2010
Sorry Lee, I think my brain is frozen still and I stink at computers!!
Old Feb 05, 2011, 10:07 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
LOL, no prob.
Old Feb 05, 2011, 11:52 AM
Orange Park,FL.
Joined Aug 2007
!That was funny!
raypadro is offline Find More Posts by raypadro
Old Feb 05, 2011, 02:28 PM
that's how i roll!!
parkfly27's Avatar
Joined Feb 2008
Hey Corsair, it sure has been a while! we all really enjoyed having u. are ya going to be in the area again anytime soon?
Thanks for the help guys, sounds like the turbax rotor may be the solution, though it means more $$. I'd just like to stick with the '$70 motor and fan combo'
Do you think it would work to use the 880K/V motor with the stock 5-inch fan on 8S or 9S? I'm not trying to tear the wings off here... so i'd be happy with even 10-lbs thrust. Also the air is a bit thinner where i fly (our field is at 4000 feet ASL) so maybe the thinner air would make it suck less amps??
Thanks again; i appreciate the input.
Old Feb 09, 2011, 05:34 AM
Samjet's Avatar
Joined Mar 2010
single 90 mm 3000 watts Falcon 120
Hi Guys. What a great thread.
I have ordered all the parts for the hayoe fan with turbax rotor but I am still waiting for them to arrive.
One thing I still need to order is the 6 mm shaft which used to be available at EJF.com. Does anybody know where to get one?
Another question:
I already have a het 9305 90 mm fan with a arc 36-75-1.5 producing around 3000-3400 watts on 12 s 5000 mah.(don't got the exact number). I am getting slightly impatient so I thought I might try this out.
Will it be able to fly my Falcon 120?
Samjet is offline Find More Posts by Samjet
Old Feb 09, 2011, 11:03 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
your talking at least a 16lbs plane ...might be a bit much . think you need 4000 watts for a Falcon 120 .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Feb 09, 2011, 11:09 AM
Samjet's Avatar
Joined Mar 2010
Thx Sally. I think you are right but it will only be temporary until I get the Haoye/turbax fan ready. I just need to know if it can get airborn with decent speed (90 mph) with my setup. Any idea if that's possible?
Does anybody know where to buy the 6 mm shaft for the turnigy 880kv motor?
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? ditchit Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
