Old Jan 25, 2011, 05:31 PM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
Thanks Lee
I am staying on this 120mm setup and the 15 pounds. I am thinking up a twin but need to get the speed controllers back in stock.
Working on the two models on the bench first.
Air Head is offline Find More Posts by Air Head
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
To me it looks like the Turnigy 4030-880 is a good choice for 12S use, and the 1100 a slightly hotter choice for 10S in the 4" fan.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jan 26, 2011, 02:17 PM
todd5 is offline
Find More Posts by todd5
todd5
chicago
Joined Feb 2010
6mm collet
just starting out will electric ducted fan, great info on this fourm, trying to order the 6mm collet but then web link on the first page wont work, if some one can repost info for the needed 6mm collet or where to get it, keep up the good work!
todd5 is offline Find More Posts by todd5
Old Jan 26, 2011, 06:26 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Very cool guys. I decided to try a Wemotec HW730 rotor in mine. What do you guys have your timing set to on the Turnigy 120A HV controller? This is my first one of these
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 26, 2011, 06:56 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I`ve been flying mine on the default settings. I`d have to check to see what those are.
An HW730 rotor? What do those cost and who has them?
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jan 27, 2011, 01:55 AM
Senior Member
Molde, Norway
Joined Jan 2001
$$$ Those are hand laid carbon fiber, and the fan has been out of production for years, I suspect Kevin has some old stock at home.
Kevin, you are cutting one down to fit a 4" shroud? That would be easy enough as the HW 730 is a 105mm fan.
Old Jan 27, 2011, 04:37 PM
Kevin Cox's Avatar
Joined Jan 1997
Thanks Knife.
You are correct Arngeir! I have 2 of them here doing nothing so I have put one to work .
I ran it up on 10S 5000s last night, no readings. Later today I will do 12s 3700mah or 4900mah.
Old Jan 27, 2011, 05:22 PM
Senior Member
Molde, Norway
Joined Jan 2001
I have one of those HW 730's myself, mine is assembeld with a Neu 1912 1/Y sitting inside, I'm thinking about trying it on my Falcon 120 as it is using the included ABS inlet lip and tailpipe, and there's room in the motortube in that fan for one of these 49mm outrunners as well so that is another possibility I might end up exploring.
Old Jan 27, 2011, 05:44 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Intresting fan. Too bad that it is out of production
Old Jan 29, 2011, 04:48 PM
ca_fingers is offline
Find More Posts by ca_fingers
Been there , Crashed that
Joined Mar 2010
hi all , im glad to see the numbers that you are getting from these fan combos. can you guys tell me if hk's measurments for these fans are accurate? im working on a haoye f18 (same as ed waldrep's) and im trying to measure if i can stuff a 4.5" in or if im limited to the 4" . thanks, sorry for the hijack.
ca_fingers is offline Find More Posts by ca_fingers
Old Jan 30, 2011, 08:20 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yes the measurements are accurate.
Old Jan 30, 2011, 02:07 PM
Joined Mar 2010
thanks alot. so your setup with the 4" fan was the 4030 1100kv and turbax rotor . did you have to beef up the motor tube on the 4" to fit the motor after boring it out?
Old Jan 30, 2011, 02:19 PM
Senior Member
Molde, Norway
Joined Jan 2001
It's a good idea to reinforce the motor mount with a plywood or fiberglass disc. If not the motor can wobble around and rub on the motor tube.
Old Jan 30, 2011, 03:30 PM
Joined Mar 2010
yeah i've got some 160g 3k carbon i can use to build up the front of the motor tube but will boring out the motor tube make it too thin to support the stators ?
Old Jan 30, 2011, 04:01 PM
Senior Member
Molde, Norway
Joined Jan 2001
No, that is ok. It's the motor mount at the front that's a bit weak.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
