Espritmodel.com Heli Air
Old Oct 20, 2010, 06:09 AM
iamzoli1's Avatar
Joined Jan 2009
looking forward on results. there are some requests on hk for a 550 kv motor for 12s maybe we see one soon.
Originally Posted by Knife Liddle View Post
I think the question is, how many watts can the motor handle. It seems to be ok at the 4kw level. With this rotor 12s would go too far I think. But with the Turbax rotor, my educated guess is that it will work. I'll have a new rotor within a week and then we'll find out for sure.
iamzoli1 is offline Find More Posts by iamzoli1
Old Oct 20, 2010, 06:19 PM
United States, VA, Suffolk
Joined Nov 2007
How would this motor do on a stock turbax?
jhaywood is offline Find More Posts by jhaywood
Old Oct 20, 2010, 06:46 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
The problem is that it wouldn't fit in a Turbax. The center body on the fan is too small. If you could buy the adapter that Scorpion sells and put a longer shaft in the motor it might work. But the long unsupported 6mm shaft might not be strong enough. The Scorpion 4035 used for the Turbax uses an 8mm shaft.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Oct 20, 2010, 09:01 PM
Joined Nov 2007
I was afraid of that. I am not too crazy about that looonngg unsupported shaft. Looks like I will be getting a Haoye fan. Should go great in a JHH A-4.
Old Oct 22, 2010, 10:19 PM
USA, GA, Marietta
Joined Oct 2000
Isn't the Turbax rotor 5mm and the Turnigy motor 6mm. I've never seen the details of the turbax rotor but are you just drilling out the adapter, or is there a simple fix?
Ric
RicVaughn is offline Find More Posts by RicVaughn
Old Oct 22, 2010, 10:34 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
The adapter that comes with the Haoye fan is for a 6mm shaft so that works perfectly with the Turnigy 4030.
The hole in the Turbax rotor is slightly larger than the shaft of the adapter so it's nessesary to use a shim on the shaft to keep the rotor centered.
I used two layers of heatshrink tubing as the shim and it worked great.
Old Oct 22, 2010, 11:45 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
huh, thats a great idea lee!
corsair nut is offline Find More Posts by corsair nut
Old Oct 23, 2010, 08:56 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
that`s an old trick from my IC days. Sometimes we would also use fuel tubing over the shaft to make a shim, that works well too if you have the right size of tubing. But the heat shrink worked very well and can be fine tuned. I didn`t try it yet, but soaking the heat shrink with a little thin ca glue maight be good too.
Old Oct 23, 2010, 09:39 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
i need to snag one of those motors before they are gone! i think this would be the perfect setup for my jhh A-4......because i only have about 10 sq in of inlet area. any ball park of the FSA on this 4.5" fan?
Old Oct 23, 2010, 09:40 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
ps...with 880 kv, you should be right about 5 kw with the turbax rotor. should get ya about 15 lbs of thrust, and 200+ eflux noooo problem..
Old Oct 23, 2010, 09:58 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Originally Posted by corsair nut View Post
ps...with 880kv, you should be right about 5 kw with the turbax rotor. should get ya about 15 lbs of thrust, and 200+ e flux noooo problem..
I`ll measure the FSA for ya Brent and let you know.
On the Turbax rotor numbers.. 5kw may be pushing the motor a bit past it`s best spot for efficiency, but I`ve had mine up to 4.5kw and the windings aren`t changing color yet
I`ll have a new rotor next week and will give it some good tests. 11s may be better for long term use, but for $32 what the heck.
I`m working on mounting the 4.5" to my Falcon and plan to fly it next weekend at a local electric event....will follow with video.
With my twin 90mm on the Falcon it weighed over 17lbs. With this set up it will be close to 13lbs, so it should be a blast to fly if I can get 13+ thrust and over 200 efflux, it will also land like a pussy cat at that weight.
Old Oct 23, 2010, 10:01 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
When I do burn one of these motors up I will rewind it and adjust the KV as needed....maybe slightly lower for 12 use.
Old Oct 23, 2010, 11:22 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
yeah, id say 850 would be optimum for 12s. 880 might be a scosh hot, would be killer in a 4" fan....hmm......
you might be right about 11s. we'll see i guess. i know that the full turbax is about 5 kw on 5000 12s with the 1527 1.5Y, and thats around 830 kv....or maybe it was 840 somethin. id have to double check.
Old Oct 23, 2010, 11:31 AM
Its a Condition not Addiction
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
I got a 630 KV hyperion motor in the 100mm Hoaye...55amps on 12s 26000 rpms, flies my 10lbs bobcat nicely for 10 mins on 5k packs with the gear hanging down..no retracts
James
lashmett75 is offline Find More Posts by lashmett75
Old Oct 23, 2010, 12:42 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Of course that`s a full size rotor. With it cut down, 12 s might be perfect.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? ditchit Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
