Old Oct 19, 2010, 04:12 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I charged up my best 5ah cells today and did a run to measure rpm and efflux speed. It was holding at about 115a on 10s. The rpm measured 25.5k and the efflux was just a shade above 165 mph. The rpm were measured with an optical tach and the efflux was checked with the newest style of airspeed unit from ET used in stand alone mode much like a HowFast.
I estimate about 3.55v per cell. That would give about 4.1kw.
With the Turbax rotor I should be able to go 12s with amps in the 110 to120 range. The rpms and efflux will be higher and the power should hit in the 4.5 to 4.7kw range.
This is going on my Falcon 120 wing for some real world testing. The AUW will be about 14lbs so if the motor dies I'll have plenty of glide to bring it home.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Oct 19, 2010, 08:40 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I also checked the thrust again and saw 13.6 lbs.
Note: Remember all of these actual numbers are with the stock Haoye rotor.
Fan and motor cost $60. The weight of the unit is 1.3lbs. Pretty
amazing in my opinion.
Old Oct 19, 2010, 08:46 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Always good to see people pushing ideas.
Very good figures (and price) as well
Lee, if you don't mind me asking, what brand packs were you using?
Not trying to bring anything down, but some of the newer technology packs might see an even higher voltage under load, thus even higher amp/thrust figures?
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Oct 19, 2010, 09:10 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Vic
No prob Vic. These are XPS 30c cells that are over a year old and haven't been treated very nicely. I can't run that many amps thru my ET unit so that's why I don't have an exact reading for the voltage.
Old Oct 19, 2010, 09:15 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
dude! didnt we talk about the cut down turbax a while back? freakin awsome!!!!!
corsair nut is online now Find More Posts by corsair nut
Old Oct 19, 2010, 09:37 PM
hoser is offline
Find More Posts by hoser
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
i love this kind of imagination, bravo!
hoser is offline Find More Posts by hoser
Old Oct 19, 2010, 09:43 PM
RicVaughn is offline
Find More Posts by RicVaughn
USA, GA, Marietta
Joined Oct 2000
Are you waiting for the tubmax rotor to cut down. I'm very interested in your project. How are you going to trim the rotor down?
Ric
RicVaughn is offline Find More Posts by RicVaughn
Old Oct 19, 2010, 09:45 PM
tehachapi, CA
Joined Jan 2006
hes already ran it with the turbax rotor i think...??? lee....chime in here buddy!
Old Oct 19, 2010, 09:46 PM
tehachapi, CA
Joined Jan 2006
oh, just re read this....i guess he hasnt ran the turbax rotor yet.....sheesh! cmon lee!
Old Oct 19, 2010, 09:55 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yep, that was in you Turbax thread, where those details are. I moved into a house in May and somehow lost my cut down Turbax rotor, but it was such a nice match for the Haoye shroud that I've been wanting to try an outrunner with it.
I thought this motor might be something to try, but I never expected it to be able to do this. It's very tight and well ballanced. It starts up very smoothly. I'm running it with the Turnigy 120a HV and it just sings at 25k rpm.
I'll admit I'm a sucker for cheap, but the cheap stuff is getting better all of the time. I'm very fired up about this combo. 13.5 lbs of thrust for less than $200 including the esc. Incredible!!!
Old Oct 19, 2010, 10:01 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
So, no I haven't run he Turbax rotor yet. But I know basicly how well it performs compared to the Haoye from those earlier tests.
Old Oct 19, 2010, 10:12 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I'll detail it for you when I do it. It's just a matter of taking an equal
amount off of each blade, the I use sand paper inside the shroud to fine tune everything. Then the rotor has to be static ballanced again.
Old Oct 20, 2010, 01:07 AM
iamzoli1 is offline
Find More Posts by iamzoli1
iamzoli1's Avatar
Joined Jan 2009
sure you thing this motor can handle 12S ?
iamzoli1 is offline Find More Posts by iamzoli1
Old Oct 20, 2010, 02:24 AM
wilerbee is offline
Find More Posts by wilerbee
Hong Kong
Joined Jan 2002
I think I know who makes the motor, and their quality is good
wilerbee is offline Find More Posts by wilerbee
Old Oct 20, 2010, 04:38 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I think the question is, how many watts can the motor handle. It seems to be ok at the 4kw level. With this rotor 12s would go too far I think. But with the Turbax rotor, my educated guess is that it will work. I'll have a new rotor within a week and then we'll find out for sure.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
