Old Oct 11, 2012, 04:50 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Originally Posted by p901P901 View Post
Has anyone used one of these fans? It seems that the flat on the motor is causing the shaft adapter to have about 0.60" runnout.
Looks like the shaft needs to be changed.
Those fans have adaptors that are known to wobble. If you do a little searching you will find much info.
scatsob is offline Find More Posts by scatsob
Old Oct 11, 2012, 05:43 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Also, running an outrunner in a plastic shroud like these without reinforcing the mounting area is VERY DANGEROUS. Please check the early part of the thread to see how to reinforce it.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Oct 11, 2012, 05:57 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Thanks Scatsob:
I had a 6mm hardened shaft that I checked with the fan and adapter. Sure enough the adapter is the culprit http://www.rcgroups.com/forums/showp...postcount=1801. Still looking for an alternative adapter without luck. It seems most use a different fan.
Thanks Knife Liddle:
I used some 5.6 oz carbon cloth for reinforcement. 2 layers of cloth on the ID of the motor tube and 4 layers across the inside of the spider. There is about a 1/8 radius of cloth that extended to the spider. Vent holes where then routed out and are smaller than the originals.
p901P901 is online now Find More Posts by p901P901
Old Oct 11, 2012, 07:21 PM
p901P901's Avatar
Joined Jan 2009
Ran it up on a 7 blade Haoye rotor and adapter. Running smooth now with 0.002" runout. Now I need to find the numbers that this produces on 10 cell. Still may go with a Turbax fan or try a CS 12 blade. I am using a YEP 120A HV controller.
Thanks all
Old Oct 12, 2012, 06:24 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Check SDSHobbys.net
http://www.sdshobby.net/Wholesale-Di...ies_c2803.html
seems like they have more shafts..
Also, to get mine running more true I held onto the outrunner and twist the shaft adapter onto the motor shaft while pressing down...seemed to work on 2 different 6mm motor shafts from the haoye fan.
Seems like if you can get the shaft adapter bottomed out it runs more true
erh7771 is online now Find More Posts by erh7771
Old Oct 12, 2012, 09:54 AM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
That's why I don't like those full length flats. I suppose rotating the adaptor did not help? Hope you find a solution & share. TIA!
Phil
ps: I'm assuming U hav the collet type?
PhilLin is offline Find More Posts by PhilLin
Old Nov 26, 2012, 08:59 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I was going to buy an expensive fan for my new purchase, but thought to myself today....why spend a ton of money when I have a 15lb thrust setup like this. I am going to install the 4.5" with the Turnigy 880 of 12s in my new used BVM MAverick.
Tumbler is online now Find More Posts by Tumbler
Old Nov 26, 2012, 10:13 PM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
Way to go, Tumbler.
Phil
Old Nov 27, 2012, 01:44 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Now we're talkin'. Show what this power system can do Brian.
Old Nov 27, 2012, 01:45 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks Phil, I'll get back to ya.
Old Nov 27, 2012, 01:55 AM
p901P901's Avatar
Joined Jan 2009
Been using my 110mm setup with George's adapter http://www.rcgroups.com/forums/showp...postcount=1206 without problems. Its uses 1100 kv turnigy motor on 8 cells. A little underpowered on 8 cells.
Old Dec 06, 2012, 12:14 PM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
I kind of went through this thread but got conflicting information, so I thought I would just ask the question directly.
I acquired an assembled:
Haoye 4" 102mm with motor adaptor.
Turnigy 4030-1100kv
Turbax rotor copy, (RC Lander 120mm rotor turned down)
CC 160HV ESC
I plan on using our AGA Power 65C 12S 3300mah
My question is, am I going to blow up this motor?
It will be installed in a VERTIGO Rebel.
wingspan100 is offline Find More Posts by wingspan100
Old Dec 06, 2012, 12:39 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I use 10-11s 25c 5000mah with that fan/motor. 11s can hit 135a
With your better lipos on 12s you could easily hit 160a or more. Too much for the stock motor to last very long. With your equipment I recommend no more than 10s unless snow is on the ground,, then maybe 11s.
Old Dec 06, 2012, 02:06 PM
Joined Nov 2007
No snow here
Old Dec 06, 2012, 03:15 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Better stick to 10s then. You could go 12s with the 880kv motor.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
