Old Sep 10, 2012, 11:19 AM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
But if you are talking about two motors on one shaft, that will change everything because the rpm will be much higher for the fan to hit 12lkw, but each motor will only carry 1/2 the load so the 880kv may be great on 14s when run in pairs. It would hit around 40k rpm. 33k takes about 6kw. If the motors will sync it might be awesome.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Sep 10, 2012, 11:22 AM
Joined Jan 2005
The twin idea is another project
This is just for the setup that was started on this thread but it seems the stock motor will pull too much current.
I think I might try the twin though it since the KV seems to be close. Perhaps a tungsten shaft?
Air Head is offline Find More Posts by Air Head
Old Sep 11, 2012, 06:55 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
The YEP 120 can easily do 140a on 12s as long as it has good airflow.
Old Sep 12, 2012, 02:49 AM
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
That car place has a esc that is 300 amps 2 150 amp esc that use the same pwm so both esc get the same synchronized spin per motor.
sikky is offline Find More Posts by sikky
Old Sep 12, 2012, 11:42 AM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
6 phase motor
Have you seen this?
Turnigy C8085 BLDC 6-Phase Dual Controller Rewind (4 min 29 sec)
Why use 2 motors when you can package all in one?
I do not think any motors are made to match. So you will have to measure winding resistance. If they do not match then you will have to rewind so you can have a matched pair.
Also see http://www.rcgroups.com/forums/showthread.php?t=746922
p901P901 is offline Find More Posts by p901P901
Old Sep 12, 2012, 05:12 PM
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
I don't think it has to 100% even to work..... One motor may pull a few more amps... but within reason.... the power both motors make would be crazy! I think losing sync on one motor would over load the other one is what needs to be looked at..
Old Sep 12, 2012, 05:42 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Wow, what a cool idea! I`ve got to play with this for sure. Another advantage for a high rpm edf motor is that not only would the amps be 1/2 for each esc, but the pwm rate would only need to be 1/2 also. PWM can be an issue with high pole count motors. Very, very interesting.
Old Sep 12, 2012, 08:25 PM
p901P901's Avatar
Joined Jan 2009
This guy knows allot about motors-- http://www.rcgroups.com/forums/showp...53&postcount=4
He says there maybe problems on start because of sync problems. But once they start the esc will sync themselves to the motors.
This would be the same if using two motors tied together. If the motors are matched then there should be no timing issues other than start.
More reading - http://www.rcgroups.com/forums/showthread.php?t=1665401 read first post. "Operation at start-up and low rpm is a bit rough yet it starts to sing above 1500 rpm or so. " He also said that he did not know the timing of the esc
Old Sep 12, 2012, 08:48 PM
p901P901's Avatar
Joined Jan 2009
Christian Lucas on rc groups has experimented with this for years. Look him up for information on 6 phase.
Old Sep 12, 2012, 10:22 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That makes sence because a motor running with a prop or rotor is constantly adjusting to different load conditions. The esc works to keep the motor running a a constant rpm based on the position of the throttle. So slight diff in the motors should be treated by the esc like any other load condition.
Old Sep 14, 2012, 05:40 PM
Joined Jan 2005
YEP 120 settings?
Hi Lee
Would you know what settings I should use?
What do you think about adding a heat sink?
Rick
Old Sep 15, 2012, 07:25 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I`ve never used the YEP with the Turnigy 4030-880 motor but it should work fine.
You need fast start which is set up in the initial programing part. Then I use auto detect for cell count. I`m using high PWM and try both 15 and 30 degree tomming.
As long as you have some cool airflow over the esc, it should be good for 5kw without an added heat sink. I`d recommend cutting the heat shrink and the label off of the existing flat heat sink for better cooling. Also I see no reason that you couldn`t leave the existing flat plate in place and then glue an aux heat sink directly to it with something like JB Weld.
Old Sep 23, 2012, 09:40 AM
Joined Jan 2005
Rotor Trim
I am about to cut down the rotors and dont know how much clearance I need.
How much gap should there be?
Thanks for the help
Rick
Old Sep 23, 2012, 10:01 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I shoot for 1/16". A little more doesn't seem to affect performance much.
Old Oct 11, 2012, 03:57 PM
p901P901's Avatar
Joined Jan 2009
Change Sun 4 blade and T600 880kv motor
Has anyone used one of these fans? It seems that the flat on the motor is causing the shaft adapter to have about 0.60" runnout.
Looks like the shaft needs to be changed.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? ditchit Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
