Old Jul 25, 2012, 11:47 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Also the adapter on the 4 blade CS 120 can be off center. If you can't get it to work, go with the Turbax rotor as shown in this thread. It will perform well and fits that shroud perfectly.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jul 26, 2012, 02:50 PM
tomp40c is offline
Find More Posts by tomp40c
Joined Jan 2011
Lee,
I haven't posted since my Hobbywing ESC burst into flamesealier this year, but now have a new HobbyKing 160 HV ESC ready to try again. I have also purchaded to Turnigy Nano 2S-5000 25-50C batteries to make up a 10s pack to test. I'll post the results.
Where is the thread you havde showing how to wind motors?
Tom
tomp40c is offline Find More Posts by tomp40c
Old Jul 26, 2012, 03:06 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
http://www.rcgroups.com/forums/showthread.php?t=1665104
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jul 27, 2012, 12:01 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Originally Posted by tomp40c View Post
Lee,
Tom
Thanks for supplying the link Mark.
Be careful with that HK 160 Tom, they develop a lot of heat on 12s so make sure it has lots of airflow. I would concider them a 120a esc.
The winding post is still a work in progress. I hope to add to it this weekend.
Old Sep 09, 2012, 03:23 PM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
30 pounds of thrust
For a 30 pound thrust setup running a 12 cell twin is there a better way to get there?
My XPS Pro lists 16 cells at 205 amps- they don't post wattage which is somewhat lacking but ill figure it at about 13000 watts.
A twin 12 cell @ 4800 watts X 2 = 9600 seems to have a huge efficiency boost and also a low cost solution.
I guess the efflux with the dynamax is going to be higher but is there soething else I am missing?
Air Head is offline Find More Posts by Air Head
Old Sep 09, 2012, 04:01 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Nope, your thinking is right on....I have a couple of haoye fans, I only need 20 lbs of thrust and it seems like going twin is better all around in regards to watts to thrust with two of them vs one..If I can do 10lbs at 60 amps on 12s then double that I can use just one 5000mah single pack
What's it going in?
erh7771 is offline Find More Posts by erh7771
Old Sep 09, 2012, 04:04 PM
Air Head is offline
Joined Jan 2005
What's it going in?
I am guessing but I think the difference is the efflux velocity??????
Old Sep 09, 2012, 04:11 PM
erh7771 is offline
Joined Nov 2005
This setup will have higher NATURAL efflux than the dynamax....
Total CFM is what's important turbine or edf...
Turbine eflux is 700 - 1200mph....there are no mach 1 retail model jets that I know of
which plane are the fans going in?
A-10?
Regards
Old Sep 09, 2012, 04:24 PM
Air Head is offline
Joined Jan 2005
I think your on target
No need spewing 1200 mph efflux on a 150 mph airframe.. Even at 200 mph we seem to be crammed into a wall as far as speed goes for our toys. I guess if I wanted a straight line speed record machine then it makes sense but what I see for the most part the efflux is not needed.
Old Sep 09, 2012, 10:20 PM
Air Head is offline
Joined Jan 2005
Motor Winding
Hi Lee
Would you know of a motor wind to keep the amperage around 120 on 12 cells with the 4030 on this setup?
Old Sep 09, 2012, 11:22 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
depends on which fan/rotor
Old Sep 10, 2012, 08:44 AM
Air Head is offline
Joined Jan 2005
Turnigy 4030-880 Outrunner/ Haoye 4.5" / Turbax rotor...15+ lbs Thrust for about $200
Its the setup in this thread.
Sorry if I missed it but spent a few hours looking through the 120 pages and did not see it.
Or perhaps a 120 amp wind for the 14 cell controller you suggested. That may give me a little more push.
Thanks Lee
Rick
Old Sep 10, 2012, 10:56 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Rick, on my 25c Turnigy cells I hit 135a on 12s(aprox 42v). On14s holding aprox 51v a kv of 750 would give about 33k rpm and 6kw, that would put you at near 120a.
Two years ago there were not any factory motors this size in the 750kv range but I think there are now. That would be cheaper than rewinding 4030s.
Old Sep 10, 2012, 11:04 AM
Air Head is offline
Joined Jan 2005
Thanks Lee but
I already have the motors
Old Sep 10, 2012, 11:10 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I'll have to go back and check my notes on turns vs KV. I get back to you. I think I started a thread on it. I'll see if I can dig it up. Seems like it was 6 turns, but I'll have to check.
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 12:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 12:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 07:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 08:44 PM
