Old Oct 17, 2010, 03:52 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Turnigy 4030-880 Outrunner/ Haoye 4.5" / Turbax rotor...15+ lbs Thrust for about $200
It's been too quiet around here so I thought I'd stir things up a bit.
This is the real deal,not a joke, but I'm not giving up the details just yet.
If someone can guess the combo, I'll come clean with pics and vid. Otherwise you'll have to wait for me to do a little more testing. Also I want to pick up some more of the parts before they all sell out.
I might be shamed into giving some hints if you know where the chinks are in my armor.
Have fun. Lee
List of videos.........
All videos are with the Turnigy 4030-880 and the Turnigy 120hv esc
Post #143 The stock Haoye fan and rotor on 10s
Post #560 Repeat of the previous video
Post #566 The Turbax rotor on 11s (temps about 45F so lipos cold)
Post #616 Turbax rotor on 12s (temp 58 F....so lipo performance was better)
The second pass was Dopplered at 165mph - tailwind = 160 airspeed
PARTS LIST
Fan Assy http://www.hobbyking.com/hobbyking/s...idProduct=4242
Motor http://www.hobbyking.com/hobbyking/s...dProduct=11143
The shaft adapter.... I use the Great Planes 6mm adapter, don`t have a link, but their part number is GPMQ4968
The rotor and spinner for the 120mm Metal EDF can be used instead of the original parts listed. These will save you $25 if you go with the least expensive shipping option.
http://parkrcmodels.com/index.php?cPath=97
100a HV ESC http://www.hobbyking.com/hobbyking/s...idProduct=4691
120a HV ESC http://www.hobbyking.com/hobbyking/s...idProduct=8921
Adding test numbers here now that the mystery is over..........
These first three test specs are with the fan as follows
Haeyo 4.5" shroud, Turbax cut down rotor to fit shroud, Turnigy 4030-880 motor and the ESC is a Turnigy 120a HV.....
10s2p 6400 XPS 30c battery fresh charge
37v
92a
3.4kw
183 mph efflux
11.5 lbs thrust
battery 11s2p 6400 XPS 30c cells fresh charge
40v
102a
4.1kw
200 mph efflux
13.5 lbs thrust
12s2p 6400 XPS 30c not recharged after 10s test (one fresh 4s added)
43.5v
110a
4.8kw
210 efflux
15.5 lbs thrust!!!
Here are the numbers with a 5" Haeyo rotor cut down to 4.5"
10s2p 6400 XPS 30c full charge
37v
120a
4.5kw
165-170 mph efflux (previous report of 200mph was wrong)
13.5 lbs thrust
Knife Liddle is offline Find More Posts by Knife Liddle
Last edited by Knife Liddle; Feb 09, 2013 at 01:04 PM. Reason: added parts list and video list
Old Oct 17, 2010, 05:00 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Is this a combo you put together, or one that comes pre installed?
Steve C
Steve C is offline Find More Posts by Steve C
Old Oct 17, 2010, 05:08 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Steve, it`s something that I put together from readily available parts.
Hint: the dia of the rotor has to be reduced a little from stock and the motor support flange of the shroud needs some simple reinforcement.
Old Oct 17, 2010, 05:10 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
It's gotta be outrunner driven, right? Maybe a Scorpion motor?
AceMigKiller is online now Find More Posts by AceMigKiller
Old Oct 17, 2010, 05:44 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
yes
no
A Scorpion capable of 4kw+ would put you way over budget.
Remember......the cost of housing + rotor + motor = right at $100 not counting shipping.
Old Oct 17, 2010, 05:54 PM
Joined Jul 2004
You use cheap-china motor???
Despite what Confucius say, it no last you long time...
But I'm willing to throw out a guess for the Haoye shroud and/or Rotor.
Old Oct 17, 2010, 05:57 PM
ICRSHLTS is offline
Find More Posts by ICRSHLTS
Two Rivers, WI
Joined Mar 2003
yeah
definitly Hoaye shroud and blue chinese motor- that's 70-75 $$$ but a good $30 rotor? HMMMMM
ICRSHLTS is offline Find More Posts by ICRSHLTS
Old Oct 17, 2010, 06:28 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
OK guys, the guts go into a 4.5" Haoye shroud.
Of course it`s a Chinese motor, but I`m telling ya. This thing is smooth and has some guts. I`ve held it at over 100a for 60 sec blasts and yes it warms up, but the windings still look like new. This is a sweet motor. I have 5 Scorpions in smaller sizes and IMHO this unit is every bit as good as a Scorpion. Yep, that`s what I said.
Also the cool thing about the outrunner is that the bearings are easy to replace and I can rewind it if it burns and can make it even better. Of course the kv can be fine tuned also.
Old Oct 17, 2010, 06:29 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
oh, the motor isn`t blue.
and the rotor isn`t from Haoye
Old Oct 17, 2010, 06:36 PM
ICRSHLTS is offline
Two Rivers, WI
Joined Mar 2003
rotor
Oh the rotor is turbax cut down too right?
$40 rotor
$28 fan
wow that's a cheap motor
Old Oct 17, 2010, 07:03 PM
Terryoc is offline
Find More Posts by Terryoc
Melbourne Australia
Joined May 2003
Is the motor a red Turnigy Heli motor.
I have one in a 4" Hayoe on 10s 80 amp 3000 watt 9 pound thrust 100% fan area out let
Terryoc is offline Find More Posts by Terryoc
Old Oct 17, 2010, 07:19 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Ok
It`s the Haoye 4.5" shroud
The rotor will be a Turbax cut down to fit (I lost my first one while moving) using the Haoye right now
The motor is a Turnigy (red) Heli motor. Size 4030, kv is 880, 6mm shaft
Right now I`m running it on 10s to keep the amps down to 110. With the Turbax rotor, I`ll be able to go 12s and the amps will stay in the area of 110.
I took a video of a 30sec run at over 100amps. I`m putting it on you tube. I`ll post a link when it`s ready.
Old Oct 17, 2010, 07:25 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
bench run vid
here`s a bench run of 30s over 100a
pretty impressive I think
this was on 10s but the cells were not fully charged
the white plastic shroud was just to hide the color of the motor
Q-2.6 181.mov (0 min 48 sec)
Old Oct 17, 2010, 07:29 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
here`s a pic of the motor
Old Oct 17, 2010, 07:33 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
here`s what the fan looks like with the Turbax rotor in it
For Sale ducted fan/motor combo bucsbw Aircraft - Electric - Power Systems (FS/W) 1 Aug 06, 2011 01:09 PM
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 10:59 PM
Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Sep 12, 2010 01:50 PM
Discussion Lost over 90mm Midi Fan and Motor combo??? bri6672 Electric Ducted Fan Jet Talk 18 Jan 21, 2010 08:51 PM
Discussion 1.4KW+ motor for 6S on 70mm fan? DominicM Electric Ducted Fan Jet Talk 71 Aug 23, 2009 09:44 PM
