Espritmodel.com Heli Air
This thread is privately moderated by I R Irv, who may elect to delete unwanted replies.
Old Oct 17, 2010, 02:41 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Elevon Sumo
3mm depron,26.67g, 12'' WS, AR6400L, AS2000L servo, 4-Site motor and prop,Mustang GB, 120 or 180 hyperion lipo
I R Irv is offline Find More Posts by I R Irv
Old Oct 24, 2010, 06:35 PM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
very nice
so the AR6400 onboard servos are controlling one elevon and rudder, and the external servo is picking up the other elevon?
Originally Posted by I R Irv View Post
3mm depron, 12'' WS, AR6400, AS2000 servo, 4-Site motor and prop, 120 or 180 hyperion lipo
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Oct 24, 2010, 07:21 PM
I R Irv's Avatar
Joined Nov 2008
Originally Posted by Razors edge 29 View Post
very nice
Yes with the RX on the bottom (backwards) servo gears facing the tail and external servo mounted on top (normal) servo gears facing nose. If you use the 6I set it to elevons and for full throws you set it
MIX 1
AILE > AILE ACT
RATE L +100% R +100%
SW ON TRIM ACT
MIX2 do the same but Elevator These two mix's give you about twice the throws.
Old Oct 24, 2010, 08:58 PM
Canada
Joined Aug 2009
thanks
do you have plans by chance or even vids of this gem in action?
MIX 1
AILE > AILE ACT
SW ON TRIM ACT
Discussion Newbie would like Elevon mixing advice paulregret Slope 28 Oct 28, 2010 03:43 PM
Discussion Newbie needs advice on Elevon mixing paulregret Beginner Training Area (Aircraft-Electric) 2 Oct 12, 2010 04:29 AM
Question Tactic TTX400 FM - Does it have elevon mixing? dezerteagle323 Radios 5 Sep 18, 2010 09:59 AM
Discussion Q's about elevon mixing and VT-mixing Raidenflight Electric Ducted Fan Jet Talk 5 Sep 16, 2010 02:09 PM
Discussion Hanger 9 F22 full throttle dive, elevon failure = new hole in the lawn. bastian74 Fuel Plane Talk 1 Sep 13, 2010 08:01 AM
