Old Oct 17, 2010, 08:36 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
Build Log
Mini Canberra bomber
Pusher prop jet models donít seem to be quite as popular as they were a few years back when jetset44 started pumping out designs for park jets. But I still like them. In the case of the plane Iím about to start building, I donít have much choice because they donít make a 25mm dia fan.
Iíve drawn up plans for a 55cm (22Ē) English Electric Canberra bomber. It was also built in the US as the B-57. The target weight is 110g (4oz), so itís a calm weather park flier.
My first thought was to build it from Durabatics foam, but when I went to order some I found that the guy who makes it had passed away. So then I thought of 1mm depron, but you canít buy it in Australia, so I decided to make my own by taking 2mm depron and shaving one side away. It means there is only one skin, so its not nearly as stiff, but I hope it will work OK.
I used my electric planer set to a cut depth of 0.7mm. Then I finished it with an orbital sander with 80 grit paper. I tested the planer on a piece of scrap 6mm, because I didnít know what it would do. I thought it might ingest the whole sheet like a mulcher, but it worked OK. The planer makes a bit of a mess, so itís a good thing I did it outside. The finish was a little rough but the sander smoothed it out. I could have done the whole job with the sander but it would have been too hard to maintain a consistent thickness. I donít know if anyone else has tried shaving down depron.
Scaledown is offline Find More Posts by Scaledown
Old Oct 24, 2010, 06:16 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
G'day Scalemeister,
good to see another project on the bench.
I'm subscribed of course.
Still scratching away at the Mavis (what a job it turned into) multi's seem to take forever.
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Oct 24, 2010, 07:29 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
I agree on scratch built foams.
I use 4' long sanding boards. 1 has 33 grit & the other is 80 grit. I also made 2 round closet poles into sanding boards for the inside curves.
I found the high humidity is my friend.
I did 1 day on a 20% humidity. HA HA HA. " It is the Michilen tire man. "
cyclops2 is offline Find More Posts by cyclops2
Old Oct 27, 2010, 07:38 AM
Scaledown's Avatar
Joined Sep 2004
Hi Phil
Agree with you about multis. This will be my last for a while. At least its a simple build.
cyclops2
4' sanding board? That would take a bit of effort to use I expect. That's a nice collection of planes you have there.
I've attached a pic of the wings under construction, ready for the top skin.
I've designed it for positive Gs by gluing a single kevlar thread to the bottom skin (for tension) and a 2mm square balsa spar under the top skin to stop it from buckling in compression. Most of the ribs are balsa because foam is too flexible at that size.
Old Oct 30, 2010, 08:14 AM
Scaledown's Avatar
Joined Sep 2004
The top skins are on. To get the right amount of washout as the skins glue, I twisted the building board. The board was a piece of 3mm MDF. By stapling three corners down and chocking up the fourth corner I was able to get the washout exactly the same on both wings. I've given it a fair bit of washout on the outer panels because there's quite a bit of taper in the wing plan.
I'm going to use the boiling water method to curve the foam for the fuselage and engine nacelles. The rear fuselage and parts of the nacelles will be tapered tubes, so I carved a mould with the correct taper out of blue foam, and I'll be wrapping the foam around this in the water.
Old Nov 03, 2010, 07:20 AM
Scaledown's Avatar
Joined Sep 2004
I've hinged the ailerons, carved some wing tips and joined the wings. I've used 1mm carbon torque rods. Hopefully they are not too flexible for the job. I just made the motor mounts. I hope to get a bit of cooling air passing through the nacelles.
The motors are 5 gram Hextronic 2000kv units, driving 4x2.5 GWS props. The speedies are Castle Creations Thunderbird 6.
Old Nov 07, 2010, 04:04 AM
Scaledown's Avatar
Joined Sep 2004
I've been working on the engines. I found when I curved the 1mm sheet in the boiling water, it had much more springback than normal depron with both skins. So I tried curving it around a smaller diameter tube first, then the correct diameter and the springback was much reduced. Maybe I was breaking the grain more with the smaller diameter.
You can see in the pic I glued some balsa strips to the edges. These act as handles so I can pull the sheet evenly and tightly around the mould (in this case a wooden dowel) without needing 13 fingers. I always cut the piece oversize then trim it down later, because the edges can swell and warp a little.
The pics give a good idea of the size of the plane now.
Old Nov 07, 2010, 07:44 AM
Registerd Beaver
Joined Jul 2003
That's quite a job there & came out very nice.
So the air/jet pipe duct goes over & under the wing skin to cool the motor?
This model looks like it will really fly well - lots of wing, lots of power...
Old Nov 07, 2010, 07:58 AM
ToxicToast is offline
Find More Posts by ToxicToast
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Looking forward to seeing how this one turns out!
ToxicToast is offline Find More Posts by ToxicToast
Old Nov 08, 2010, 05:56 AM
Scaledown's Avatar
Joined Sep 2004
That's the plan Phil. Normally I would include a former or two, but I can't in this case because it would block the flow. I was thinking of putting the ESC in the tube for cooling but it won't fit.
Old Nov 09, 2010, 05:00 AM
Scaledown's Avatar
Joined Sep 2004
The engines have been sanded to a smooth curve now. Later I will apply some lightweight spackle to the sanded areas (where the skin is now gone) to fill the pores before I paint it. I'll also be adding some paper tailpipes to hide the motors. I've run the motor wires through the wings to the motor mounts already. I used enamelled wire to save weight.
Now its time to build a fuselage.
Old Nov 14, 2010, 08:07 AM
Scaledown's Avatar
Joined Sep 2004
The fuse is coming together with pre-curved pieces. Things are beginning to go wrong now. I messed up a measurement when assembling the fuselage. "Measure twice - cut once!" Now I have an extra construction joint that I didn't intend. Then when I installed the control horns onto the aileron torque rods, I discovered that the carbon torque rods are way too flexible. The ailerons were just flopping around. Its probably unflyable. I've started extracting the rods to replace them with steel - not easy without butchering the wing, and I wanted to avoid the weight of steel anyway.
Come to think of it, I had the same problem with another plane a few years ago. You would think I'd learn.
Let the word go out around the world from this day onwards:
NEVER USE CARBON RODS AS TORQUE RODS!
You can see in one of the pics that I reinforced the fuselage near the wing leading edge with some bits of carbon, and some balsa strip. This is because if I have a hard landing (inevitable) the biggest stress will be at this point, trying to break the nose off in front of the wing.
Old Nov 14, 2010, 10:16 AM
kestrel2003 is offline
Find More Posts by kestrel2003
No Guts No Glory
kestrel2003's Avatar
Switzerland
Joined Feb 2003
Looking forwared to see it fly!
Always nice to see a canberra beeing built. Looks realy nice to far. Any idea on the finish? A black night intruder, a sand color recon version or a silver finish? rgds mv
kestrel2003 is offline Find More Posts by kestrel2003
Old Nov 17, 2010, 04:10 AM
Scaledown's Avatar
Joined Sep 2004
At the moment I'm leaning towards the RAAF scheme. Black looks cool, but it might be hard to pick its orientation at a distance. I've got a heap of silver planes already. I must say yours looks nice.
Old Nov 17, 2010, 11:00 AM
No Guts No Glory
Switzerland
Joined Feb 2003
Raspberry ripple
I may try building a 1m span baby canberra, impeller not pusher. If I do the its raspberry ripple time. I have a weakness for target tugs. Looking forwared to see yours.
Discussion Canberra Slopes... (details on local slopes & general flying in the Canberra region) glydr Australia 766 Jul 04, 2016 12:26 AM
Sold Scratch built Arado 234 WWII German Bomber rcdude01 Aircraft - Electric - Airplanes (FS/W) 8 Oct 15, 2010 12:58 PM
Cool Canberra Chopfest this weekend glydr Australia 6 Sep 24, 2010 05:58 PM
Question 320sq in 1/2A Lanzo Bomber udlman Vintage & Old-Timer Designs 7 Sep 05, 2010 08:56 AM
