| Wingspan: | 27.6" / 700mm |
| Wing Area: | 105.5 sq. in. / 6.66 |
| Weight: | 9 oz. / 259g |
| Length: | x22.24" / 565mm |
| Wing Loading: | 12.52 oz/sq. ft. / 389 g/sq. dm. |
| Servos: | KS-21 5g |
| Transmitter: | KT-1 4-channel 2.4 GHZ with Dual Rate Switch |
| Receiver: | 6 channel PERFEX 2.4 GHz |
| Battery: | 450 - 750 mAh 7.4 V LiPo |
| Motor: | AF 400 BLS B/07/15 Brushless |
| ESC: | 10 amp programmable |
| Manufacturer: | Kyosho Corporation |
| Available From: | Hobby Lobby |
| MSRP: | $99 PIP / $129 ARF with Tx and Rx |
Since 1963, Kyosho’s first year of production, the company has continuously provided this hobby with R/C cars, and later, planes, helicopters, boats and robots. They have been innovators in molding, die-casting and manufacturing for nearly 50 years. I have personally known and flown or raced their products for about thirty of those years.
Check out the Kyosho.com website to see the scope of their product line.
I am excited to see Hobby Lobby is now distributing this lineup. It's the coupling of a great company, with a great product.
The aiRium Cessna 182 Skylane is a three channel high-wing airplane with elevator, rudder and throttle control in 1:14 scale. The wing is made of Styrene and the fuselage is foam. The transmitter provided has a dual rate switch moving from 100% to 70% with a quick flip of the switch. The nose wheel is steerable and both the nose wheel and the rudder come channeled to channel 1 or the aileron channel. The Skylane is available in red and blue and comes in a plug and play version allowing you to use your own electronics.
This is a tidy little package. It comes with a carry handle ready to take to your local park or flying field. Components are nestled into foam compartments. With the exception of removing the wing struts, the Cessna 182 Skylane, easy packs up for transport. This is a 2.4 GHz system fully ready to fly with everything you need in one box.
Kit includes:
Kit Requires:
The packaging is good with bubble wrap here and there to ensure you get the product in one piece.
This is, for all practical purposes, an RTF. Other than adding the wing, struts and landing gear, the work is done for you. I would say that it takes maybe an hour to get up and ready to fly. The control horns are pre-installed, too. The instruction manual is written in five languages and is as detailed as one can get. Pictures, schematics and text are all provided.
The wing is a very simple attachment idea that avoids the use of wing bolts and exterior rubber bands. Inside the fuselage is a hook. A small O-ring is provided that attaches to the underside attachment point on the wing. Using a small bent wire tool (provided), you reach up through the bottom of the fuselage and hook the O-ring inside the fuselage. A forward mounting pin centers the wing and once the O-ring is attached the wing settles into the saddle very well.
Don't let the pictures on the website fool you; they show the rubber bands crossing over the wing. This version uses the unexposed O-ring attachment that is very solid.
The tail is completely installed, but I would recommend taking the linkages off and exercising the hinges. This will make the servos work easier and give you more movement when you want to switch to a high rate.
Everything is installed using a 2.4 GHz system, and mine came bound. The transmitter uses slider trims and includes a dual rate switch on the front. The sticks felt fine, and because the system cam bound, I had no problem using the transmitter. I never lost the bind, and the ESC always armed as it should. The right aileron stick is set-up to control flight direction, but for some this may require you to move this to channel 3 using the rudder stick on the left. Configure as best suits your needs, but I would say for a beginner pilot I would definitely make the switch to channel 3. As an experienced pilot, you have to be careful , to avoid over controlling the rudder. While those of us that fly a lot know we can throw in full aileron with little chance of a stall, generally speaking to do the same with the rudder is s recipe for a stall-spin.
The proprietary KT-21 transmitter has a few limitations. \Kyosho indicates no more than 15 planes flying in the vicinity on 2.4 GHz, and the range is 150M over land and 200M in the air. As with most 2.4 GHz transmitters they recommend the antennae be angled 90 degrees.
Binding uses a bind plug. Simply install the bind plug into the identified channel, power the Rx through your ESC and then turn on the Tx while pressing the bind button on the Tx. The green light will indicate the bind is successful.
Final preparation for flight requires the installation of the landing gear and wing struts. Both the wing struts and the main gear have fairing silhouettes. The main gear fairing snaps in place.
Elevator
!Flying
The Cessna 182 has plenty of power. The AF 400 BLS B/07/15 brushless motor will get you into the air and move you around with ease. The plane is small, so assuming scale-like performance would be an odd statement. It does fly smoothly and control is exceptional. The color scheme is beautiful right down to the wheel pants. The range of the 2.4 GHz radio system far exceeds your ability to see the little Cessna.
The Cessna is advertised as a beginner to intermediate flight capable aircraft. In the air with normal control inputs the Cessna 182 Skylane performs like a pussy cat. At half throttle it flies level and will turn easily, loop (more throttle) and can even roll. So once off the ground, with gentle inputs, the plane flies as one would expect.
But, if you slow down a bit and forgot you are turning with your rudder the plane will snap over very quickly. I got low and slow and flying as if I was only controlling the ailerons and I snapped it right over. I was in tall grass so I had no damage, but this is where we have to determine how we will fly the plane.
As a beginner setup the plane let the left stick fly the rudder. This is good practice and with some help you will soon learn to fly the pattern and then some. When proficient, switch to the aileron channel. For those of you flying with some skills just use caution if you have the rudder setup on channel 1. The rudder is just not a good tool for getting yourself out of trouble.
I found several batteries that fit into the compartment ranging from 450 to 750 mAh. The flight times were excellent with ten minutes of flight coming pretty easy. Throttle management is more scalelike as you will not want to just firewall it all the time. Enjoy the pretty plane as it passes by.
The Cessna really needs a smooth surface to operate both landing and takeoffs. Hand launching is easy, but landing requires something smooth. If you do mostly hand launch, remove the main gear and the nose gear.
The takeoff roll is not that easy to control, and the torque moves the plane right, because it is so light. One might assume the torque would cause it to turn left. Such a light plane with pretty quick controls is hard to keep straight. If you fly from a parking lot, no problem, but you will have a little learning curve on the runway. Just be gentle on the throttle and rudder inputs.
The landings are predictable and the glide slope to the runway is really very good. Keep the nose up and land on the mains and very gently let the nose down. This is very difficult to do in a small plane, especially for a beginner, and still not so easy for an intermediate pilot. I had problems on my runway with the plane nosing over as I landed. I tried over and over and still ended up with the same results. I think on a smooth surface this is not as much of a problem. Overall, I thought the best flying was with a hand launch and with the wheels removed.
I thought the plane was smooth with power. It will loop and roll and can fly inverted. The power curve is excellent. This is not really intended to be an aerobatic plane.
If you are a beginner, hand launch and keep some power on and you will enjoy the plane’s flight characteristics. If you have some experience you too will like the flying the little plane and learning the takeoffs and landings. The dual rates are fun to work with and give you some more aerobatic movement.
Kyosho has produced a great little Cessna 182 Skylane. I would say most of you will like flying the plane and will respect what it is capable of doing both on the positive and negative sides of the flight envelope. I think the looks are outstanding, but the functionality requires a mating to the correct runway surface. Frankly, I was surprised I was not able to control the noseover’s on my limestone runway. I was also surprised I could induce a snap roll so quickly. I was frustrated with myself, but have to wonder if I fly pretty good how will others respond in the same situation. One just has to be aware.
As a final suggestion, one can also reduce the throw of the rudder through the linkages. You really do not need much to fly the Cessna so set the throw as low as you think you can go as you always have the dual rate switch to increase the movement when you need it.
The Good:
The Not-So-Good:
| Thread Tools |
Thanks for the prompt reply Dave. I had assumed the fuselage's O ring retainer was something glued and or screwed into the foam.
![]() I think I may be ordering the PNP version since I have extra AR6110 receivers and have no need for an extra radio. Hopefully the 6110 will fit in the receiver opening. ![]() Bert |
I think the O-Ring for the wing is the same as the P-40 setup-----limited access but it comes with a neat tool to install it...pretty easy in my opinion. Ive had the P-40 for over a year now with no issues....still looks and flys like new. I plan on ordering this cessna today! Looks like a great plane.
" I had problems on my runway with the plane nosing over as I landed. I tried over and over and still ended up with the same results. I think on a smooth surface this is not as much of a problem. Overall, I thought the best flying was with a hand launch and with the wheels removed."
You must have meant to say that the wheel pants should be removed, and leave the wheels on. |
I have no clue as to what's happening at Hobby Lobby. I have tried to get this model, and in all its incarnations, be it RTF or PNP the page lists it as discontinued. Even the link provided in this review takes me to the same "discontinued model".
![]() Status: Discontinued Product#: KYO932RSB Was: $269.99 Price:$129.99 Status: Discontinued Product#: KYO932RBR Was: $206.99 Price:$99.99 They also show other "similar" models that use a wire type landing gear, but are listed as discontinued as well. All show this plane with what appears to be a 72MHz transmitter. ![]() I did a search using the description given here: "Kyosho aiRium Cessna 182 RTF" (http://search2.hobby-lobby.com/psear...ode=any&page=1) and come with 16 pages of everything and the discontinued planes listed above, all of them listed as DISCONTINUED. ![]() I have just about given up on Hobby Lobby a few months back. I have a notion I will not bother with them anymore since they are not the company they once were. Their web page is nightmarish to navigate since they decided to "improve it" a couple of years back. Even friends of mine who live in their immediate vicinity (within a 30 minute drive of their shop) tell me the same thing.
Hey guys,
Wanted to explain a little bit about what's going on here. We went with the Kyosho planes because we were able to offer them at price points that have never been available before. These simply didn't sell well enough to continue stocking. Quite frankly, we need the warehouse space for products that people are going to purchase. So we move these out a great discount and make room for other stuff. Any Kyosho planes that sell at a reasonable rate, we will continue to offer and support. Side note about a previous comment. We're real people here guys trying to run a business and support our customers as best we can. I think our website is awesome right now. If you haven't looked at it in the last few months, it's completely different than the 1st time we "improved" it. Yes that was a hard transition and yes the navigation was terrible, but we had to move forward with technology that benefits everyone. We're still tweaking it and always will be, but the navigation right now is awesome. It's so easy to find what your looking for. We're improving, but at the same time, we haven't changed our commitment to our customers and our service. We want to earn your business and I feel we're in a good place to do that right now. ok, off of soap box I go.... Jason |
| Thread Tools | |
| For Sale Kyosho Cessna 182 Super Quality Series- 62" NIB ARF | topher39 | Aircraft - Fuel - Airplanes (FS/W) | 4 | Oct 20, 2010 05:44 AM |
| Sold 62" Kyosho Cessna 182 Skylane to Convert to E-power | topher39 | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 12, 2010 10:39 AM |
| Sold Kyosho Cessna 182 Super Quality Series- 62" NIB ARF | topher39 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Oct 11, 2010 01:34 PM |
| Sold Kyosho Cessna 182 Super Quality Series- 62" NIB ARF | topher39 | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 11, 2010 01:33 PM |
| Sold 62" Span Kyosho Cessna Skylane 182 | topher39 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Oct 08, 2010 02:42 PM |
