This thread is privately moderated by troynh, who may elect to delete unwanted replies.
Old Nov 21, 2010, 02:13 PM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Capt, Move your EPA all the way up on all channels to 125%. I love how Alex programmed the arming & disarming of the motors. (Right for on - Left for off)
Also, don't forget to calibrate the neutral position of the gyros before flying. First tilt the yaw stick left, move the pitch stick down while having the throttle stick all the way down too. Watch for the green LED to blink a few times. When it stops blinking, you're done.
troynh is offline Find More Posts by troynh
Old Nov 21, 2010, 06:09 PM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Test flight in the garage went well! Wish it was not blowing snow and windy so I could fly it outside but that will have to wait.
I will calibrate the gyro's also as I haven't done that yet.
Troy how do you use the GUI to change PID settings? I can't seem to change any settings on it.
capt is offline Find More Posts by capt
Old Nov 21, 2010, 07:16 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
You'll want to calibrate the Wii before every flight. Takes less than 2 seconds.
To change the PID values, place your mouse in the numerical box, click and hold the mouse and the drag it left or right. this will increase or decrease the settings. (This function isn't well documented...)
Old Nov 21, 2010, 08:47 PM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
Ah Ha! I was using a laptop with out a mouse so it was a little awkward, thanks.
Old Nov 25, 2010, 10:19 AM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
Just test flew my Wii copter @ -6C/20F dead calm wind, Awesome! only tweaked my TX expo a little and it is very stable. Fingers gave out before the 2200Mah battery did.
Happy Thanksgiving
Old Nov 25, 2010, 11:29 AM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Great job capt!
Happy Thanksgiving.
-Tim
Old Nov 27, 2010, 04:08 PM
CoastalTom is offline
Find More Posts by CoastalTom
United States, AL, Foley
Joined Nov 2005
OK guys, I finally got my Tri-Wii wired and running (no flight yet).
However, the Wii+ gyro is reversed in pitch mode (elevator works correctly via stick)
How do I reverse the gyro for pitch?
Tom
CoastalTom is offline Find More Posts by CoastalTom
Old Nov 27, 2010, 04:31 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Tom,
Dumb question.... Do you have the wii board right side up and facing the correct direction?
(See Alex's picture and note the blue arrow and the top of the wii board.)
Old Nov 27, 2010, 06:45 PM
Joined Nov 2005
Mine was a dumb question, not yours!
Nope, my wii board IS upside down. Guess I thought it didn't matter and could be changed by software or TX.
Thanks Troy! I'll keep ya'll posted on progress.
Old Nov 28, 2010, 11:39 AM
power is online now
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Hold the bus guys!!!
I am confizzeled capts post above (#92) shows the wii board mounted upside down. He says it flys fine...
Another question....I am thinking about leaving the plug attached to the board like capt did. I noticed that two of the pins on the underside are actually soldered together. Far right pegs in pic.
Could someone tell me if this going to be an issue? I see most of the setups dont have solder between the two
power is online now Find More Posts by power
Old Nov 28, 2010, 12:36 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Mike,
The white plug side of the Wii must be face down and oriented in the same direction as Alex has in his diagram. You can visually test through the Wii GUI by holding and moving the wii in your hand. Pitch, Roll, Yaw. Capt is going to have to respond on how he got his to work that way... Who knows, I could be completely wrong...
These are the only wires that you need to know about when building a Tricopter config. (Black & Blue are both grounds...)
GRAY (Sometimes Brown) - GOES TO PIN D12
RED - GOES TO PIN A5
WHITE - (Sometimes Orange)
YELLOW
GREEN - GOES TO PIN A4
BLUE - GOES TO GROUND
BLACK
Here is the wiring from the Arduino pins to your Receiver:
Pin 2 goes to CH 3 on the receiver
Pin 4 goes to CH 1 on the receiver
Pin 5 goes to CH 2 on the receiver
Pin 6 goes to CH 4 on the receiver
Old Nov 28, 2010, 06:39 PM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
I had to reverse a channel (roll I think), I was to lazy to undo everything and flip it after we relized it was backwards.
Will probably fix it after I get my WMP clone board.
Old Nov 28, 2010, 07:12 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Well, There you go.
Old Dec 02, 2010, 09:38 PM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
excellent project.. read through the whole thead.. don't see any mention of the tx radio setup..heli or acro?? if heli what swash mix,gyro settimg, pitch, thro curve?? if plane mode..anything special??
barok is offline Find More Posts by barok
Old Dec 03, 2010, 08:04 AM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
barok,
Any 4 ch radio can be used as it sets up as ACRO. Alex's Wii sketch does all the mixing, etc.... And his Wii GUI is where you can make your adjustments. http://radio-commande.com/internatio...copter-design/
-Tim
New Product Flytron Lay-Z (Wii Nunchuck Remote Control) MelihK FPV Talk 65 Jun 18, 2014 10:33 AM
Discussion Wii motion plus, Flybarless stabilazion for Heli. NighthawkF-117 DIY Electronics 7 Sep 10, 2010 11:29 AM
Wanted Trade T-Rex 450SE V2 for/towards Wii 500Driver Non R/C Items (FS/W) 2 May 06, 2009 10:47 PM
For Sale Wii Games, Accesories, Harley T-shirt, OBD II Scanner, Multiscope,+ Weather Stations Etonic Non R/C Items (FS/W) 5 Feb 03, 2009 02:00 AM
For Sale Wii Console w/Wii Fit, 4 controllers, 7 retail games rz22g Non R/C Items (FS/W) 0 Oct 31, 2008 04:13 PM
