This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Oct 16, 2010, 06:52 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
P-47 Jug: The JUG's Tail Feathers.
UP-DATE 2/13/2011: Got back on the JUG this past week, and got some work done on the 'ole girl's Tail Feathers!
I cut the control surfaces in preparation of re-hinging both the elevator and rudder. But first I needed to install a spar so I routered a groove to install the .220 x .092 flat CF. I glued the spar in with GG, and once cured, I filled with Squadron putty and sanded smooth.
Once the spar was done I started on the hinging. I used some pivot point hinges on the rudder, and some of these Super Lite hinges from HK. This is the first time I have used these, but I must say I do like their concept. They slip in just like a regular pinned or CA hinge. They have a dam which keeps the CA from getting on the pivot section, and were easy to install.
After getting the hinging done, I set out to install the .092 joiner rod on the two control surfaces to eliminate the dual push rod set-up.
Sandancer is offline Find More Posts by Sandancer
Old Feb 25, 2011, 09:05 AM
rickfe101 is offline
Find More Posts by rickfe101
United States, FL, Fort Lauderdale
Joined Jan 2011
Where did you get the joiner rod?
rickfe101 is offline Find More Posts by rickfe101
Old Mar 27, 2011, 09:07 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
I make my own out of .092 piano wire.
