Old Oct 06, 2001, 09:31 AM
leftysdeceiver is offline
Find More Posts by leftysdeceiver
Joined Jan 2001
How to estimate CG on a Delta wing
Can anyone give me a ballpark for determining the CG on a triangular delta?
I have a model balanced at about 43.75% of the root chord and it seems unstable but does fly. I'm thinking that it may need to be about 50-55%. Any ideas?
Lefty
leftysdeceiver is offline Find More Posts by leftysdeceiver
Old Oct 06, 2001, 11:46 AM
rkrishnan is offline
Find More Posts by rkrishnan
Schaumburg,Il,USA
Joined Apr 2001
Lefty,
I think it's more like 27%. For the Mugi and the Pibros, which both are 800mm span, 400 mm length plain deltas with 0 tip chord, the reccomended C.G.s are at 205 & 210 mm from the nose.
There's a good C.G. Calculator at:
http://ourworld.compuserve.com/homep...le/page17.html
I've verified this with both models and it works out fine as a starting point.
Tell us more about your Delta!
rkrishnan is offline Find More Posts by rkrishnan
Old Oct 06, 2001, 01:46 PM
Joined Jan 2001
I'll check out the calculator. Here's a picture of the delta. I got bored with my Lite Stik and built this delta last night.
Hey, you're not too far from me in Schaumberg. Where do you fly. I'm in Northbrook but don't fly at a club just in the park next to me and at the nature preserve in Buffalo Grove.
Cheers,
Lefty
Old Oct 06, 2001, 06:14 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
For anything unusual I normally make up a cartoon version using thin sheet foam (ceiling tiles) for the wing. Either to scale, or for very small models full-size. Bend a tiny bit of reflex into the CG then add weight to the front till it glides nicely. Takes no time at all and gives me a nice warm feeling when it comes to test-flying the 'proper' model! Here's one I used this technique to get the CG for (wingspan 7", Cox TD020, glide like a brick ):
Bill Glover is offline Find More Posts by Bill Glover
Old Oct 07, 2001, 09:10 AM
Joined Jan 2001
Thanks Bill,
I did the same with a paper aircraft and that's how I came up with the first estimate.
Tristan
Discussion How do you check your CG on your wing? reefboy Flying Wings 19 Sep 11, 2007 12:44 PM
Discussion how do i find cg on a delta punkrockd Flying Wings 15 Oct 11, 2006 03:23 PM
how to find CG on a flying wing? EKI16 Parkflyers 8 Jan 02, 2004 06:10 PM
How to get CG for a delta wing? (Mirage) GregG Power Systems 12 Dec 23, 2001 01:29 AM
CG on flying wing bruce ryan Power Systems 9 Jun 21, 2001 08:43 AM
