Hi all,
I have to say some of your techniques for molding Depron are producing some fine results.
I'm pretty new to the RC community but have wanted to do something for a long time - just work got in the way. Having been an avid fan of building scale static/display warbirds as a boy I really thought with the advent of the minaturised Rx & servos, kits that I made in my youth would serve well as templates for lightweight, micro or peanut scale as I always used to know it.
This year I bit the bullet & grabbed an aileron & elevator controlled bank & yank micro trainer in the form of a Minium Super Decathlon and taught myself to fly, crash, repair, crash, repair, fly etc. I really cannot describe what pleasure I derived from actually being able to remotely control an aircraft for the first time.
So - flying learnt (how niave I am) I thought it would be a good time to put some ideas I'd been kicking around into practice and with some investigation and sciency type info from Depron I decided to set about molding some of the light stuff to try and create my own 'kit' to build and use the inner working of the Decathlon to power & control it.
I chose to use Plaster of Paris to create the positive and negative molds because it was easy to find, cheap and easy to use - my first subject - rather ambitiously was a 1/32 Hawker Hurricane Mk1 and the slow climb up the learning curve began...
I soon realised that this project would probably turn out to be more of an experiment and was satisfied that it would be extremely unlikely I would get a Hurri flying warbird from it, but I would get a wealth of experience and knowledge on Depron, its characteristics and limitations in this process and learn more about compression or press molding.
Then during a spot of armchair research I then strayed upon threads that Harpye & Heliman420 had posted on some of their builds. You guys are really pressing forward with this stuff which meant I had to sign up to see where it was going.
I'm afraid I left it for a long while as my inexperience in the field of RC didnt exactly give much confidence that I would know what I was talking about but if you dont ask right?
The technique I used was to warm the plaster of paris molds in the oven to 100-110 degs C. I drilled a small hole in each mold so I could insert a temp probe whilst they were still in the oven.
I then take out the 2 sides of the mold and place the sheet of 3mm Depron between the two and slowly apply pressure. The plaster retains plenty of heat for a relatively long time - a bit like a stone. I then G-clamp with protective sheets of MDF either side to spread the pressure from the clamp so it doesnt cause the plaster to crack. Leave it for 15 mins then take it all out.
On the down side the plaster does have a tendancy to crack (due to the heat) and some molds only last for a few shots. The thicker the mold the less likely it is to crack, but it also depends on mix ratios with water too when making the molds initially I think.
I'll post some more as the thread develops - heres some pics of a few of the pieces I have got out of the process. Not the best quality photos - I will try better next time!
