Old Jan 24, 2011, 09:54 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Does anyone happen to know at what tempretature EPS beads fuse? I have this idea... If I partially fill the female mold with EPS beads, (making sure all the surfaces are covered), clamp everything together, and put it in the oven. If I get it to the fusion temperature, I should have a nice completed part once it's cooled...in theory...
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Jan 24, 2011, 10:17 PM
lw_hughes is offline
Find More Posts by lw_hughes
Hals und Beinbruch !!!!
lw_hughes's Avatar
Joined Aug 2002
are these pre expanded beads or raw new beads ( good luck finding a supplier). I had an idea of using pre expanded beads mixed with very light resin mixed with alcohol compressed in a mold. Who knows....
lw_hughes is offline Find More Posts by lw_hughes
Old Jan 24, 2011, 10:29 PM
Roy!! is offline
Find More Posts by Roy!!
Roy!!'s Avatar
Ocala,Fla
Joined Jan 2009
ima try this method to make a glider using a 5-10g brushless it would deffinitley look btter then a 4 sided square fuse
Roy!! is offline Find More Posts by Roy!!
Old Jan 25, 2011, 05:16 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I found a supplier of raw beads a very long time ago. I'll go find the link.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 25, 2011, 05:17 AM
Joined Nov 2007
Here you go. The link is within my thread (first page). $25 for 6 cubic feet.
http://www.rcgroups.com/forums/showt...ight=eps+beads
Old Jan 25, 2011, 10:57 AM
aerogel is offline
Find More Posts by aerogel
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Originally Posted by deadbird View Post
A HUGE thank you to all of you who have posted experience, ideas & advice onto this thread. Without it I feel I would not have been able to build my first moulded depron plane to my own satisfaction.
Its a 1/32 scale Messerschmitt Bf109E-4N with a 310mm wingspan and weighing in at 22.2g (inc. undercarriage) - a little over what I wanted by 6-7g but we'll see how this affects flight performance. Only managed to do glide tests so far.
I rather overdid it on the airbrushing as it's the first time I've ever used one so the weathering is heavy and I estimate the acrylic paint has added 2-3g to the weight.
Anyway, thanks to all of you guys with a special mention to Aerogel. I completed the wheels and spinner today using the exact same method you described back on pages 5-6 and they came out brilliantly.
Looks Sweet paint job look's awesome glad it work out for you...any hoot ,you guys are killing me can't wait to get back to my shop soon very soon.
aerogel is offline Find More Posts by aerogel
Old Jan 25, 2011, 11:26 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
just create a positive plug and put it on a block of wood ... put it in clear shrink tube for batteries and take the heatgun to shrink it to form ....
Harpye is offline Find More Posts by Harpye
Old Jan 25, 2011, 03:56 PM
deadbird is online now
Find More Posts by deadbird
Crashing with style
deadbird's Avatar
UK. Dorset
Joined Jun 2009
pacer canopy glue is excellent drys clear and cleans up with water...fantastic results..can you post some images of your molds etc.
LW - I'm putting the full build log here: http://www.rcgroups.com/forums/showthread.php?t=1377747
But here's a few more pics from during the build....thanks for tha canopy advice too. I'm definately gonna have to fit it to the next one now arent I!?
deadbird is online now Find More Posts by deadbird
Old Jan 25, 2011, 04:43 PM
Roy!! is offline
Roy!!'s Avatar
Ocala,Fla
Joined Jan 2009
ok so im going to go get my supplies i take it to make your male and female you just make the female then when it is done put a release compound on it and then pour your mold material on it to male the male? then seperate the 2
Old Jan 25, 2011, 09:18 PM
Heliman420 is offline
Find More Posts by Heliman420
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
Thats how i do it...
Heliman420 is offline Find More Posts by Heliman420
Old Jan 26, 2011, 02:05 AM
Crashing with style
deadbird's Avatar
UK. Dorset
Joined Jun 2009
I actually do it a bit different. Once I've made the female mold I cover it loosely with food wrap - we call it cling film in the UK. I then insert the plastic part I used for creating the female mold back into the cavity, sandwiching the film between the plastic and the mold - essentially the film is acting as the release agent here. I build a box around the female mold using Lego, tucking the film under beforehand. I then pour in the plaster and create the male. This means when the two halves of the mould come completely together there's a minimum of 1mm gap for the depron to form into, in an attempt not to over press the foam.
Make sense?
I'm going to go into more detail on the build thread. http://www.rcgroups.com/forums/showthread.php?t=1377747 Getting the right type of plaster is a must as well.
Old Jan 26, 2011, 02:38 AM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
Good info
Depends what thickness foam one is using... if using thin stuff like 025-020 the a 1to1 mold is needed.. then the critical areas especially around the joining lines are sanded... for the larger molds wax can also be used, but i like db's cling wrap idea better
Old Jan 26, 2011, 04:24 AM
Crashing with style
deadbird's Avatar
UK. Dorset
Joined Jun 2009
true, true Heliman - I'm using 2mm & 3mm depron at the moment for fuse. There doesnt seem to be any weight difference btween them once the parts are prepped. Need more than one decimal place on the digiscales m'thinks.
Old Jan 26, 2011, 10:25 AM
Roy!! is offline
Roy!!'s Avatar
Ocala,Fla
Joined Jan 2009
Make sense?
for what im doing i will make a plug for each half of the fuse then make me female so i don;t have a part to put back over the female to create the gap but i guess a little sanding will do the trick then i will just cut a foam wing with a foam core wing machine i have
Old Jan 26, 2011, 07:30 PM
Evansville, WI
Joined Dec 2006
I like the idea of cling wrap as a parting agent, I'm going to have to give it a try
Discussion A simple quiz on religious knowledge tolladay Life, The Universe, and Politics 86 Oct 03, 2010 06:37 PM
Discussion Airtronics SD-10G model exchange thread webbsolution Multi Task F3X 31 Jun 14, 2010 12:10 PM
Build Log New L2 Airframes Super Scooter build thread Daemon Slope 37 Dec 27, 2008 06:30 PM
Discussion Diy Tire Molding Thread cyclenut44 The Builders Workshop 0 Jan 09, 2007 12:19 PM
Link ultimate full size molding build thread jirvin_4505 Composites Fabrication 2 Jun 09, 2006 07:19 AM
