Old Mar 13, 2011, 04:13 AM
z3scot is offline
Find More Posts by z3scot
Joined Mar 2011
Originally Posted by Wayne Giles View Post
If anyone else is in the market, please let me know; I don't mind taking some risk, but not much as there is no profit motive involved
Wayne.
Hi Wayne, Please add me to the list
-- Scott
z3scot is offline Find More Posts by z3scot
Old Apr 02, 2011, 10:42 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Wayne.
Please put me down for one also.
How are things looking to do another production run?
Ohmic is offline Find More Posts by Ohmic
Old Apr 02, 2011, 01:42 PM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Pete,
I have added you to the list of people to be informed when they are available. At present all components are ordered and I am awaiting PCBs which are due April 13th. I guess units will be available about two weeks later ie end April.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Apr 02, 2011, 03:51 PM
Ohmic is offline
USA
Joined Jan 2002
Thanks Wayne.
Old Apr 02, 2011, 03:55 PM
LeszekJ is offline
Find More Posts by LeszekJ
LeszekJ's Avatar
Poland
Joined Nov 2010
Wayne, how many measurements does your nice device take to calculate the average value?
LeszekJ is offline Find More Posts by LeszekJ
Old Apr 03, 2011, 04:46 PM
Rugby, UK
Joined Feb 2007
Leszek,
It only takes a single reading by measuring voltage, applying a load of 16A for 15mS and measuring the voltage again just before the pulse is removed. It then calculates the IR from the results. There is no need to take several readings as the results are very consistent. I tried several pulses with no improvement. Several pulses or one longer one will distort results slightly by warming the battery and reducing the IR.
Wayne
Old Apr 03, 2011, 05:13 PM
LeszekJ is offline
LeszekJ's Avatar
Poland
Joined Nov 2010
I rather meant one pulse and fast series of measurements.
How fast can you take voltage measurements?
BTW what is the ADC resolution?
15 ms? How do you manage the transient state (inductance of connections, capacity of cell SEIs). Did you take waveforms with a scope for various battery capacities?
Old Apr 04, 2011, 11:14 AM
Rugby, UK
Joined Feb 2007
Leszekj.
Will send a PM with more details - most people on the forum don't want lots of technical detail.
Wayne
Old Apr 04, 2011, 11:37 AM
Ohmic is offline
USA
Joined Jan 2002
Leszekj.
Wayne
I'd appreciate the technical details. The more the merrier.
Old Apr 04, 2011, 04:56 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Wayne, I'm sure there are quite a few people who would. You can always put a "This information is known in the State of California to cause possible brain damage" warning in the title.
I would be interested.
jj604 is online now Find More Posts by jj604
Old Apr 05, 2011, 03:12 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Leszekj.
Wayne
Me too I would be interested in the technical details.
jaccies is offline Find More Posts by jaccies
Old Apr 13, 2011, 08:30 AM
bob_nj is offline
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Smaller Packs
What would happen if this meter is used on smaller packs like 325~480?
Also, if the list is still around, I'd like to be put on it for a meter.
I may have missed it, but is there a manual on the meter I can look at
in the mean time?
Bob
bob_nj is offline Find More Posts by bob_nj
Old Apr 13, 2011, 10:36 AM
Rugby, UK
Joined Feb 2007
in the mean time?
Bob
Bob,
I rated it at 500 - 6000mAh because the pulse is 16A. which is not too big for the smallest pack yet is still a significant load for the larger sizes. As the pulse is only 15mS it would not damage the 325mAh pack, but the maximium pack reading is 250milliohms and cell 30 milliohms so that there is a risk that the actual values would be greater than this at low temperatures.
I have put you on the list to be contacted when the present batch is completed (about 2 weeks.)
As I only made them as a hobby, there is no real Manual, but I send out a double sheet of info with each meter. Hopefully it is attached to this post.
Wayne
Old Apr 13, 2011, 11:12 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Thanks!
Old Apr 13, 2011, 02:00 PM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
Hi Wayne,
From your manual...
"It is possible to connect the meter in parallel with a working load (ESC + Motor) and monitor the ESR as the discharge proceeds. This will clearly demonstrate the self heating effect and consequent fall in ESR as the battery temperature rises."
Can you explain how you would do this? Would you press the button while the motor is running? Wouldn't this either put an excessive load on the pack and or confuse the meter? I'm very slow when it comes to electronics so please pardon the question.
ScotY is offline Find More Posts by ScotY
Discussion Best fo the West Jets Schwemmer Inland Slope Rebels 0 Oct 14, 2010 05:02 PM
Discussion Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch RJPIoW Electric Ducted Fan Jet Talk 1 Sep 08, 2010 12:05 PM
Question New Low IR Lipos Cells nxtdoor High Performance 75 Sep 06, 2009 04:47 PM
Discussion ESR meter to test Nicad/NiMH ?? 1101 DIY Electronics 3 Jun 15, 2009 04:08 AM
