Old Feb 14, 2011, 03:58 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Originally Posted by jaccies View Post
Only thing suprised me and dont understand why is there a difference, between the Pack IR and the sum of all cells IR? It's around 10mOhm difference.
In cell mode, it measures the IR of the cell at the solder tabs of the cell. In pack mode, it measures the resistance of all wiring (including wiring within the IR meter) and connectors.
For this reason, there will always be a difference between the aggregate cell IR and measured pack resistance. Any large discrepancy between these two measurements will denote a bad connection somewhere, be it solder joint, connector mating interface, or other. As such, measuring both cell IR and pack IR is not a bad idea.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 14, 2011, 05:03 PM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Jac,
Thanks for posting the results on your packs.
Mark is exactly right, the difference is because of the sum total of the resistances of the terminations, leads and connectors. With a Deans I always expect 6 - 8 milliohms extra of resistance between cell totals and pack reading. Your pack with Deans shows 7.4milliohm difference. Can't comment with authority on 4mm cage connectors as I hardly use them, but I would expect just slightly more than Deans.
It is surprising how the difference builds up as it includes the interconnecting resistance between the cells as well as the external leads, connectors and all the solder joints. Nonetheless it is a practical reading because in practice this is what the ESC + motor see in series with a perfect voltage source ( ignoring discharge effects.)
Your readings all look sensible at a glance; I will look at them in more detail , compare with your original readings and comment again in the next day or so.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Feb 14, 2011, 09:00 PM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
Just tested some of my packs for info
All tested at storage voltage, ambient 80f
Most are 12 months old with 20 - 40 cycles on them
They all balance charge fine
I use 5.5mm bullets for discharge leads
6s 5100mah 35c Voltz
Pack 23.1
2.72, 2.72, 2.68, 2.96, 2.68, 2.76
4s 5000mah 40c Turnigy
Pack 12.6
1.36, 1.48, 1.52, 1.64
3s 6000mah 25c Nano
Pack 13.8
2.0, 2.2, 2.08
3s 5000mah 40c Turnigy
Pack 11.7
2.04, 1.36, 1.44
2s 6000mah 25c Nano
Pack 11.1
2.08, 2.20
2s 5000mah 40c Turnigy
Pack 9.9
1.52, 1.48
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old Feb 15, 2011, 03:05 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Pack 23.1
Pack 12.6
3s 6000mah 25c Nano
Pack 13.8
2.0, 2.2, 2.08
Pack 11.7
2.04, 1.36, 1.44
2s 6000mah 25c Nano
Pack 11.1
2.08, 2.20
Pack 9.9
1.52, 1.48
Cheers
Hi,
you measure very low values, what brand of lipo''s are you using?
Put the brand of lipo in your list.
jaccies is offline Find More Posts by jaccies
Old Feb 15, 2011, 03:08 AM
Melbourne
Joined Aug 2010
The brands are listed mate
Hobbyking Turnigy
Hobbyking Turnigy Nanotech
Voltz
Cheers
Old Feb 15, 2011, 03:20 AM
jaccies is offline
Joined Dec 2008
Hobbyking Turnigy
Voltz
Cheers
yes i saw it sorry
your readings are very low values, i use only 1 turnigy which readings are also low.
Why you choose for Turnigy instead of Zippy flightmax?, i know Turnigy;s are more expensive then Zippy's
you measured at storage level, its summer overthere lipos should be full for cars
Old Feb 15, 2011, 03:23 AM
Melbourne
Joined Aug 2010
I use them for cars and usually just grab whatever is in stock
Have used plenty of smaller Zippy's over the past few years and never had a bad pack
Cheers
Old Feb 15, 2011, 02:55 PM
Rugby, UK
Joined Feb 2007
Jac,
Having looked at you results I was intending to say that I notice that the Turnigy IR was low which I have also noticed in my measurements and Scott's (Crusey) results confirm it also, although his temperature is rather higher.
Notice his difference between Pack and total cells is about 6.6 - 6.8mOhms because he is using 5.5mm solid connectors which are only about 0.15mOhms each.
I see your 30C FPs are noticeably lower than the 20Cs but not as low as the Turnigy, again as I have found.
I have noticed in doing comparison high power continuous discharges that the higher IR packs show greater voltage drops initially but then finish up at the end with the same IR due to the self heating, but a lot hotter and presumably will not live as long.
All your packs look OK; if one is dying you will see one cell much higher than the others, which is a runaway situation. The poor cell gets hotter and the rate of damage accelerates.
Scott, thanks for posting those; Turnigys do come out low generally. No experience of Volz.
Wayne
Old Mar 04, 2011, 01:45 AM
Kozmyk is offline
Find More Posts by Kozmyk
United Kingdom, Wales, Swansea
Joined Jun 2010
Originally Posted by Wayne Giles View Post
Jac,
Wayne
Hah Hah. I went to quote some connector resistance values that I'd read on another forum then when I looked I noted that it was YOUR data.
http://www.rcmf.co.uk/4um/index.php/...915455.html#37 post #37
Valid nonetheless.
Kozmyk is offline Find More Posts by Kozmyk
Old Mar 04, 2011, 11:45 AM
Rugby, UK
Joined Feb 2007
Valid nonetheless.
Kozmyk,
That is what the statement was based on!
I know it is off - topic, but I avoid 4mm cage connectors for two reasons:
1) When fumbling in a fuselage at the field it is all too easy to pick up the wrong connectors and plug the pack +v into the pack -ve. - Yes, I did it once!
That objection applies to any single pole bullet connector.
2) The cage connector has little surface area and is effectively two connectors in series, which is why a 3.5mm solid connector is 3 x better than a 4mm cage connector. I must say I was surprised how good that little 3.5mm solid connector was; enough to make me double check the results, not far behind the 5.5mm solid bullet.
Wayne
Old Mar 04, 2011, 03:30 PM
Kozmyk is offline
Joined Jun 2010
Wayne
I agree that the single cage type are risky in terms of pack safety but I must admit that I was surprised how well they did in the resistance stakes, still well behind the solid bullets but not as bad as I had expected.
The EC# design of course prevents such pack shorting accidents by mounting it's 3.5mm bullets in polarised housings.
Now if only we could get solid bullets to fit into EC# housings; that would be perfect.
Getting back on topic, I look forward to you getting enough interest to be able to make some more IR Meters.
Such a precision device would be a prized addition to my arsenal.
So refreshing to see so much care and attention to accuracy in a design these days.
Old Mar 04, 2011, 03:39 PM
Rugby, UK
Joined Feb 2007
Koz,
If you look at an XT60 connector (which I have changed over to for normal use, ie up to 60A) you will see that it uses solid bullets which look very nearly identical to the 3.5mm solid bullets. I would have difficulty in telling them apart out of the housings, so they sound exactly what you want. Don't ask me to explain why they don't perform as well as the bullets - I can't, but even so they are very good. This is why I was so surprised how good the bullets were.
Wayne
Old Mar 04, 2011, 04:21 PM
Kozmyk is offline
Joined Jun 2010
I'm happy enough with the EC3s for now despite them being cage types (in a shroud) but any bigger current and I'd prefer solid to cage for sure.
So far I've got 3 helis, 2 planks and 8 packs on EC3 and I'm reluctant to change unless any of them start getting hot.
In retrospect I'd have done as well to keep the packs on XT60 and changed the birds but it's done now.
Old Mar 06, 2011, 10:52 AM
speed2004 is offline
Find More Posts by speed2004
United States, IL, Peoria
Joined May 2003
Do you have any of the IR meters left? and how do I pay you-Paypal or Int Money Order?
speed2004 is offline Find More Posts by speed2004
Old Mar 06, 2011, 10:53 AM
Joined May 2003
I ran out of British Sterling...LOL
Discussion Best fo the West Jets Schwemmer Inland Slope Rebels 0 Oct 14, 2010 05:02 PM
Discussion Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch RJPIoW Electric Ducted Fan Jet Talk 1 Sep 08, 2010 12:05 PM
Question New Low IR Lipos Cells nxtdoor High Performance 75 Sep 06, 2009 04:47 PM
Discussion ESR meter to test Nicad/NiMH ?? 1101 DIY Electronics 3 Jun 15, 2009 04:08 AM
