Old Aug 04, 2014, 10:01 AM
gtxkid is offline
Find More Posts by gtxkid
1300mm Octo K130 / Mikado Logo
United States, FL, Gulf Breeze
Joined May 2006
Any chance of getting one to do the 10000 to 22000ma 6s packs.
Reason i ask is because i am getting ready to buy a lot of batteries for a 1300mm Heavy Lift Octo i have.
Lot of guys are buying the 10,000 / 16,000 / 22,000 batteries for them.
After reading a little here i am wondering if i should just buy 5000ma packs and use 1 or 2 or even 3 or 4 to achieve what job calls for.
With having lost a lot of money on lipo's over the years i feel this is a great tool for people like me who do not have a lot of money and want to stay on top of there batteries.
gtxkid is offline Find More Posts by gtxkid
Old Aug 04, 2014, 12:38 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by Ermilo View Post
Tks nice metaphor
Yes, you really want some "headroom" in ESCs and batteries.
Rule for Lipos and ESCs
Buy ESCs and Lipos that have 20% headroom minimum. And, I might add, lipos tend to be over-rated so consider 30 to 40% of headroom.
Prof100 is offline Find More Posts by Prof100
Old Aug 04, 2014, 02:38 PM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
The meter will read packs of any capacity. Although I initially specified a max of 6000mAh this was based on the thinking that the measurement pulse of 16A was well below the likely working current of very large packs. I experimentally built a higher current version using a 32A measurement pulse but found that the results on very large cells were within 1% of the standard 16A version so that the considerable extra expense was not worth it.
You can confidently use it on large lipo packs of any capacity but you must respect the 6S cell limit.
There is also a Hi Resolution version, using a 25A pulse and capable of a cell IR resolution of 0.0.01 milliohms as against the standard unit's 0.04 milliohms. The downside is that the maximum cell IR range is 0 - 8 milliohms so that it is not suitable for cells of under about 2600mAh.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Aug 04, 2014, 03:45 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Wayne
Wayne,
So you can use it on any cell to measure IR, but never more than 6 cells to measure pack IR.
Bill
Old Aug 04, 2014, 05:46 PM
Rugby, UK
Joined Feb 2007
Originally Posted by Prof100 View Post
Wayne,
Bill
Bill,
The only limitation on the size of the cell is at the bottom end ie on very small cells. The 16A pulse represents 32C for a 500mAh cell although it is OK for cells down to 300mAh (53C) as the pulse is only 15mS long so will not cause damage.
If the pack voltage falls below 7V during the load pulse, which can happen on small or very weak 2S packs, the reading may be erroneous.
The number of cells is always limited to 6 maximum as the pulse is taken from all the cells in series, even for Cell measurements, so the internal electronics has to dissipate 400watts during the measurement pulse on a 6 Cell pack.
Wayne
Old Aug 07, 2014, 03:52 AM
pyroarch57 is offline
Find More Posts by pyroarch57
Joined Jun 2008
Pack ESR
Post retracted as question is now solved.
pyroarch57 is offline Find More Posts by pyroarch57
Old Aug 10, 2014, 12:40 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
.... There is also a Hi Resolution version, using a 25A pulse and capable of a cell IR resolution of 0.0.01 milliohms as against the standard unit's 0.04 milliohms. The downside is that the maximum cell IR range is 0 - 8 milliohms so that it is not suitable for cells of under about 2600mAh.
Wayne
Wayne, I would like to purchase the high res version. Since I typically only measure 6S 5000's and up it's been hard to realize much differentiation when packs are uniformly warm (short of an outright failure). I'm thinking it might be a good thing to develop an IR degradion curve along with the capacity curves during my up coming life cycle test series. Maybe track the average IR of the 6 cells or the highest value cells' reading.
Joe
MCSGUY is offline Find More Posts by MCSGUY
Old Aug 10, 2014, 01:36 PM
Rugby, UK
Joined Feb 2007
Hi Joe,
Thanks very much for your enquiry.
Sounds a good idea to track the IR of the cells on each pack. The obvious problem is temperature variation as the differences you are trying to track will be small.
Do you have a temperature controlled enclosure to enable you to bring the packs to a closely controlled temperature of, say, 70*F. (21*C)? If not you can knock one up very cheaply from a small drink cooler and a cheap temperature controller.
Will be interesting to see when they peak as I find that the IR of all packs fall initially but then start s to rise as the pack ages. Some packs have only fallen after the first cycle but others fall for the first 3 or 4 cycles.
I will build a Hi Res meter this week and let you know when it is ready for despatch.
Old Aug 10, 2014, 04:54 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Thanks Wayne! I'll look forward to receiving it. I probably won't start testing for a good month as the flying (and repair) season is in full swing here.
My thermal chamber is a double walled tube vented to the outside with a fan blowing through the open end to provide air flow over the pack while it's cycling. My thinking was to do the IR check after every 25 charge/discharge cycles when I do the capacity check. Then all the packs would be on a common playing field so to speak when they are measured.
Joe
Old Aug 17, 2014, 02:05 PM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Hi Wayne,
How many versions do you now make?
My original unit is still going strong. The best tool in my electric flight box!
Cheers
Alex
like2fly! is offline Find More Posts by like2fly!
Old Aug 17, 2014, 03:35 PM
elecfryer is offline
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
United States, CA, Camarillo
Joined Aug 2007
I have had mine for just over 2 years now and while I use it a lot and I show other people how it works and what the numbers mean it is only recently that others are asking to have their batteries checked. Many people still just check the voltage and then fly. When they have issue with the battery not working well the usual comment is "I don't understand whats happening, I fully charged it before I used it" It seems that having a "good tool" is nice, understanding what it does, that's nice also however, understanding what makes lipos tick is....................different from just putting fuel in a tank! Oh well, one can lead a horse to water but, you can't make him drink! Michael
elecfryer is offline Find More Posts by elecfryer
Old Aug 17, 2014, 04:14 PM
Rugby, UK
Joined Feb 2007
Alex,
Glad to hear your meter is useful.
There are four types although three are just varaitions of one design.
Only the Single Cell unit is a different design as it is a dedicated unit intended for measuring small single cells of 30 - 1000mAh.
The other three types are the original unit and two variations.
Standard unit is for measuring 2 - 6S packs of 500mAh and up. Resolution is 0.04milliohms
Modified 1S - 6S. version has the same spec. but can measure single cells.
Hi -Res version can measure 1S - 6S packs 2000mAh upwards with a resolution of 0.01milliohms but really is a specialist unit as the max cell reading is only 8milliohms and the max total pack reading is 65milliohms. It is intended for competition users.
Hope that clarifies it.
Wayne
Old Aug 18, 2014, 12:21 PM
gtxkid is offline
Joined May 2006
Does it happen to be in on of the icharger's.
Be Cool if the charger had this option.
Old Aug 18, 2014, 04:07 PM
Rugby, UK
Joined Feb 2007
Sorry, I don't understand the question.
Can you clarify it
Wayne
Old Aug 18, 2014, 04:21 PM
gtxkid is offline
Joined May 2006
Can you clarify it
Wayne
Is there a charger that has it integral in one of the i-chargers.
Discussion Best fo the West Jets Schwemmer Inland Slope Rebels 0 Oct 14, 2010 05:02 PM
Discussion Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch RJPIoW Electric Ducted Fan Jet Talk 1 Sep 08, 2010 12:05 PM
Question New Low IR Lipos Cells nxtdoor High Performance 75 Sep 06, 2009 04:47 PM
Discussion ESR meter to test Nicad/NiMH ?? 1101 DIY Electronics 3 Jun 15, 2009 04:08 AM
