Old Feb 11, 2013, 04:02 PM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Jim,
Thanks for the endorsement.
Re the variation of "C" rating with temperature, The short answer is yes it does vary. The IR can increase by 50% for a 20degC fall at low temperatures so that affects the heat dissipated within the cells and effectively reduces the C rating.
We have all seen models take off in winter and cut out on LV limit within half a minute because the IR of the pack is so much higher than it would be at summer temperatures. A 50% increase in IR suggests a decrease in C rating of about 20% because a square law is involved.
The reverse is true but it depends on the rate at which the IR decreases with temperature and, of course, we have the limitation of maximum operating temperature. As you raise the starting temperature, you are decreasing the heat dissipated within the lipo, but you are starting closer to the max operating temperature so that the acceptable rise is less.
I always start any discharge testing from a nominal 25deg.C to ensure that all lipos are compared on a "flat field" basis, ie they all start from an equal point.
The 'battery load test comparison' thread is a different approach but will almost certainly come up with the same general conclusions as it is measuring and comparing the voltage drops from different packs under the same conditions.
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Old Feb 12, 2013, 05:20 AM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
Would this be because the pack was cold initially and not installed relatively warm or the resultant internal generated heat was not sufficient to maintain the starting IR .?
Originally Posted by Wayne Giles View Post
Jim,
Wayne
Jimob23 is offline Find More Posts by Jimob23
Old Feb 12, 2013, 03:35 PM
Rugby, UK
Joined Feb 2007
Jim,
This is because the pack is cold to start with so the IR is high and therefore the heat dissipation at a given current in the lipo is higher. This generates heat which lowers the IR so that the voltage then rises. There is a delay involved, so that the first flight fails but the second attempt is often successful because the heat generated in the first attempt has now spread through the pack and the IR is much lower.
The plot below which I did some years back demonstrates the problem.
Look at the low temperature (yellow) discharge plot.
http://static.rcgroups.net/forums/at...emps.Irfan.jpg
Wayne
Old Feb 13, 2013, 02:57 AM
Jimob23 is offline
Joined Aug 2012
Thanks Wayne and interesting to see the cold pack does start to sort itself out after a relatively short period .
Bit like warming up an engine before expecting to get max power supply
Jim
Jim,
Wayne
Old Feb 13, 2013, 10:40 PM
Edward64 is offline
Find More Posts by Edward64
Ontario - CANADA
Joined Apr 2008
Hello Wayne. I read about your device in the Model Aviation - Canada publication.
Can you e-mail shipping details? Thanks. esadok@rogers.com
Edward64 is offline Find More Posts by Edward64
Old Feb 13, 2013, 10:46 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
It's also sold in the u.s. which might save you a little and help us, too!
http://www.progressiverc.com/tools-a...electric-tools
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Feb 14, 2013, 09:20 AM
Edward64 is offline
Ontario - CANADA
Joined Apr 2008
LiPo Internal Resistance
Thank you, JohnathanSwift, for your link to Progressive RC.
Also, Mr. Wayne Giles has e-mailed me, as well. I appreciate this help.
The LiPo battery internal resistance meter is a very useful device for assessing the "real" capacity of a LiPo battery.
Old Feb 14, 2013, 09:32 AM
Greenland
Joined Mar 2012
Anything for you Canadian dudes! Also, it will either corroborate or show false your chargers data on ir.
Old Feb 14, 2013, 11:32 AM
Mikecam is offline
Find More Posts by Mikecam
Mikecam's Avatar
Canada, MB, Winnipeg
Joined Apr 2008
I bought mine from here. Charged me $7 for shipping at the time. Love the tool!!!! Pull it out at the field and in less then 5 minutes you have a crowd around you. Best bet is school someone on the simple instructions and go fly, either that or you will be testing batteries all day.
http://www.f3aunlimited.com/webstore...roducts_id=572
Mikecam is offline Find More Posts by Mikecam
Old Feb 19, 2013, 09:33 PM
Jimob23 is offline
Joined Aug 2012
Wayne
That all falls in line with something's I have read elsewhere where there is an inhibitor within the cell chemistry to pre-long shelf life .
In your initial cycles what voltage are you terminating at ?
After the 5C cycle do you consider that the pack is now ready for proper field use or should there be further breaking in cycles
I have seen suggestions elsewhere that 10C sustained load be considered as part of the 'break-in' so in my case of 5000 Ma that equates to 50A which I fell could be a bit extreme !
Cheers Jim
Jim,
In most lipos I have noticed that the first cycle reduces the IR.
I think it depends on the electrochemical makeup and this varies from one type to another.
I always run them through at least one 1C cycle before any testing and then go to a2C cycle, a 5C cycle and then to serious testing. The fact that the IR changes suggests to me that the cell goes through a "forming" process on the lines of an electrolytic capacitor.
As an example the GensAce lipos I tested dropped in IR by 25% on first cycle which is the most I have seen but then remained constant. The Haiyin I recently tested which was 20C dropped about 15% and then remained constant.
Other people say the IR falls for several cycles but I have never seen that; it just seems to be the first cycle.
It is certainly worth doing so measure it with your new pack, being very careful you do so at the same temperature and see if you see a fall.
Wayne
Old Feb 20, 2013, 02:07 PM
Rugby, UK
Joined Feb 2007
Originally Posted by Jimob23 View Post
Wayne
Cheers Jim
Jim,
I terminate the cycles at 3V, but that is the loaded voltage.
After a cycle I think that a lipo is ready to use as I do not see any change in IR after that point, so that presumably, any forming process is complete.
I only run further low C cycles when testing in case that theory is wrong and to remove any excuse for failure or poor performance.
Wayne
Old Feb 20, 2013, 03:59 PM
Jimob23 is offline
Joined Aug 2012
Thanks Wayne
I will follow your suggestions and let you know where the final C rating ends up.
Cheers Jim
Jim,
Wayne
Old Apr 18, 2013, 04:44 PM
nitrodude71 is offline
Find More Posts by nitrodude71
r/c addict
USA, LA, DeRidder
Joined Jul 2004
hi wayne
i own this meter and what a great piece of equipment it is and was wandering is there any way possible to use this meter to test the esr of electrolytic capacitor's? as i also work on tv's and electronics as a hobby but my $220 esr meter bit the dust. so i thought if i could use this one i could save a few bucks. thanks
nitrodude71 is offline Find More Posts by nitrodude71
Old Apr 18, 2013, 06:53 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Nitro, I'm sure Wayne will provide a proper explanation but the answer is no.
The ESR in the meter name stands for the Effective DC Series Resistance internal to the pack and is not the same as capacitor ESR which is an AC parameter. The ESR/IR meter needs the LiPo pack to power it and supply the voltage for the measurement.
John
jj604 is online now Find More Posts by jj604
Old Apr 19, 2013, 05:10 PM
Rugby, UK
Joined Feb 2007
Yes, sorry Nitro, but John is correct.
The two types of meter are quite different in operation so my meter cannot read a capacitor and a capacitor ESR meter cannot read the IR of a lipo pack.
Glad you like the meter; thanks for the endorsement.
Wayne
Discussion Best fo the West Jets Schwemmer Inland Slope Rebels 0 Oct 14, 2010 05:02 PM
Discussion Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch RJPIoW Electric Ducted Fan Jet Talk 1 Sep 08, 2010 12:05 PM
Question New Low IR Lipos Cells nxtdoor High Performance 75 Sep 06, 2009 04:47 PM
Discussion ESR meter to test Nicad/NiMH ?? 1101 DIY Electronics 3 Jun 15, 2009 04:08 AM
