Old Jul 03, 2011, 08:52 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
You can tell a weak cell from a spot IR reading alone
like2fly! is offline Find More Posts by like2fly!
Old Jul 03, 2011, 09:18 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Snip from post #6
It measures the effective resistance by applying a pulse load of controlled constant current load of 16A to the pack, measuring the voltage just before the start of the pulse and again just before the end of the pulse. It then does the maths of subtracting the last figure from the first figure, divides the answer by 16 to give result in ohms and divides that by 1000 to display the answer in milliohms.
A very simple means to spot a weak cell is to just connect a CellLog or other such device which reads and displays each cell's voltage by way of balancing connector and then run up your motor to provide a load.
Some chargers have the ability to monitor and graph each cell's voltage under a load which gives a very clear indication of a cells relative health.
http://www.rcgroups.com/forums/showt...8#post18621408
FYI In the case of this LiPoly there really is not signaficant difference in the cell's IR.
http://www.rcgroups.com/forums/showp...89&postcount=8
Charles
Old Jul 03, 2011, 05:26 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Wayne is the expert on this but I think he is on hols so here is a quick answer.
Total "resistance" in an AC circuit is a combination of in phase and out of phase voltage/current interactions. It is called impedance and varies with frequency. ESR is commonly specified for capacitors and is the sum of in-phase AC resistance of the capacitor in an AC circuit. That is the "DC" component at a particular frequency. It includes resistance of the dielectric, plate material, electrolytic solution, and terminal leads at a particular frequency. ESR acts like a resistor in series with a pure non-resistive capacitor (thus the name Equivalent Series Resistance).
A LiPo is very similar to a large capacitor in many ways in regard to internal impedance effects. We generally ignore any AC (out of phase) effects since it is supplying DC current so ESR becomes the DC Internal Resistance of the battery -commonly called IR. Wayme used the technically correct term for the meter but it does in fact only measure resistance using DC. Some IR meters use a specific frequency as the standard to specify the resistance (1kHz from memory but I'm no expert on this).
The value of IR you get depends on the frequency you measure it at (and a host of other things). This meter measures it under the conditions that interest us. Supplying DC.
Originally Posted by Aviefly View Post
A couple of questions. First is probably easy for most but what does ESR stand for?
jj604 is online now Find More Posts by jj604
Old Jul 03, 2011, 06:11 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Wow thanks John. I think I got something wrong in my question as that isn't likely to be easy for most. I think I got the idea of it, thanks for taking the time.
Aviefly is offline Find More Posts by Aviefly
Old Jul 03, 2011, 06:29 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Don't worry about it! First time I had to try and understand this stuff and the lecturer said, "Now we are going to have to get an understanding of imaginary numbers" I was a bit stumped.
For us, for all practical purposes ESR and IR are interchangeable. AFAIK IR is the correct usage for batteries.
Just think of a battery as a container that includes a voltage source (that varies with state of charge) in series with a resistance (the IR of the battery). The more current you draw from the battery the lower the terminal voltage and the hotter it gets because of the power dissipated in the internal resistance.
Old Jul 04, 2011, 06:03 AM
LeszekJ is offline
Find More Posts by LeszekJ
LeszekJ's Avatar
Poland
Joined Nov 2010
Here we go again!
I've been trying to discuss this problem with Wayne...
LeszekJ is offline Find More Posts by LeszekJ
Old Jul 04, 2011, 06:15 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
I know a LiPo is not "like" a capacitor. I said it is "very similar to a large capacitor in many ways". Those ways help understand some things about LiPo behavior. It is an analogy not a correspondence.
There is a fine line between making things accessible and absolute accuracy. All of our models of the physical world involve some sort of approximations. The level of approximation is chosen to be appropriate for the purpose.
We know Newtonian physics and classic atomic theory are not "accurate" pictures of the physical world but they work just fine for almost everything we need.
Most people don't have your detailed and deep knowledge of the technology. My simplification was an attempt to assist someone understand how a concept such as IR might help in better understanding everyday LiPo behavior, not a definitive statement.
Just to be clear I'm not arguing or disagreeing with you about the best and most accurate model of a LiPo equivalent circuit. But for the purposes of the exchange a simplified analogy was adequate.
John
Originally Posted by LeszekJ View Post
Here we go again!
Old Jul 24, 2011, 04:28 AM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
AGENT IN USA
I have been off-line for four weeks thanks to British telecom., but finally now back on.
In the meantime I finished a batch of units which were sold to David Gray of ProgressiveRC in Seattle. David is enthusiastic about the unit and has them for sale at a very modest mark up. Customers in the US will save a siginificant portion of that in shipping costs.
Any further units I make will have to be at an increased price as it only started as a hobby and I was prepared to break even or even lose money on a few units but more units have been sold than I estimated. Obviously I can't lose money on any future units.
Link to David's site at : http://www.progressiverc.com/esr-meter.html
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Jul 24, 2011, 08:17 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Wayne,
I showed the meter to my club and they want some. I have about 6 orders coming. I am also taking my meter to the US Nationals next week, and there are some big electric guys there. Get busy!!
tclaridge is online now Find More Posts by tclaridge
Old Jul 25, 2011, 08:27 AM
Rumple is offline
Find More Posts by Rumple
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
Wayne, glad to hear that you joined with the best vendor in the US for these!
I ordered mine and received it quite promptly along with a string of other items from progressive. So far I really like the ESR - it sorted all my packs out in short order!
Rumple is offline Find More Posts by Rumple
Old Jul 25, 2011, 12:42 PM
bob_nj is offline
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
In post #158 RUMPLE says the following;
I can see how this meter might be useful to sort the good from the bad packs at the hobby shop before purchasing! I.e., confirm (or more likely, refute!) the C-ratings on the packs.
So if I wanted to confirm or refute the "C" ratings on a pack, what would I do?
Would I use the 12000 divided by the capacity of the pack to get the estimated IR reading, and compare it to the actual?
How far from the actual is considered acceptable, and how can I calculate the "C" rating from the IR reading on Wayne's meter?
Whew, so many questions...
Bob
bob_nj is offline Find More Posts by bob_nj
Old Jul 25, 2011, 01:32 PM
Rugby, UK
Joined Feb 2007
Thanks Rumple.
Bob,
The 12000 divided by capacity is Mark Forsyths's estimate and I agree although only really good packs meet his criteria.
You should get a feel for what is a good IR value although the above figure is a good starting point.
I did a thread on Turnigy nanotechs as I bought two 3S2200 25c packs and they both showed very high IR values which immediately said to me that they could not meet the 25C claim.
Thread at http://www.rcgroups.com/forums/showthread.php?t=1384403
When I tested the packs on a real continuous discharge it became obvious that the packs were only capable of 15 - 18c discharge rates dependant on what temperature rise the user is prepared to risk.
Results at http://www.rcgroups.com/forums/showthread.php?t=1406364
Look at the difference in the IR values for the Loong max, Tipple and older Turnigy packs and you will see that they meet Mark's criteria whilst the Nanotechs are far short. So your suggested calculation is broadly correct, although the 12000 figure is always arguable.
Wayne
Old Jul 26, 2011, 03:39 AM
TreeDiver is online now
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
@Wayne
Did you get already GensAce? For testing?
They emailed me...but I am not a tester and I did advice to send some packs to you.
It seems that Gerd Giese also will do a test of GensAce, altough I did not see them at the German market yet.
The IR you have on the 25C Nano are indeed high. I have 9mOhm per cell (2200mAh), which is equal to my Rhino 30C (which are two seasons old).
Seems that Nano is a good marketing story. Still I like these packs, but regular Turnigy also work perfect. I have several 40C 1800mAh with 5mOhm per cell, which is IMO good.
The GensAce are 3mOhm per cell (2200mAh)
TreeDiver is online now Find More Posts by TreeDiver
Old Jul 26, 2011, 06:31 AM
Rugby, UK
Joined Feb 2007
[QUOTE=TreeDiver;18865086]@Wayne
No unfortunately I have been off line for nearly 4 weeks due to British Telecomm's incompetence - it is so bad that it is hard to believe that anyone could be doing it accidentally - it looks deliberate, but can't be.
I hope to get one later and will post the results.
Wayne
Old Jul 26, 2011, 07:30 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
@Wayne
That is indeed odd! We have some bad providers here as well, but 4 weeks...that is shameful.
Maybe they have to much IR on their lines and pull too much amps!
Good luck and we see the results coming. Good news is that GensAce are available in Europe now
My Rhino 30C for the funjet are still in great condition... but it is very tempting to purchase GensAce 4s 2200mAh for them.
Discussion Best fo the West Jets Schwemmer Inland Slope Rebels 0 Oct 14, 2010 05:02 PM
Discussion Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch RJPIoW Electric Ducted Fan Jet Talk 1 Sep 08, 2010 12:05 PM
Question New Low IR Lipos Cells nxtdoor High Performance 75 Sep 06, 2009 04:47 PM
Discussion ESR meter to test Nicad/NiMH ?? 1101 DIY Electronics 3 Jun 15, 2009 04:08 AM
