Old Oct 16, 2010, 07:41 AM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
New Product
ESR / IR Meter fo Lipos
ESR / IR Meter for 2 – 6 Cell Lipo Packs
A unit to measure and track the deterioration of your Lipos and compare different makes.
BACKGROUND
This is not a serious commercial enterprise, just a hobby extension. As an active modeller and retired power electronics engineer, I have a particular interest in battery performance and have built myself a unit to measure the internal resistance (ESR or IR) of Lipo packs and cells. It worked so well that I have had a PCB laid out and have built a small batch partially to recover some of the engineering cost, but also to offer the unit to other modellers because it is so useful. It measures both total pack ESR and individual cell ESR , the latter using a Kelvin 4 wire system at high current levels.
Many Lipo chargers read ESR, but they are measuring the charging ESR at low currents, which is very different from discharging ESR at high current, which is what the user is interested in. The difference is often more than double and is further distorted by the endothermic charging effect as the ESR of lipos has a negative temperature coefficient.
ESR tells us more about the likely performance and life of Lipos than any other measurement.
As a pack ages it’s ESR will increase and a serious mismatch of cell ESR usually occurs as a pack nears end of life. The meter allows the user to monitor and measure the deterioration of a pack and individual cells within it. Thus you can accurately measure and quantify the declining performance of your lipos as they age.
DESCRIPTION
The unit is self powered by the pack under test, the only controls are a mode switch and an operate button.
ESR is measured at high current to simulate real operating levels.
When connected to the pack, the display will read the voltage of the pack if switched to ‘Pack’. If the meter is switched to ‘Cell’ and the search connector plugged into the balance connector, the meter will read the voltage of the cell corresponding to the pin positions. Moving the search connector allows measurement of any cell in the pack.
Pressing the operate button will display ESR for about 3 seconds and then revert to voltage. In ‘Pack’ mode it will read the ESR of the whole pack plus the connector and leads. This is a practical measurement as it is measuring the total resistance that the ESC will see in practice.
In ‘Cell’ mode it will read the ESR of just the individual cell that the search wire is connected to, excluding all leads and connectors. In the ‘Cell’ mode the instrument is using a true 4 wire Kelvin connection enabling the user to very accurately compare the ESRs of each individual cell in the pack.
SPECIFICATION
Mode--Measurement Range---ESR Resolution---Accuracy---Volt Res.---Volt Acc.
Pack---0–250 Milliohms--------0.3 Milliohms-----<3%-------40mV------<0.5%
Cell-----0–30 Milliohms--------0.04 Milliohms----<2%-------10mV------<0.3%
Measurement current: 16A.
Maximum Pack Voltage: 30V.
Protection: Unit is protected against reverse polarity on both main power and search wire inputs.
Range: The unit can measure any Lipo pack of 2 – 6 cells in the range of 500mAh – 6000mAh.
Size: 45mm x 100mm x 130mm (1.8” x 4” x 5”)
Weight: 200g (7 oz)
Standard Connector: Deans.
NOTE :THIS UNIT IS NOW REPLACED WITH AN AUTOMATIC RANGING UNIT.
SAME BASIC SPECIFICATION.
FOR DETAILS AND PRICING SEE http://www.rcgroups.com/forums/showp...&postcount=249
Will answer any technical questions I can.
To buy one contact me by PM initially and I will give e-mail address and details.
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Last edited by Wayne Giles; Dec 06, 2014 at 02:25 AM. Reason: UNIT REPLACED BY UPDATED VERSION
Old Oct 16, 2010, 01:48 PM
N2UMK is offline
Find More Posts by N2UMK
N2UMK's Avatar
Clifton, VA
Joined Mar 2003
ESR/IR meter
Wayne -
Very cool! I was just talking about internal resistance with a fellow e-pilot.
He bought a cell-pro charger because it measures ir. Your meter looks very practical.
Nice work!
Pat
N2UMK
N2UMK is offline Find More Posts by N2UMK
Old Oct 16, 2010, 02:03 PM
Cody f86saber is offline
Find More Posts by Cody f86saber
Edge of the World
Cody f86saber's Avatar
Canada, NB
Joined Apr 2006
Good work Wayne Giles. Nice to have someone else with an engineering background around.
Cody f86saber is offline Find More Posts by Cody f86saber
Old Oct 16, 2010, 02:08 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
I agree, and am interested in purchasing one
pm sent
rick.benjamin is offline Find More Posts by rick.benjamin
Old Oct 16, 2010, 02:47 PM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
How exactly does it measure IR? Have you compared the values your device gives to those obtained from chargers that measure IR? Can it measure other chemistry cells?
biskit is offline Find More Posts by biskit
Old Oct 16, 2010, 03:09 PM
Rugby, UK
Joined Feb 2007
It measures the effective resistance by applying a pulse load of controlled constant current load of 16A to the pack, measuring the voltage just before the start of the pulse and again just before the end of the pulse. It then does the maths of subtracting the last figure from the first figure, divides the answer by 16 to give result in ohms and divides that by 1000 to display the answer in milliohms.
I have compared the results with those from chargers and generally they vary by up to 150% more. The meter agrees with the figures from actual loading results when power testing whereas the charger results are higher, I think because of the endothermic effect of charging and because most chargers do not use a 4 wire Kelvin connection so that the connectors are included in cell figures.
The unit will measure any chemistry provided that the pack is between 7V and 30V and the cell voltage is less than 5V.
Wayne
Old Oct 16, 2010, 03:40 PM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Sent $70.40 by paypal
Oh boy, oh boy!
Is it here yet?!
Old Oct 16, 2010, 05:04 PM
Rugby, UK
Joined Feb 2007
Oh boy, oh boy!
Is it here yet?!
I'm sending it, I'm sending it!!
Wayne
Old Oct 18, 2010, 07:00 PM
mtnflyer44 is offline
Find More Posts by mtnflyer44
Rocky Mountain High
United States, CO, Gunnison
Joined Nov 2006
Wayne,
PM sent, I will be travelling until Wednesday pm. Hold one for me.
mtnflyer44 is offline Find More Posts by mtnflyer44
Old Oct 18, 2010, 07:21 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
We would like to purchase one ourselves.
JimDrew is offline Find More Posts by JimDrew
Old Oct 19, 2010, 05:18 AM
Rugby, UK
Joined Feb 2007
[QUOTE=Cody f86saber;16305316]Good work Wayne Giles. Nice to have someone else with an engineering background around.[/Q
There are a lot, of engineers/retired engineers on the forum, I think because modelling is miniature engineering without the responsibility - you get the high, without the hassle!
I found Phil_G on the forums who has done the PIC and software for me on the meter. I just worked out a basic system, sent him a spec, he sent me a board with the display and PIC on it, I built my power operating and analogue measurement system onto it, pressed the button and hey presto! it worked first time. I just had to calibrate it and we had a working system. We have changed and added bits since then such as the voltage measurement facility, but the co-operative excercise worked perfectly and first time.
Wayne
Old Oct 20, 2010, 01:27 PM
Rugby, UK
Joined Feb 2007
Originally Posted by mtnflyer44 View Post
Wayne,
Marvin,
OK, Will do.
Re: your PM, I'm sure you will find that the accuracy and repeatability of the meter will allow you to compare cells within a pack. The resolution of 0.04milliohms means that you can measure a cell on the outside of a pack, place the palm of your hand on the cell for only 5 - 10 seconds, take another reading and see that there is a measureable change in ESR.
Wayne
Old Oct 20, 2010, 01:56 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Nice work Wayne.
Quick question - Have you had the opportunity to corroborate the readings from your meter with any of the commonly used hobby grade chargers that incorporate IR measurement features? (FMA CP10, PL8, iChargers, etc.) And with greatly varying cell capacities? Also wondering how the results compare with a lab grade kelvin meter...
I (among others) have long complained that C ratings are basically useless since there is no test standard. Sadly, C ratings have proven to be an extremely effective marketing tool however as most modelers are not aware that they are very arbitrary. As such, I have been using cell IR as my primary performance indicator for the last few years as it's much simpler than firing up my CBA.
I would be much happier if lipoly manufacturers would print measured cell IR on their packs rather than arbitrary C ratings. This will obviously never happen though as it would likely expose the largest lipoly vendors in a less than favorable light.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Oct 20, 2010, 03:20 PM
Rugby, UK
Joined Feb 2007
[[SIZE="2"]QUOTE=mrforsyth;16338611]Nice work Wayne.
Mark[/QUOTE]
Thanks Mark,
The only Charger I have which reads IR is a Hyperion EOS0610iNET which is a great charger but not very good at measuring IR. It reads between 150 and 250% of the IR I measure, varying with pack size and other factors which I cannot quantify. So much so that I quickly gave it up as a measurement source.
The meter gives the same results that I see in power testing ie the figures agree with the initial drop when the a controlled CC load is applied. Obviously I have checked this against the step change on a memory 'scope using reasonable length pulses of significant load, 10- 20C. I don't have a lab grade Kelvin meter, but have calibrated 10 and 45 milliohm resistors which I use to calibrate the 'Cell' and 'Pack' ranges respectively, and all the meters so far have shown figures within 1% on the Cell range and 3% on the Pack range. Latter is more difficult to be precise as it is not a Kelvin measurement so we have a (variable) connector contact in series.
I agree with you about "C" ratings. They were a joke a few years back and I was beginning to think they were more realistic when claims were 25 and 30C. I now think we are into another lunatic claiming era.
Whilst I agree with your last paragraph, the pack must be soaked at a known temperature (25deg.cent/77deg.F?) and given time to settle if you are comparing packs.
When looking for degradation between cells within a pack this is obviously not a problem and the advantage of the meter it gives an instant answer.
Wayne
Old Oct 23, 2010, 07:46 AM
Rocky Mountain High
Joined Nov 2006
Wayne, money is on the way.
Marvin
Discussion Best fo the West Jets Schwemmer Inland Slope Rebels 0 Oct 14, 2010 05:02 PM
Discussion Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch RJPIoW Electric Ducted Fan Jet Talk 1 Sep 08, 2010 12:05 PM
Question New Low IR Lipos Cells nxtdoor High Performance 75 Sep 06, 2009 04:47 PM
Discussion ESR meter to test Nicad/NiMH ?? 1101 DIY Electronics 3 Jun 15, 2009 04:08 AM
