Old Oct 16, 2010, 03:44 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
Cool
Android Phone App - Center of Gravity Calculator
Here is a free Android Phone CGC (Center of Gravity Calculator) for planes (It can prevent a crash!).
You enter your required CG percentage, measure and enter the tip chord, the root chord and the sweep and it will calculate the position of the center of gravity of an airplane measured back from the leading edge at wing root.
It's free, released as donationware, and is now available on the Android Market.
It's pretty intuitive but instructions are behind the 'Instructions' button
Comments and suggestions welcome!
Please try it out and send it to anyone who might be able to use it! (or point them to this post)
Now available on the Android Market:
QR code or http://www.androidzoom.com/android_a...calc_mctb.html
Graham Dyer
pardus is offline Find More Posts by pardus
Old Oct 16, 2010, 09:01 AM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
I have tried such a style before.
It then gives out results such as required by a Trainer type, instead of the aircraft as advertised, like for an aerobatic type. The new results work fine if all you want is a hotter F3A type than you are not normally used to.
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Oct 16, 2010, 12:43 PM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
You input your OWN required CG, i.e. if you want an agile aerobatic type's CG around 33% then that's what you put in, if you want a trainer type then put in a stable CG of 25%. The app will then output the balance point aft of the root chord leading edge.
The instructions in the app give a guideline however it's up to the experienced pilot to use a CG that achieves the right style of flying that he requires.
All this does is to give a rough idea of the CG of a plane especially for that all-important first flight, it uses formulas which are widely available on the 'net but on your phone at the field. If it prevents an uncontrollable flight ending in a crash then it works!
It is FREE after all
Old Oct 16, 2010, 07:33 PM
Joined Jul 2005
Must be main selling point then.
Wm.
Old Oct 17, 2010, 08:07 AM
richg99 is offline
Find More Posts by richg99
houston tx
Joined Aug 2007
Seems like such a device would be helpful to those of us who don't have a smart phone yet...and can't use an "app". Is there a LINK to a spreadsheet or simple calculator somewhere on the web? thanks Rich
p.s. Oh yes...and thank you for providing a free service that many could find helpful. regards, RG
richg99 is offline Find More Posts by richg99
Old Oct 17, 2010, 12:29 PM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
http://www.nasascale.org/howtos/cg-calculator.htm
http://adamone.rchomepage.com/cg_calc.htm
Old Oct 18, 2010, 02:02 PM
fotoflojoe is offline
Find More Posts by fotoflojoe
Waltham, MA
Joined Aug 2010
Downloaded.
Thanks!
Will report any bugs found.
fotoflojoe is offline Find More Posts by fotoflojoe
Discussion Android Phone Center of Gravity Calculator for planes pardus Product Announcements 4 Oct 25, 2010 03:24 AM
Discussion Android app for calculating Roll Out and Final Drvie Ratios jimbo-69 Car Talk 5 Oct 19, 2010 03:18 PM
center of gravity calculator foamman01 Power Systems 2 Nov 25, 2001 07:19 PM
center of gravity calculator Vinnya42 Foamies (Kits) 6 Oct 22, 2001 09:32 AM
