Old Oct 16, 2010, 01:59 AM
Mr. UD is offline
Find More Posts by Mr. UD
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Question
Ducting for EPP SUKHOI SU-39 (~SU-25 Frogfoot)
Hello scratchbuilders,
been starting to build a SU-39 made of EPP (massive). The Ducts came out quite smooth (for EPP) - so I'm not sure wether I should cover the inlet with plastc-sheet or not
pro's:
-smooth surface
con's:
-my plastic-sheet is not long enough - so I would have a step if I made it out of two sheets
-sheets plus glue=weight
-too smooth is not good too
Whats your opinion?
Mr. UD is offline Find More Posts by Mr. UD
Old Oct 16, 2010, 05:04 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
don't think you need plastc-sheet but you could paint inside. all so i whould run 4000ma 4s lots more thrust same wt. nice job you should kit
space 1 is offline Find More Posts by space 1
Old Oct 16, 2010, 12:32 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Smoother would probably be better, especially behind the fan in the exhaust.
You could use lightweight paper and water based glue. Perhaps erasable typing paper (thin and lighter than normal copier paper), or perhaps tissue like some use to cover free-flight models.
Nice build!
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Oct 16, 2010, 04:49 PM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
I agree, the extra power from smoothing out the intakes and exhaust would outweigh the extra weight. Great job on the build, nice subject.
jumpy is offline Find More Posts by jumpy
Old Oct 17, 2010, 03:08 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Thanks for the replies!
I planed to cover the nozzle with acetate sheet anyway (I only worried about the intakes - they are about 350mm (14") long - the acetate sheet is only 290mm)
I will weight the acetate sheet compared to different kind of paper - lets see how much is the difference...
I'm also thinking about reworking the intake lips - they are made of EPP and quite sharp (but soft). Maybe I will cut away 10mm from the front and replace it by a 5mm, well rounded, balsa-lip (?)
@space 1:
I'm using the 53mm 5000 kv from hk, they pull 50A each with 3s - users of this EDF told about exploding ones when they used 4s - so I guess 3s have to be enough - or I have to use another EDF
Old Dec 20, 2010, 02:45 PM
LSSS is offline
Find More Posts by LSSS
LSSS's Avatar
Ontario, California
Joined Apr 2007
How about an update?
LSSS is offline Find More Posts by LSSS
Old Oct 15, 2011, 11:46 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
... after finishing my Nemesis Air Racer and my Henschel HS-129 B3 I decided to finish my SU-39 too - I will start with it tomorrow after a break of almost one year!
(I will post the further progress at the main threat: L-39 Build log)
Old Oct 15, 2011, 12:15 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
I was wondering what happened to this project. Good luck, look forward to seeing it finished.
Phil
Old Oct 15, 2011, 12:26 PM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
...thanks - she was standing at the end of my workbench, smiling at me for a year now - but I wanted to build (and fly!!) some propellor driven aircraft which are easier to fly for me before finishing that EDF-project
Build Log EPP SU-39 (modernized SU-25 Frogfoot) formerly: lets play "guess the plane" Mr. UD Foamy EDFs 42 Sep 07, 2015 10:01 AM
Question Su-25 Frogfoot.... got any plans? birdlives1955 Foamies (Scratchbuilt) 7 Feb 28, 2011 07:28 AM
su-25 frogfoot Robbie d Electric Ducted Fan Jet Talk 7 Dec 03, 2009 10:02 AM
Help! Steve Griffiths Su-25 Frogfoot Windknot Slope 7 Sep 07, 2008 08:28 AM
Sukhoi 39 Frogfoot Neil Straker Pusher Prop Jet Models 108 Sep 14, 2005 10:15 PM
