Old Oct 15, 2010, 07:03 PM
HUMPHREY1957 is offline
Find More Posts by HUMPHREY1957
I fly SLOPE landings are crash
HUMPHREY1957's Avatar
Central Coast NSW Australia
Joined Nov 2007
STOL Super Cub
Hi Folks. I have a 1/4 scale Sig Cub.
It was crashed when I got it and I have repaired the wing and tail surfaces.
I loathe the yellow scheme and was looking for a different scheme when I found this on UTube. Way too cool.
Short Landing and Take-off Piper Cub (0 min 28 sec)
My major drama is finding suitable wheels and a braking system.
Any help would be appreciated.
Cheers.
HUMPHREY1957 is offline Find More Posts by HUMPHREY1957
Old Oct 15, 2010, 07:16 PM
Joined Nov 2007
Just browsing the tube and found this Hahahahahahhahaha
How to impress yer chick at a hot spring. (3 min 4 sec)
Old Oct 17, 2010, 07:01 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
Wow, I love Cub Yellow, it is my favorite color!
Mode One is offline Find More Posts by Mode One
Old Oct 19, 2010, 08:17 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Humphrey,
Good luck finding suitable Inflatable wheels. The Tundra tires that are installed on the S'cubs in those video are most likely 31" tires (tundra tires typically range from 28" to 33", 31" being the most popular) on full scale.. So a 1/4 scale tundra tire (they are inflatable, and typically run 15psi or less) is 7 3/4" in diameter. I have been looking for a set of tundra tires for a 1/3 scale S'cub or Aviat husky and no-one has them in that size... I've tried looking for inflatable tube tires, but no-one offers them (atleast that i can find) in that small of size either.
invertmast is offline Find More Posts by invertmast
Old Oct 20, 2010, 02:17 AM
Joined Nov 2007
Originally Posted by invertmast View Post
Humphrey,
Thanks for the reply.
I am glad that some one is at least reading.
So I am looking for tyres at least 8"diameter.
I was contemplating making some if I can't find any.
The large scale blokes must get them from somewhere.
Old Oct 21, 2010, 12:29 PM
warhead_71 is online now
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Your best bet might be to try lawn mower or go-kart inner-tubes. You may have to fabricate your own hub, or scavenge a hub from another set of wheels.
*** edit ***
Or, you might be able to use 4x4 rock-crawler wheels/tires from a big 1/6 scale RC truck. Fins some old used ones cheap on Ebay, then chuck them into a drill and take some coarse sandpaper to them to get rid of all the tread and make them into "slicks".
warhead_71 is online now Find More Posts by warhead_71
Old Oct 24, 2010, 04:12 PM
pelle_gris is offline
Find More Posts by pelle_gris
Danmark, Syddanmark, Billund
Joined May 2008
200mm balloon tire. Should work out as a 31" for a 1:4 scale Super Cub.
http://www.topmodel.fr/en/product-de...l-z200-mm-pair
There are several other sizes available (140, 160 and 180mm) in the menu to the left. Click "Airtop"
pelle_gris is offline Find More Posts by pelle_gris
Old Nov 08, 2010, 09:03 PM
RAMFlyer is online now
Find More Posts by RAMFlyer
United States, FL, Orlando
Joined Sep 2003
Mud duck wheels
http://www.mudduckaviation.com/zen/i...roducts_id=209
RAMFlyer is online now Find More Posts by RAMFlyer
Old Nov 09, 2010, 03:03 AM
Joined Nov 2007
Thanks for the tips guys.
I will look at Ride on mower inner tubes for starters and then work out some wheel hubs.
Old Jun 22, 2011, 08:25 AM
qm1usn is offline
Find More Posts by qm1usn
JMRC Cub Driver
qm1usn's Avatar
United States, CA, Oceanside
Joined Sep 2003
I had the 200mm on my 1/4 scale DP SuperCub. Cant recommend them enough. They fit right on the Dubo hub if your running 6" dubro inflateables. They are expensive but look awsome for someone who wants that Bush Plane look.
They are always outta stock but show up once in a while befor they are sold out again. These pics show a direct comparison to the 6" Dubro tires.
qm1usn is offline Find More Posts by qm1usn
For Sale Mini Super Cub ESC, MTR, and TX akozols Aircraft - General - Radio Equipment (FS/W) 3 Dec 30, 2010 08:58 PM
For Sale Super Mini Cub RX/TX and servo's dmanshep78 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 15, 2010 12:17 PM
For Sale Super Cub LP Transmitter & ESC/Receiver RCGIJOE09 Aircraft - General - Radio Equipment (FS/W) 0 Oct 10, 2010 10:13 PM
Discussion Cessna 182 Skylane Vs Piper Super Cub Select RTFs Msioni Scale ARF/RTF 1 Oct 10, 2010 03:57 PM
Discussion Cessna 182 Skylane Vs Piper Super Cub Select RTFs Msioni Parkflyers 0 Oct 09, 2010 02:17 PM
