Old Oct 15, 2010, 07:23 PM
Goofy68 is offline
Find More Posts by Goofy68
Sweden
Joined Sep 2010
Need advice on my fpv project
Hi
Im a long time rc pilot who needs some advice on a fpv project that I have just started. I have been reading alot on these forums and decided to use a Easystar as my platform.
I have just ordered the following:
Camera
http://www.bevrc.com/bev-osc-480pal-p-173.html
Video tx/rx
http://www.bevrc.com/bev-24g-500mw-p...-fpv-p-46.html
OSD
http://www.bevrc.com/ce-osdnewest-an...ion-p-113.html
I need advice on brushless engine+ESC for the Easystar. Any recommendations where I dont have to modify the plane too much. Please add links to where I can order it.
I just learned from another thread that 1 lipo is the way to go these days instead of 2. I need advice on a suitable lipo with link to where to order one please.
I want pan/tilt and found the EZpod from rangevideo.com. Is that a good solution?
http://rangevideo.com/index.php?main...roducts_id=106
Thanks for your advice
Goofy68 is offline Find More Posts by Goofy68
Old Oct 15, 2010, 09:42 PM
kist2001 is offline
Find More Posts by kist2001
Senior Gravity Checker
Tampa, Florida
Joined Mar 2001
If your video is on 2.4 you will not be able to fly around other people. They will have their radio in 2.4 and they are incompatible. I would suggest 900 Mhz in the USA.
For a brushless motor for the Easystar consider a 2000kv motor and a 6x4 prop. Consider a Hobbyking.com motor if you want to go cheap. Go to one of the site sponsors and find a better quality motor. An inrunner will fit the easystar best.
You will need a Castle 25 amp esc....probably 35A if you go for a cheaper esc as they are underrated. Use a separate bec like the Castle Bec to be safe.
Best of luck!,
Ken
kist2001 is offline Find More Posts by kist2001
Old Oct 16, 2010, 07:52 AM
Voguna is offline
Find More Posts by Voguna
Norway, Oslo
Joined Jun 2010
This motor gave me enough power to my Easystar. My eaststar was kinda heavy loaded, with GoPro, 5000 mah, etc..
http://www.hobbyking.com/hobbyking/s...idProduct=6614
I used a 40A esc, but I don't think you need more than 20-25 :P
Voguna is offline Find More Posts by Voguna
Old Oct 16, 2010, 06:23 PM
Goofy68 is offline
Sweden
Joined Sep 2010
Thanks for your replies.
Old Oct 16, 2010, 07:22 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
What radio control are you using?
sim_io is offline Find More Posts by sim_io
Discussion Need advice with my Gentle Lady build. jdraughn Sailplane Talk 3 Sep 15, 2010 03:54 PM
Discussion Briefed My Club On FPV Tonight - Need Advice JBeauford FPV Talk 6 Jan 28, 2009 11:56 PM
Help! Advice on 36mhz antenna placement on Easystar FPV project chancesAU FPV Talk 9 May 05, 2008 12:27 PM
Discussion Advice on 36mhz antenna placement on Easystar FPV project chancesAU Radios 0 May 03, 2008 07:12 AM
Help! Need some advice/pointers/help on my latest project eagle eye Scale Kit/Scratch Built 12 Nov 03, 2006 04:05 PM
