Old Oct 15, 2010, 10:03 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
Android Phone Center of Gravity Calculator for planes
Here is a free Android Phone CGC (Center of Gravity Calculator) for planes (It can prevent a crash!).
You enter your required CG percentage, measure and enter the tip chord, the root chord and the sweep and it will calculate the position of the center of gravity of an airplane measured back from the leading edge at wing root.
It's free, released as donationware, and is now available on the Android Market.
It's pretty intuitive but instructions are behind the 'Instructions' button
Comments and suggestions welcome!
Please try it out and send it to anyone who might be able to use it! (or point them to this post)
Now available on the Android Market:
QR code or http://www.androidzoom.com/android_a...calc_mctb.html
Graham Dyer
pardus is offline Find More Posts by pardus
Old Oct 16, 2010, 03:12 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
I think you must post this in "The Builders Workshop" or "Modeling Science" forums or even in "Electric Plane Talk", there you will get more reaction.
rebell is offline Find More Posts by rebell
Old Oct 16, 2010, 04:47 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Thank you, have done.
Old Oct 24, 2010, 10:00 AM
awayne is offline
Find More Posts by awayne
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Graham,
Have you tried this application out yet? How accurate is it? Will it save your data?
Thanks!
awayne is offline Find More Posts by awayne
Old Oct 25, 2010, 04:24 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Before publishing I tested this application extensively, it is accurate to more than 3 decimal places however it won't save your data as it's intended for 'live' once off use.
All it does it calculate the postion of the CG based on the percentage you enter. If the CG is too far back on a plane you WILL crash! Use this the to prevent destroying your plane.
Discussion Center of gravity 39mikek Electric Ducted Fan Jet Talk 2 Sep 12, 2010 11:27 AM
center of gravity calculator foamman01 Power Systems 2 Nov 25, 2001 08:19 PM
center of gravity calculator Vinnya42 Foamies (Kits) 6 Oct 22, 2001 10:32 AM
