This thread is privately moderated by T3chDad, who may elect to delete unwanted replies.
Old Oct 14, 2010, 09:40 PM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Cool
X-44 Deltastorm IV
Fresh off the workbench!
This is the latest version of the Deltastorm...the X-44. It's powered by a 55mm EDF. Go read the the main thread NOW!
X-44 Deltastorm IV (1 min 36 sec)
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: Latest Projects...
Old Nov 09, 2010, 02:46 PM
aero1960 is offline
Find More Posts by aero1960
Joined Sep 2010
Thanks to you, I did your X-41,(changed the canard to a second set of elevrons and it was a wild thing), duplicated your X-42 and added a virtual rudder(radio mix) and went into ducted fans.
Built not only a single ducted fan, played with two on a F-22. Then moved on to 360 thrust vectoring. What a blast. You should modify your X-44 and you will have the newest toy on the block.
Here is a video of what it can do in tight quarters. I have since added the second thruster and now play with canards to tighten the cobra's.
360 Thrust vectoring with 64mm EDF RC F-22 Foamy (2 min 42 sec)
aero1960 is offline Find More Posts by aero1960
Old Nov 09, 2010, 03:20 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Wow! That's pretty impressive....and inspiring!
Old Nov 09, 2010, 07:05 PM
aero1960 is offline
Joined Sep 2010
I buy cheap ducted fans that usually have a wide gap between the impeller and the hub. Do you have the same condition?
I reduced the gap by using Scotch magic tape and improved thrust. (radio allows me to read % throttle in numbers -was 75 went to 69 to hover). Have you ever thought of experimenting with your ducted fan? Would love to trade data on that.
Even if the tape touches the blade at high speed, there is no damage.
Presently, I have four F-22's with the modification and no problems.
Build Log X-41 Deltastorm T3chDad Foamies (Scratchbuilt) 1614 May 03, 2016 12:10 AM
Sold Parkzone ZX10 5 Ch Transmitter and Receiver CH54 - X-PORT - Buddy Box Port global344 Aircraft - General - Radio Equipment (FS/W) 0 Sep 25, 2010 11:58 AM
Video X-41 Deltastorm Demonstration T3chDad Electric Plane Talk 12 Oct 21, 2009 08:44 AM
Video X-42 Deltastorm II T3chDad Electric Plane Talk 3 Mar 28, 2008 07:26 PM
