Old Jul 09, 2003, 10:04 AM
gmaster is offline
Find More Posts by gmaster
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
SlowStick shopping/mod list help
ok.. gonna take the plunge and get a slowstick and try my hand at some aerial photography.. i know there are tons of mods for the slowstick.. so if you guys can give me suggestions on what exactly I need.. my LHS said they can order the SlowStick for $34.95 and a flight pack that will work with it for around $75.. i think it comes with a 400mah battery though help me figure out what i need so i can order all this at once.. i already have a Triton charger and Hitec Eclipse7...
thanks
gmaster is offline Find More Posts by gmaster
Old Jul 09, 2003, 10:36 AM
t.nollett is offline
Find More Posts by t.nollett
coventry uk
Joined Nov 2002
i would go for 8 cell packs of kan 950's, gives more power to carry a camera, a spare motor and a couple of props unless you do the servo arm mod holding the prop on with an elastic band.
better wheels. keep the receiver well away from the speed controller and motor, i mounted mine on the wing and run the aerial along the wing away from the alluminium boom so you can fly high and get some good shots.
t.n
p.s $40.00 is a lot for batterys look here http://www.electricsquadron.com/
t.nollett is offline Find More Posts by t.nollett
Old Jul 09, 2003, 11:36 AM
Texy is offline
Find More Posts by Texy
Texy's Avatar
Newbury, UK
Joined Aug 2002
t.nollott has given some good advice there - I,m sure they'll be lots more!
Try www.aircraft-world.com for batteries, wheels, props, prop-saver etc.
They ship from Japan for only $2.50 !
Texy
www.btinternet.com/~texy/navled.htm
Texy is offline Find More Posts by Texy
Old Jul 09, 2003, 12:53 PM
gmaster is offline
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
thanks guys.. keep the info/mods coming... i have ordered from NipponDave before at aircraft-world.. took 5 days from japan to usa.. got my hacker setup for my Corona helicopter from him..
Old Jul 12, 2003, 01:22 PM
gmaster is offline
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
can anyone else chime in? i know there has to be more mods that will make the slowstick more durable.. etc..
Old Jul 12, 2003, 01:59 PM
tomlescal is online now
Find More Posts by tomlescal
braidwood,il.
Joined Dec 2002
slow stik mods
get a peice of wood and stuff it in the fuse.the kans are good to.try a gws 400 motor.when building the plane do the rudder first.my slow stik has an astro 010 and 10 cell aaa 720's.
tomlescal is online now Find More Posts by tomlescal
Old Jul 12, 2003, 04:15 PM
coventry uk
Joined Nov 2002
well you can put c/f rods full lenght front and back to stop flutter
i built a 1/4 '' thick balsa tail end, makeing the control serfaces 30% bigger, used a 1"hole cutter to reduce weight then covered
looks good if you cover with translucent colored film.
but the best mod is going brushless with li-polys.
left standard they are a great plane.
t.n
Old Jul 12, 2003, 04:27 PM
SHOCKERS is offline
Find More Posts by SHOCKERS
Joined Jun 2003
check here
http://www.rcgroups.com/forums/showt...hreadid=122951
SHOCKERS is offline Find More Posts by SHOCKERS
Old Jul 12, 2003, 04:59 PM
gmaster is offline
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
Thanks guys.. I really appreciate it.. Shockers.. thanks...
Old Jul 12, 2003, 05:23 PM
MooseFlyR is offline
Find More Posts by MooseFlyR
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
Do a search for other numerous slowstick threads. Though well intended, much more reliable info will be found elsewhere.
MooseFlyR is offline Find More Posts by MooseFlyR
Old Jul 12, 2003, 05:53 PM
TRAVO is offline
Find More Posts by TRAVO
Airplane Addict
NorthWest Houston
Joined May 2003
I put balsa down the fuse, replaced aluminum tube with brass and epoxied everything.
Since your no stranger to Brushless.........
SS performs great on BL.
Currently flying with a PJS800 and 8 cell KANS, 11x4.7 SF. It goes vertical for as long as you can hold it from leveling out.
The PJS1000 would have been better.
I have LEDS, an epoxied wing from a midair with a three dee, and have flown with a bombbay loaded with plastic parachuters.
Added strapping tape spar.
Flies inverted, outside loops, vertical and can hover for about 3-5 seconds.
My favorite plane for relaxing after a nervous flight with my nemesis.
TRAVO is offline Find More Posts by TRAVO
Old Jul 12, 2003, 06:24 PM
Rivethead is offline
Find More Posts by Rivethead
Pocono Mountains, PA
Joined Jan 2002
The Slow stick is a great plane!!
Mods:
- Wheels
- changed to a 12x60 prop
- got rid of the battery holder and replaced with bass wood 1/8" plate and velcro
- I used a dab of hot glue to stop all the mounts on the square shaft from sliding.
Chris
Rivethead is offline Find More Posts by Rivethead
Need SlowStick shopping list gtessau Beginner Training Area (Aircraft-Electric) 16 Feb 12, 2005 09:03 AM
Slowstick motor mod and controller question... David L. Parkflyers 1 Feb 06, 2004 12:09 AM
Complete Herr Mini Sport Mod list GHarvey Parkflyers 1 Oct 05, 2003 07:14 PM
Final Stretch of Slowstick Assembly...Need A Little Help DWavs Parkflyers 16 Mar 18, 2003 09:19 AM
Skimmer Mod List Started amike_321 Electric Sailplanes 5 Mar 09, 2003 10:44 PM
