Espritmodel.com Heli Air
Old Oct 18, 2010, 06:37 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Got the 1st set of 4 ESC's wired up and tested it and it flew. Now just soldering the 2nd set of 4 ESC's and cross my fingers
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Oct 18, 2010, 08:30 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
It Flies
OK after wiring it multiple times and switching the props multiple times and flipping it over and bending a motor shaft I finally got it wired right. I lifted it up and hovered with only 7 motors. Now gonna replace the bad motor and see what happens.
Site Sponsor
Old Oct 18, 2010, 10:41 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Got it all setup and flying but it is not powerfull enough. Gonna try it outside Tue and see if it flies better. The batts get warm fast also so it might be too big of a draw on the batts. I used a Hyperion 900mAh 45c 3S batt so I am using the highest C rating batt I can buy.
Site Sponsor
Old Oct 19, 2010, 09:59 AM
mkmkmk13's Avatar
USA, CA, Anaheim
Joined May 2007
try 2 bladed props
do you have a watt meter?
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Oct 19, 2010, 10:24 AM
mkmkmk13's Avatar
USA, CA, Anaheim
Joined May 2007
i forgot you have 8 motors
900 mah 45c = .9X45 = 40.5amps
if every motor is pulling 5 amps 8x5 = 40 amps
very close to the battery's limits
you need a bigger battery
Old Oct 19, 2010, 10:56 AM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Originally Posted by mkmkmk13 View Post
try 2 bladed props
Thanks I have the 7" 2 blade props coming Wed or Thur. I will try those. I do not have a watt meter.
Site Sponsor
Old Oct 19, 2010, 11:00 AM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
For my 4 motor setup with the same ESC's/motors I was using a Outrage 450mAh 35C 3s and thats what gave me the best performance and 6 mins flight time which is all I need. I figured double the motors and over double the batt and I would be fine.
Site Sponsor
Old Oct 19, 2010, 12:16 PM
Clearwater, FLorida !
Joined Sep 2009
What about two of those batteries "taped" together? ;P one for each set of 4 motors
witespy is offline Find More Posts by witespy
Old Oct 19, 2010, 12:24 PM
mkmkmk13's Avatar
USA, CA, Anaheim
Joined May 2007
that 7" prop will probably run much hotter
when experimenting with props and motors you need a watt meter
try the same props with a 2s lipo
2000KV is a bit high so 7.2v should calm things down
Old Oct 19, 2010, 12:47 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
I was contimplating that same idea. This way there is less draw on the batts.
Site Sponsor
Old Oct 19, 2010, 12:50 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
I thought a 7" 2 blade prop would run cooler than a 5" 3 bade prop. That would be 7" prop area with a 2 blade verse 7.5" prop area w/3 blade.
Site Sponsor
Old Oct 19, 2010, 07:48 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Perhaps this is a dumb question, but why are the bottom props on backwards?
Are they off when upright and only turn on when inverted?
If so, how do you transition from upright to inverted?
Pat Mackenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Oct 19, 2010, 08:50 PM
mkmkmk13's Avatar
USA, CA, Anaheim
Joined May 2007
I think Pat got it
The bottom props are on backwards
Old Oct 20, 2010, 12:37 AM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
I think Pat got it
Thats the only way to set it up. I tried every setup and thats the only combo that works. They are not on backwards by accident.
Site Sponsor
Old Oct 20, 2010, 01:06 PM
FRANCE
Joined Dec 2004
hi friends Z06
i just saw your forum and that is funny because i just made something like you but it is a tricopter not a quadri
anyway i will post pictures soon , as i just made the frame
i am on the electronic set up now
KABAL99 is offline Find More Posts by KABAL99
For Sale Worlds smallest BL 3s 3D Micro Walkera w 3 main, tail, motors crash kit xtra 4in1 blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 09, 2010 01:27 AM
Discussion Worlds smallest V-8 mikefast Life, The Universe, and Politics 2 Apr 25, 2009 04:37 PM
Discussion Worlds Smallest Air Operated Micro Retracts just got smaller LJE4357 Electric Ducted Fan Jet Talk 2 Mar 29, 2008 04:49 AM
Discussion NANO-TORQUE 0.8 - Worlds smallest 9N-Brushless-Outrunner flattermann Electric Motor Design and Construction 6 Apr 26, 2007 01:52 PM
Worlds Smallest Micro Heli, Just Kidding MicroRC Beginer Electric Heli Talk 4 May 23, 2002 07:03 AM
