Old Oct 14, 2010, 01:13 PM
Warthog_Fan is offline
Find More Posts by Warthog_Fan
United States, NY, Endicott
Joined Jun 2006
Sources for Carbon Fibre, Aluminum, and Cardboard Tubes.
Guys,
I'm going to build a vintage kit of an aerobatic biplane that was designed in 1973. The wing span is 55". As with many larger wings of this time period, they are built in two halves, and then glued together in the center. Then you have to add a 4" wide strip of fiberglass or polyester tape over the center section to give it adequate strength.
I don't want to use the tape. I'd like to use carbon fiber or aluminum tubes in the wings as spars, kind of like the newer ARFs do that have larger wings. This makes for a neater covering job without the bulge of the tape on the center section. It also would allow me to take the two wing halves apart for easier transportation.
Does anyone know of a source for the carbon fiber and aluminum tubes, and also the cardboard or fiber tubes that are permanently installed in the wing panels to receive the spar tubes?
Thanks in advance.
Bob
P.S. I also posted this question in the "Fuel Plane Talk Forum".
Warthog_Fan is offline Find More Posts by Warthog_Fan
Old Oct 14, 2010, 01:55 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Aerospace composites is a good one.
I'd suggest instead of cardboard that you use thin wall K&S aluminium tubing as the slip tube. At this size with 3/8 carbon rod as the joiner it'll provide a more slop free fit than some other options.
Also with the aluminium tubing you can build the whole wing as one but leave a slight gap in the center between the facing ribs and then just cut through the tubing and file it off flush. Or better yet leave about a 3/8 inch of gap so you can cut the tube and then install 3/32 birch ply face ribs that are the full airfoil shape and then file the tubing back flush to the face ribs.
BMatthews is online now Find More Posts by BMatthews
Old Oct 14, 2010, 02:59 PM
Joined Jun 2006
Thanks, Bruce.
So you would recommend a carbon fiber rod, as opposed to a carbon fiber tube?
I've never used carbon products in building kits before so I really don't have any prior experience as to what works best in which application.
Bob
Old Oct 14, 2010, 03:43 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
This place has a good selection of carbon, fiberglass, and ferrules:
http://www.goodwinds.com/
-Stone1295
Stone1295 is offline Find More Posts by Stone1295
Old Oct 14, 2010, 08:09 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Originally Posted by Warthog_Fan View Post
Thanks, Bruce.
Bob
For the case of a 55 inch biplane wing where the space between the upper and lower spar caps will only be about 1/2 to 5/8 inch yes I do. Just because you are not looking at the same sort of thinner wall tubes as joiners as you would see on a model with a much thicker wing. If you can find some "tubing" that has really thick walls, such as 3/8 tube with 1/4 or less ID, then sure, go for it. But that is unlikely so you may as well just go with a solid rod for this case. In any case the added weight of the carbon rod over a suitable tube will be diddly squat so it's not worth the trouble of hunting down such a beast.
And that way you can get some K&S 13/32 aluminium tube for the slip tube that you embed in the wing roots between the spar caps using epoxy and micro balloons as a combination filler and glue.
Wanted Carbon Fibre flats, tubes, rods... retiredVTT Aircraft - General - Miscellaneous (FS/W) 2 Nov 29, 2009 04:17 PM
Carbon Fibre tubes for fuz - further thought Nigelp Composites Fabrication 1 Jul 08, 2004 06:18 PM
Carbon Fibre tubes for fuz - Help ! Nigelp Composites Fabrication 2 Jul 06, 2004 08:59 AM
Carbon Fibre Tubes - HELP! John Webb Electric Plane Talk 10 Nov 29, 2002 07:53 PM
