Old Oct 14, 2010, 01:08 PM
joy4u is offline
Find More Posts by joy4u
joy4u's Avatar
India
Joined Feb 2006
How to seperate channel 6 from channel 1 in Futaba T6EXHP..??
Someone please help me out here...
I have a FUTABA T6EXHP Tx...
I have a AUX switch to control the 5th channel but my 6th channel is controlled by the throttle stick as its engaged with the 1st channel...
How do I separate the 6th and control it with a switch like the 5th channel...??
joy4u is offline Find More Posts by joy4u
Old Oct 14, 2010, 01:26 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
What are you flying? Cause sound like the TX is in HELI mode.
freechip is offline Find More Posts by freechip
Old Oct 14, 2010, 01:40 PM
joy4u is offline
joy4u's Avatar
India
Joined Feb 2006
The TX is a HELI tx...
It does not have Airplane programming...
I am flying a quad..
Where I am using the sticks to fly the quad and need two extra channels to activate GPS POSITION HOLD and activate HEADING HOLD...
So is there ant hardware hack so that I can seperate the 6th channel from throttle...??
Old Oct 14, 2010, 03:01 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Well you're 6 channel is for Pitch and unless you can tell it not do to pitch you're out of luck. Mite be time for you to upgrade radio. 7C if you're Futaba guy.
Old Oct 14, 2010, 10:34 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I don't know the details of that transmitter, but you should be able to deactivate the built-in throttle->Ch6 mix by doing Ch6->Ch6 -100%. Then use another mix to mix Ch7->Ch6, setting a switch to control Ch7.
This is all hypothetical as I use JR, so maybe someone can verify or give better advice.
EDIT: Sorry. You don't have channel 7! I didn't look back to the original post.
So I guess you can't do it.
Daedalus66 is offline Find More Posts by Daedalus66
Old Oct 14, 2010, 11:31 PM
joy4u is offline
joy4u's Avatar
India
Joined Feb 2006
@ Daedalus66
No that is not possible...
Here is manual of my tx..
FUTABA T6EX-HP MANUAL
For Sale Reall Flight Expansion packs 1-6 deal Now selling seperate drifter88 Aircraft - General - Miscellaneous (FS/W) 2 Oct 01, 2010 11:22 AM
For Sale 6 Channel CCPM TX EFlight w/4-in-1 unit gargoyle7 Aircraft - Electric - Helis (FS/W) 3 Sep 10, 2010 03:45 PM
Discussion How do I expand 1 or 2 chanels in my FUTABA T6EXHP after the ASSAN 2.4Ghz hack..?? joy4u DIY Electronics 5 Jul 25, 2010 06:53 AM
Question Seperate Rx from 4-in-1 JoeSay Coaxial Helicopters 5 Aug 19, 2008 09:37 PM
For Sale Radio: Futaba T6EXHP 72mhz w/ 1 Futaba 6ch R146iP RX & 1 Futaba 9ch RP-R129DP RX akguanja Aircraft - General - Radio Equipment (FS/W) 9 Apr 28, 2008 01:53 PM
