United States, CA, Rocklin
Joined Sep 2003
ok great Thanks |
Got my first flight in this am after the rebuild. Everything went well but I did notice quite a big difference in the power of my new system. I ran a stock prop and lost quite a bit of top speed and punch for that matter. That doesn't really surprise me as the turnigy sk3548-900 I installed is rated @ 100kv less than stock. I am going to try a 12x6 for the next flight. I think that should be a good combo and is the rated prop for that motor. I haven't flown the bird for a while now so I can't really notice a huge difference in the new Hitec's. They worked flawlessly and the bird cae down when I told it to so they are a success. I Was excited about the built in flight logging in my new superbrain esc but during the tornado I created rebuilding the yak I misplaced that tiny usb dongle. Hopefully I can find it soon.
OK, my replacement motor shaft from HH arrived today. What is the technique for removal and installation of the motor shaft using a pair of small C clamp pliers and the right size allen wrenches? What are the right size allen wrenches? Thanks again for the help! |
Think the allen wrench is a 1.5mm. If it was a stock motor (not a replacement bought from Eflite) you are going to have a very hard time getting the set screws out. Heating them with a solder iron prior to trying to remove them is a good idea. If you strip the head out and can't get them out, call HH and make them give you a new motor. The set screws are glued in on ones that come with planes, but not on ones you buy as replacements. OR (not recommended as this is one more place where shotty manufacturing is catching up with HH and they need to be held accountable) you can drill out the set screw that gets stuck. It's a pain to do this and you will likely have to drill the hole larger afterward and tap for a 2mm screw or something. Once that is done, place the forward side of the motor on two pieces of 2x4 with the shaft between them (or drill a hole larger than the shaft in one 2x4). Take a 4mm shaft or a smaller than 5mm drill bit that you don't mind ruining; place the flat side on just the shaft of the motor and tap with hammer (use a little force, but don't just slam the hammer down). Continue to tap it with the hammer until the old shaft is removed from just the back portion of the motor casing. After it is free from there you should be able to pull the motor apart and then slide the old shaft the rest of the way out of the front of the motor. Put the c clamp and washer (don't lose this when pulling the old shaft out) on the new shaft. Slide the new shaft in from the front side of the motor and replace the back housing. Line up the two flat spots on the shaft with the set screw locations on the back half of the motor. Lightly tap the shaft back in to the rear housing until flush. Reinstall set screws using removable loctite.
| Thread Tools | |
| Sold E-flite 4-Site like new BNF Version | MK2 | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Sep 30, 2010 06:51 PM |
| Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? | MerlinKing | Parkflyers | 3 | Jan 20, 2010 08:45 PM |
| Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? | MerlinKing | Scale Electric Planes | 1 | Jan 20, 2010 06:29 PM |
| Alert Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... | jamiekerr | 3D Flying | 15 | Aug 07, 2007 12:24 PM |
| Poll Part of Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... POLL | jamiekerr | 3D Flying | 1 | Aug 07, 2007 02:55 AM |
