Old Mar 11, 2011, 05:26 PM
helicow is online now
Find More Posts by helicow
Gravity gets me down.
helicow's Avatar
USA, FL, Brooksville
I have had some good luck with these: http://www.headsuprc.com/servlet/the...P--13-x/Detail
Not APC's but what I have.
helicow is online now Find More Posts by helicow
Old Mar 11, 2011, 06:46 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
Stupid....
This is absurd...I've got other things I have to work on...I don't have hours to spend adding ounces to the prop trying to get it balanced....
StormJunkie is offline Find More Posts by StormJunkie
Old Mar 11, 2011, 09:32 PM
Whoooo!
Summerville, SC
Joined Jan 2009
Regarding failing servos especially the elevator...I just went back and rebound/completely reset my DX7 for my Yak.
Is it possible that people are adjusting the travel prior to hitting the reversing switch for a particular surface? Here are the settings I had to program for travel adjust to get the correct throws (I kept them toward the lower end of the tolerances stated in manual)...
Ailerons------------Rudder--------------Elevator
----Left: 124%--------Left: 124%-------- Up: 116%
----Right: 90%--------Right: 130%-------Down: 140%
These travel adjust settings achieved the correct throws measured with calipers. So if you were using a DX7 and AR7000 (like myself) and you set the travel adjust and THEN reversed the elevator servo it would try and make the up elevator travel 24% more then recommended. The elevator also has the lowest range 48mm-50mm. 2mm tolerance when the other surfaces are 5 & 10mm.
Just wondering? Want to help keep myself or anyone else from loosing a plane due to servo failure if it can be helped.
Old Mar 11, 2011, 11:54 PM
rcpilot_971 is offline
Find More Posts by rcpilot_971
United States, CA, Rocklin
Joined Sep 2003
what hacker motor are you guys using to replace the stock motor and are you using the stock speed control and battery my motor is verry loud and seems like its slipping or has lost some power im have about 12-15 flights on it and have been using a apc 12-6
from the first flight
Thanks Tim
rcpilot_971 is offline Find More Posts by rcpilot_971
Old Mar 12, 2011, 03:20 AM
tele1974 is offline
Find More Posts by tele1974
tele1974's Avatar
USA, OH, Olmsted Falls
Joined Feb 2007
I have a Torque 2818T/900 motor and I am wondering if it would work with this kit. Any one have any idea.
tele1974 is offline Find More Posts by tele1974
Old Mar 12, 2011, 10:35 AM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Thanks Tim
Have you checked you motor mount for signs of cracking? A cracked motor mount can cause similar problems that you described.
krexken is offline Find More Posts by krexken
Old Mar 12, 2011, 11:03 AM
Joined Sep 2003
yes the motor mount looks good I did get the cnc motor mount just in case mine breaks but now that I have the cnc one as a back up mine motor mount will never break lol
Tim
Old Mar 12, 2011, 11:10 AM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
I would run the cnc and use the stocker as a backup. My guess is if you bend the cnc bracket you will need more than a new mount to fix the plane. Lol
tominator06 is offline Find More Posts by tominator06
Old Mar 13, 2011, 01:48 PM
Whoooo!
Summerville, SC
Joined Jan 2009
The stock props are very hit and miss and they are likely what's causing the excessive vibration. Out of 5, I have one that is sort of kind of ok.
From the flightline today
Old Mar 13, 2011, 07:08 PM
Joined Sep 2003
would a hacker 30-12L have the same perfamance as the stock motor or better using a 12x6 prop
Old Mar 13, 2011, 07:18 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
The APC 12x6 prop rocks. You will need a washer to make up the space on the prop nut. Runs smooth and NO NOISE......
jimmy34256 is offline Find More Posts by jimmy34256
Old Mar 13, 2011, 07:35 PM
Joined Sep 2003
yes I was using a 16x6 on the stock motor but I want to get a hacker and run the the stock esc and 4s battery and 12x6 prop
Old Mar 14, 2011, 12:13 AM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
53oz set up.. Just one of those days when everything goes wrong. Put every plane i flew today into the ground .
E-Flite Carbon-Z Yak 54 Crash.. When Yaks Attack! (6 min 14 sec)
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter Mini T Copter Fun
Old Mar 14, 2011, 08:52 AM
Mustangman50 is offline
Find More Posts by Mustangman50
Watch my trickeration! Oops...
Mustangman50's Avatar
USA, SC, Goose Creek
Joined Dec 2010
nice video. Love that hover! I would like to fly like that. You are obviously more advanced and much more talented than I am. Keep the videos coming!
Mustangman50 is offline Find More Posts by Mustangman50
Old Mar 14, 2011, 11:43 AM
ZackJones is offline
Find More Posts by ZackJones
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
Hate to tell you bud but you'll have to fly something other than your warbirds to do that kind of fancy flyin'
ZackJones is offline Find More Posts by ZackJones
Sold E-flite 4-Site like new BNF Version MK2 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 30, 2010 06:51 PM
Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? MerlinKing Parkflyers 3 Jan 20, 2010 08:45 PM
Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? MerlinKing Scale ARF/RTF 1 Jan 20, 2010 06:29 PM
Alert Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... jamiekerr 3D Flying 15 Aug 07, 2007 12:24 PM
Poll Part of Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... POLL jamiekerr 3D Flying 1 Aug 07, 2007 02:55 AM
