Jan 06, 2013, 06:53 AM
Joined Sep 2010
Originally Posted by davebales
I've been flying a few months now. Started on the Super Cub. Moved up to the F27Q. I'm a bit gun shy on flying this one. How does it handle? I know my F27Q turns on a dime. Sometimes, a bit too well. I'd like to NOT destroy this one as I did my Extra 300 (not my fault, wing dislodged). How does it fly in wind to 15 mph?
What kind of throws should I start with? I could use the recommended throws in the manual but as I said, I don't want to nose this one in. As it stands, I've already replaced the prop just taxiing. Funny story, taxiing to test the rudder controls and sneezed. Gunned the throttle and hit some rather tall grass. Plane nosed over and snapped the prop. No biggie.
Also, how much shake should expect. It looks as though the prop shaft is just a smidge off. Not much, perhaps 1mm but it's not straight. I imagine at WOT, this would come into play.
Thanks for the help. LOVE this board and this hobby!
Too lazy to find the manual to check out what it says, but the yak will fly great with very little movement of control surfaces for starters. You can always work your way up in easy steps to see what you need or can handle. You can start in the neighborhood of 25% and go from there. It won't do 3d at those settings, but flies great aerobatics at really low settings. Get the movement down for starters if you are not an expert, then you only have to deal with the speed and throttle response which the stryker should have already helped you with.
