Old Aug 28, 2012, 07:10 AM
jwiebe is offline
Find More Posts by jwiebe
Canada, AB, Calgary
Joined Jun 2011
I hit the credit card last weekend... from HK: twoTurnigy Nano-tech 3000mAh 4S 24C-50C lipos and various sizes of Turnigy ultra-light wood props and from HW/Falconsekido a Platinum 80A ESC (nice price). I've gone through 3 ESCs (1 burnout, 2 in water) this season and am tired of paying Castle prices. Also a new fuselage from Horizon since this one is looking pretty beat up after two major crashes. If it makes it to the end of the season in one piece I'll rebuild it over the winter.
Was a bit tricky to trim after the last major nose repair and hard to tell the result in the 15-20mph gusts we had. It was also the first time out with the HS-82MGs on the ailerons and it seemed to have a problem centering. I suspect I may have over tightened the aileron hinges, or possibly glued one or more of the hinge points out of alignment causing some binding. The servos buzz and I don't think they should.
jwiebe is offline Find More Posts by jwiebe
Old Aug 28, 2012, 09:58 AM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
I have the same problem on one of my wings, I reglued the aileron hinge tabs and now there is binding, the 5085 won't center perfect on it. I tried 2 different servos and same problem. The hobbywing esc is working great in the yak so far, I will be sticking to these esc's from here on out, great quality at a great price!
slo-fly is offline Find More Posts by slo-fly
Old Aug 28, 2012, 11:18 AM
cavwrench is offline
Find More Posts by cavwrench
United States, IL, Volo
Joined Apr 2006
Guys, What is the best stock replacement prop for the carbon z in stock form with 4S batteries?
cavwrench is offline Find More Posts by cavwrench
Old Aug 28, 2012, 11:20 AM
DaxFX is offline
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
i have a few Master Airscrew 12x6 electric, waiting for be needed.
DaxFX is offline Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old Aug 28, 2012, 11:35 AM
Joined Apr 2006
So a APC 12x6 would work?
Old Aug 28, 2012, 11:48 AM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
Yes. That's what I use. Just make sure you balance it.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Aug 28, 2012, 12:11 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
Most popular props (I'm guessing) would be apc 12x6 (more speed) and the apc 13x4 for more torque.
Old Aug 28, 2012, 12:29 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
I also got an APC 13x4 but have not try it yet because i read here will draw too much amps... can I used with stock setup ?
Old Aug 28, 2012, 01:06 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
Some of my buddies run the 13x4 all stock and have had no problems, throttle management is a good idea with this prop, hold full throttle for less than 10 seconds and you should be good. Not sure how many amps it pulls but I don't think it would pull more than 75 amps.
Old Aug 28, 2012, 01:26 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
some 1 post was 72-76amps nut sure but was close to that. that is the reason i didnt try it the esc is 60a
Old Aug 28, 2012, 01:35 PM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Originally Posted by jwiebe View Post
The Yak didn't pull out of a roll over the lake a couple weeks ago and entered the water at high speed, snapping the nose off and breaking it in three pieces. We have a rowboat at the club for rescues. Anyway, lots of white Gorilla glue later, it's back in one piece and I ran some numbers before taking it up tomorrow:
Hyperion 3025-8
Hitec HS-82MG (x4)
Zippy 4S 2800mAh 30C
Eflite 60A ESC (stock)
AUW: 4.00lb (64oz) (c.f. stock 3.75 - 3.81lb, about 5% heavier)
Prop ---- Amps -- Watts-- Thrust (lb)
12x6 ---- 62.3 ---- 860 ---- 5.8
12x8 ---- 70.1 ---- 944 ---- 5.3
13x4 ---- 55.4 ---- 780 ---- 6.3
13x6.5 -- 69.6 ---- 930 --- 6.9
All props are APC thin electrics. Static thrust measured with a fishing scale.
The plane balances without any extra weight, battery at the rear of the compartment. The missing pilot seems to counterbalance the slightly heavier motor.
A 13x4 draws less amps than a 12x6. No worries. You'll definitely lose some speed and make much more noise.
krexken is offline Find More Posts by krexken
Old Aug 28, 2012, 01:50 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
Alucard did some testing on stock yak and results were 1025 watts @ 74 amps for apc 12x6, 975 watts @ 68 amps on 13x4 (posted on page 204).
Old Aug 28, 2012, 02:03 PM
Joined Apr 2006
So for all around flying a 13x4 would prob be better? I dont want or need this thing to be a rocket ship. I would rather it have more power to get out of stuff then have it go 90mph.
Old Aug 28, 2012, 04:23 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
If you like high speed aerobatics the 12x6 is great. If you like harriers, hovering and such the 13x4 is the better choice. They are both good for all around flying except the 13x4 is slower and will slow dives down better, more climbing power too.
Old Aug 28, 2012, 04:30 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
Since my bad vision i enjoy more the harrier arround and slow fly so this weekend i will put on the 13x4 and give a try.
Sold E-flite 4-Site like new BNF Version MK2 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 30, 2010 06:51 PM
Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? MerlinKing Parkflyers 3 Jan 20, 2010 08:45 PM
Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? MerlinKing Scale ARF/RTF 1 Jan 20, 2010 06:29 PM
Alert Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... jamiekerr 3D Flying 15 Aug 07, 2007 12:24 PM
Poll Part of Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... POLL jamiekerr 3D Flying 1 Aug 07, 2007 02:55 AM
