[QUOTE=IEATSRT;20809312]Yup lots to play with, lots invested. I keep a ton of spare parts on hand also, so times like those when I'm tinkering I can usually make something work. Attached some pictures of the extreme flight spinner and Zinger prop. I'm running 14x5 but haven't test flown it yet.. springs not far. My motor is 870kv so I pitched up to 5 and have a bit more airflow by going 14 inch diameter. Back to what I was checking into earlier it is hard for me to tell for sure but think it is the stock adapter on there, sorta lost track but looks like it. Though it is the stock adapter I used a different piece with it (the one that fits over top of the screw that the spinner back plate buts up against. I had to use a shorter one as the 870 kv motor is a bit longer than the stock motor. So in order to get the spacing I wanted I robbed that from a different adapter to get my spacing. Hope this makes sense. All that said you should be able to use the extreme flight spinner. Perhaps someone else can chime in with others that have worked. I personally like the larger spinner more than the stock one as it covers up the motor and mount better. Also, I can swap it with the red one from the 3dhs extra back and forth if I want. Just built the extra 330 sc... can't wait to fly it! Transmitter sounds like it will do the trick. I don't really like helis like planes... started in the hobby to old to be good at them... they are challenging, I mostly just fly my planes. Hope this helps, let me know if you need clarification. Cheers.
Brandon[/QUOTE With that bigger prop, hovering will prolly be more stable i bet. Do you remember if the stock motor gets hot? I was wondering if the smaller spinner allows the motor to cool better? Ive seen some spinners that are basically a small cone nut which allows more air to hit the motor. Just wondering if you had any thoughts on this. |
[QUOTE=Dr.JJ;20809722]
For those with Phoenix Sim
I only had about 8 flights with my CZ Yak, winter hit and haven't had a chance to fly her again. From what I remember worked on a variant last couple days. For those of you with more flights on her and are running phoenix let me know what you think. Feel free to make adjustments and re-post your variant if I'm way off the mark. Plane loads as the mini yak with my adjustments. Also here's the cz yak scheme that looks great. Cheers |
Scottsdale Arizona
Joined Dec 2009
[QUOTE=IEATSRT;20810445]
Same here. I put in power 25 just cause I had it as a spare, but I'd like to try a torque or hacker with similar specs to your Hyperion. I have castle 80 amp was also a spare as well as castle ubec. Hitec 85 mg servos as well. The only thing stock is airframe. Looking forward to summer.
| Thread Tools | |
| Sold E-flite 4-Site like new BNF Version | MK2 | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Sep 30, 2010 06:51 PM |
| Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? | MerlinKing | Parkflyers | 3 | Jan 20, 2010 08:45 PM |
| Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? | MerlinKing | Scale Electric Planes | 1 | Jan 20, 2010 06:29 PM |
| Alert Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... | jamiekerr | 3D Flying | 15 | Aug 07, 2007 12:24 PM |
| Poll Part of Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... POLL | jamiekerr | 3D Flying | 1 | Aug 07, 2007 02:55 AM |
