Old Aug 08, 2011, 06:07 AM
helicow is offline
Find More Posts by helicow
Gravity gets me down.
helicow's Avatar
USA, FL, Brooksville
Originally Posted by JJ460 View Post
I found the info regarding the Hitec servos that could be used as good replacements. Has anyone found a less expensive source or servo option? JJ
Someone on this forum has suggested theses. I have never used them, so can not say one way or the other.
http://www.hobbyking.com/hobbyking/s...idProduct=6608
helicow is offline Find More Posts by helicow
Old Aug 08, 2011, 06:09 AM
vygec is offline
Find More Posts by vygec
London, UK
Joined Mar 2010
whats the recommended battery for this plane?
would this be a good choice?
http://www.hobbyking.com/hobbyking/s...idProduct=9464
vygec is offline Find More Posts by vygec
Old Aug 08, 2011, 06:51 AM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
Really heavy, and underpowered. With the APC 12X6 and 13X4 props you will draw about 70A WOT. 3300X20C=66A, You want the constant rating on the battery to at least match the current draw, however using an even higher discharge lipo will keep the batteries cooler, and can pick up an amp or two and up to 50w more just by switching the battery. Once the discharge gets above 50% higher than the draw there is no real benefit, for 70A, that would be 105A, that would be a 2650mah 40C, or 3,000mah 35C. For 3D, something lighter, prefferably under 300g is better, the 2650mah 35C nanotechs put out 92A, and weight just under 300g, probably the best mix of weight and flight duration for 3D. Some have been using 40 and 45C 2200mah batteries, they can come in around 250g, and can get a tailheavy CG if desired for 3D, although flight times will be short. If you mostly fly conventional aerobatics or pattern, a 3,000mah 30C might be better, the weight isn't as much of an issue, and can actually be beneficial to some degree in the wind. Problem is once you get near 350mah, you need to cut the bay deeper to get a neutral CG, A 300g LiPo pushed all the way back is about neutral.
alucard0822 is offline Find More Posts by alucard0822
Old Aug 08, 2011, 10:04 PM
JJ460 is offline
Find More Posts by JJ460
United States, OR, Sherwood
Joined Jan 2009
replacement servos?
Other than the HS servo's, what other less expensive servos would work for 3D type work??
JJ460 is offline Find More Posts by JJ460
Old Aug 09, 2011, 10:02 AM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
I use these with Dubro's long JR arms. You'll need to enlarge the opening a bit but it's no problem. http://www.headsuprc.com/servlet/the...-19g-TP/Detail You can get them from Hobbyking also for about $9.50 if you don't mind the wait.
krexken is offline Find More Posts by krexken
Old Aug 10, 2011, 02:09 AM
crobar is offline
Find More Posts by crobar
crobar's Avatar
Joined Apr 2009
I may have missed this in the manual but what is the most accurate way to locate the manufacturers recommended cg near the fuselage versus out at the wing tips?
crobar is offline Find More Posts by crobar
Old Aug 10, 2011, 07:07 PM
FlipFlops365 is offline
Find More Posts by FlipFlops365
Tom Holdren
FlipFlops365's Avatar
USA, WI, Appleton
Joined Oct 2010
what are you guys using for washers when installing larger wheels on the main landing gear to prevent the wheel from sliding?
FlipFlops365 is offline Find More Posts by FlipFlops365
Old Aug 11, 2011, 12:37 AM
crobar is offline
crobar's Avatar
Joined Apr 2009
I use wheel locks, one on the inside and one on the outside of the wheel. I am using 2.5" thin white spoke wheels and they leave a lot of space on the axle.
Old Aug 11, 2011, 06:26 AM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Just get it perfect while supporting it at the wingtips then move your support close to the fuse till it balances out again and make a tiny mark or measure it for reference if you don't want to make a mark near the fuse..
tominator06 is offline Find More Posts by tominator06
Old Aug 11, 2011, 08:21 AM
Pennsylvania
Joined Jun 2010
I used a peice of string, wrapped spanwise around the wings, and used a square to make marks next to the fuse. Marked it with the string around the tips at 6", and 1/4" intervals further back.
Old Aug 11, 2011, 03:25 PM
crobar is offline
crobar's Avatar
Joined Apr 2009
Thanks for the tips. This is the first plane I've had where the cg was called out at the wing tips as opposed to referencing the leading edge near the fuse.
Old Aug 11, 2011, 06:53 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
well shoot. killed my stock battery & not anywhere i can buy another one.
wonder what would happen on a 3s2000 pack on a 12*6
Toysrme is offline Find More Posts by Toysrme
Old Aug 11, 2011, 07:27 PM
Team Hillbilly
Joined Feb 2009
3s would not give enough Rpm with that prop. Just a guess but you would have to run a 14"-15" prop to get the thrust needed. I wouldn't even attempt it.
Old Aug 11, 2011, 07:34 PM
2006rfarmer is offline
Find More Posts by 2006rfarmer
United States, CA, Temecula
Joined May 2006
Hobbypartz.com-- ValueHobby.com and alot of others have batt. in stock and at a resonable price!
2006rfarmer is offline Find More Posts by 2006rfarmer
Old Aug 11, 2011, 07:39 PM
GetSome! is offline
Find More Posts by GetSome!
GetSome!'s Avatar
United States, CA, Roseville
Joined Jan 2011
not a good idea if you like your plane
GetSome! is offline Find More Posts by GetSome!
Sold E-flite 4-Site like new BNF Version MK2 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 30, 2010 06:51 PM
Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? MerlinKing Parkflyers 3 Jan 20, 2010 08:45 PM
Discussion Why Not wood -balsa BNF or PNP RC airplanes from E-flite? MerlinKing Scale ARF/RTF 1 Jan 20, 2010 06:29 PM
Alert Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... jamiekerr 3D Flying 15 Aug 07, 2007 12:24 PM
Poll Part of Ikarus Yak 54 Or E-Flite Extra 260 E-Flite Sobre 3DX shocky... POLL jamiekerr 3D Flying 1 Aug 07, 2007 02:55 AM
