Old Oct 13, 2010, 10:44 PM
TechXpert is offline
Find More Posts by TechXpert
Joined Oct 2010
Help!
Brush vs Brushless
I'm not supposed to use RC in my project.
So i am just buying a Brushless motor.
But can a brushless motor work without esc?? (if yes how)
also can an esc work without without remote control?? (if yes how)
also i am being suggested to switch over to brush motor. what will be the speed difference i will observe ? (with any high end brush motor with cost under a brushless motor)
please reply fast. i need to complete my project soon and will have to order the motor via shipping
TechXpert is offline Find More Posts by TechXpert
Old Oct 13, 2010, 11:38 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
You must use an ESC to run a brush-less motor,
you can buy a servo tester that will replace the Remote Control to drive the ESC.
Impossible to answer second paragraph there are too many variables in motors, without further information, Ie voltage, prop size size of boat etc
Nick
nick_75au is offline Find More Posts by nick_75au
Old Oct 14, 2010, 04:25 AM
Joined Oct 2010
I was buying
Prop -> http://rcforall.co.in/product_info.p...roducts_id/414
Motor -> http://rcforall.co.in/product_info.p...roducts_id/154
ESC -> http://rcforall.co.in/product_info.p...roducts_id/293
But ESC being costly, i am thinking to switch over. so please suggest if a brushed motor could deliver a similar performance
and by the way i do not need to tutn my boat, it just has to go straight in a poool. so what should i do so that there should be no control for ESC
Old Oct 14, 2010, 06:05 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Go for a good quality brushed and power it directly from the battery, it's a lot easier. The prop you linked is very big, will be ok for a boat 25" or higher. For your 12" you should go for
http://rcforall.co.in/product_info.p...roducts_id/402
Look for a motor in the 380 size area (diameters around 28-32mm), with direct drive to the prop.
CornelP is offline Find More Posts by CornelP
Old Oct 14, 2010, 06:56 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ 28mm in a 12" boat with no RC equipment (weight) will be pretty ballistic!
TechXpert, since running a brushless motor will require more weight in equipment (finding a small enough servo tester will be hard too), you'll likely get better performance from a brushed motor in your scenario. In an RC boat that already has to lug around a receiver and ESC the brushless is better, but you don't have that weight burden in yours.
wparsons is offline Find More Posts by wparsons
Discussion Brush vs Brushless? ForeverFlying Power Systems 23 Aug 23, 2010 01:08 PM
Help! Brush vs Brushless CCLarry Scale Boats 10 Jun 30, 2009 03:00 PM
Discussion Pros and cons of brush vs brushless norgale Dock Talk 26 Jun 17, 2009 04:20 PM
Brush vs. Brushless, Geared vs. Non-geared ForeverFlying Power Systems 15 Oct 22, 2003 08:37 PM
Brush Hardness vs. Spring Tension dkimball Power Systems 3 Sep 22, 2002 12:08 PM
