Old Oct 13, 2010, 09:13 PM
mitsudriver274 is offline
Find More Posts by mitsudriver274
Joined Jul 2009
Slow Stick X motor sugestions?
Being as the days are getting shorter I would like to get a night flier together. I like my planes to serve multiples purposes so I plan on using this one for night flying, my acrobatic float plane and parkflyer.
I currently have a towerpro outrunner 2409-12t, 20amp esc and a 8x3.8 prop. This setup is rated at 200watts, will this work for a slow stick? And what will slow flight be like?
mitsudriver274 is offline Find More Posts by mitsudriver274
Old Oct 14, 2010, 01:08 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Mitsudriver,
The stock motor of Slow Stick, brushed EPS400C-DS+ Prop EP1060 + 9.6V is rated less than 100W. http://www.gwsus.com/english/product...em/eps400c.htm click at the circles of 1060 under D gear viewing its performance. Yours will be more than enough for flying SS.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Oct 14, 2010, 08:46 AM
Fredriksson is offline
Find More Posts by Fredriksson
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
I assume you are using a 3S LiPo? That power system will work. Slow flight depends on total weight, not power system although the weight of the power system is part of the total weight. But that TowerPro is not a heavy motor. Slow flight should be fine especially if you have the CG dialed in.
Freddy
Fredriksson is offline Find More Posts by Fredriksson
Old Oct 14, 2010, 10:16 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Since it is such high Kv (1600) I might run it with that motor on 2s... with a far larger prop... maybe 11x8 GWS HD.
I fly my SS with an Axi 2212/34 (740Kv) on 3s with an 11x8 GWS HD at under 10A (~100W)... your 1600Kv motor on 2s @ 20A should manage somewhat higher (?140W) output.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 14, 2010, 07:19 PM
Just having fun
Joined Feb 2008
Yes, that high kv has him set up more for speed on 3S. I use that exact same TowerPro motor on my GWS E-Starter but I use 2S and a 9x6 prop.
I think the title of the thread Slow Stick X motor implies that this Slowstick has the X wing, not the stock Slowstick wing. I don't know what kind of speed the X wing set up can handle. So this speed system may work OK. For slow flight he will not be using much throttle.
If a person really wanted slow flight from a Slowstick they should keep the stock, high lift wing. And with the high kv motor move to 2S and a larger prop like Dr. Kiwi suggests.
Freddy
Old Oct 14, 2010, 09:45 PM
romanl is offline
Find More Posts by romanl
Joined Dec 2007
I am using an Eflite 450 with a 1300 mah 3S battery. The combination works great.
romanl is offline Find More Posts by romanl
Discussion Slow Stick- Home made Wing Mount guyg Aerial Photography 1 Oct 11, 2010 03:11 PM
Discussion Slow stick users- Help- Bcak Wing Mounting- from fuse size? guyg Aerial Photography 2 Oct 10, 2010 01:35 AM
Getting a slow stick sugestions? thor4944 Parkflyers 27 Jan 19, 2003 09:11 PM
